Results 1 to 5 of 5
Thread: painting gearbox
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    painting gearbox
    ok i want to paint my gearbox when i refit so was wondering what steps to follow to get a good finish and also what paint to use as want it to last, quite tempted to paint white as the car is white but it will probably be grey
    Apr 2010
    southport
    500BHP corsa b
    Re: painting gearbox
    clean it all up with a degreaser to get rid of any contaminants, maybe a jet wash, but shove a rag in the d/s holes, let it dry then get painting, i advise hammerite, as its about the best think for tough long lastingness unless you go for powder coating.
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    2k or enamel will be most robust but I've always used hamerite as it's cheap as chips and easily jetwashed clean
    Getting 2pac to stick is very hard unless you can sit and sand the whole box down... Which isn't easy.
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Hammerite will go straight on but they do a primer for aliminium which gives it a better key. Go over the box with a wire wheel on a drill
    This stuff
    HAMMERITE SPECIAL METALS PRIMER 250ML NEW STOCK on eBay (end time 24-Aug-10 13:57:49 BST)
