wheel center bores...
Results 1 to 18 of 18
Thread: wheel center bores...
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    If for example your center bores on your wheels are slightly too small could you get these turned to fit? Would it weaken the wheel?
    www.shonkyopels.de
    Feb 2006
    Pontypool, S.Wales
    Mk4 GSi Van
    Re: wheel center bores...
    it is posible yes ive seen it done before, how much are you talking? cant see it weakening if only a bit
    Oct 2002
    2-3 mm I reckon, will need to measure it properly tbh. I reckon if I hammered the wheel on it would fit though, it's that close!
    www.shonkyopels.de
    Oct 2002
    P.S.: Check my thread, nice easy way to lower the std seat
    www.shonkyopels.de
    May 2006
    South Wales
    subaru impreza/mk3 astra
    can and has been done. i got a set of MGZR 16inch alloys on my astra (white ones on the left ) that have been done in the past by the previous owner and i dont have any problems with them.
    Oct 2002
    Can you go hit a few potholes whilst cornering hard please! lmao
    I'm sure it will be fine as at the end of the day they make them with renault hub center and 4x100.
    www.shonkyopels.de
    May 2006
    South Wales
    christ yes, i drive like a fool (check out my off at combe this year!! - The 'Rob Jenko running out of talent at Combe' Thread. lmao ) ive got rally car wheels that have had the bores machined and they take a load of abuse and are fine. the outers rim will buckle and absorb any impact before the centers start cracking im sure
    Oct 2002
    Lee can't do it on his lathe Do alloy refirbers do it?
    www.shonkyopels.de
    Nov 2005
    Chester - North West
    Vectra C CDTI
    Would not changing the spiot rings help ( or am I way off? ) alloy wheel repair places could do this I'd say
    May 2006
    South Wales
    Quote Originally Posted by spanishfly View Post
    i doubt it. best bet would be to get out the yellow pages and find a local engineering place or dig out the dremel and have a crack yourself. or do a nut and stud conversion and run with spacers!
    Quote Originally Posted by Kev_G View Post
    standard vaux alloys dont come with spigot ring though.
    MIGWeb User angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    If the tyres are off they could be set up on a mill and bored out, but obviously check how much is coming out!. I could probs do it as a private job in between work if you are stuck, depends if a machine is free
    Oct 2003
    Glasgow/Oban
    Like it's a hire car
    die grinder will do it near enough, they dont take any load anyway
    Oct 2002
    Swindon Builds: Nova
    Vectra SXi
    Vaux wheels have a 56mm bore IIRC. Renaults have a 60mm, again IIRC. When i had Renault 19 16v alloys on my last Nova (yes, utter chav!) they did need centering properly. So i guess taking 4mm off shouldnt be an issue. I'd be wary though.
    Nearly finished building a C20XE nova...
    Apr 2002
    Southwest
    Like its stolen
    I did this on friday as I was at a dead end with the nova and my mrs said she'd like to see what my corsa wheels would like like on her clio, is that similar to what you are lookin to do?
    Really suits it I reckon.
    I did it using adaptors we made up from a vauxhall spacer, all I had to change on the car itself was to machine the spigots a little shorter and put a taper on them to match the taper machined into the spacer (I used an angle grinder on the car spigots as just needed to have clearance length wise not to be an exact match) as I wanted to keep the adaptors thin to get the offset close to original (renault is 38 and vauxhall is 49, I used 15mm spacers so only 4mm difference) on the front as I didnt want to ruin the geometry.
    On the rear I used a 25mm VW spacer (all I could find in a hurry) and machined the spigot down to vauxhall bore and then the inside I got taken out to renault size.
    Vauxhall was 56.6 and Renault was 60.2, so it was 1.8mm that we had to machine off all the way around
    Apr 2002
    Southwest
    Like its stolen
    PS
    Boring out and just using a spacer to correct the offset wouldnt be a problem, but I didnt want to go down that route as I have several sets of wheels that I want to be able to use on my clio and the corsa depending on what we are doing with them.
    Oct 2002
    Good work Chip. Ali think i'm gonna do your idea and give it a go myself with the die grinder. Will let everyone know the outcome!
    www.shonkyopels.de
    Oct 2002
    Just thought I would add this for the renault boys on MIG.
    The clio ph1, cups and trophy run Et42-45. The other models run ET38. So basically vauxhall wheels are fine it there ET45, which is what most aftermarket wheels spec'd for vauxhalls are. So once you've grinded the centre bore you can use them Chuffed
    www.shonkyopels.de
    Apr 2002
    Southwest
    Like its stolen
    Yeah the later sporty clios are a higher ET, ive got a set of mk2 wheels that have to be ran with spacers on my mk1
