Results 1 to 12 of 12
Thread: Nova crossmember
    May 2006
    Tadcaster
    Corsa B
    Nova crossmember
    Hi all just in the middle of rebuilding my nova and found this on the crossmember can it be repaired or do i need a new one ?
    Re: Nova crossmember
    You could cut all the rust out and repair it with nice thick metal. Might be easier to just replace it.
    May 2006
    Tadcaster
    Corsa B
    thanks Benn what kind of thickness would you recommend
    Dec 2009
    Llynfi Valley
    Corsa B
    Dont you have to watch when replacing that you get all the dimensions right etc mate. Do as Benn said first and cut it out and weld in mate easiest option
    Liam
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Yeah that's fixable use 1.2-1.6mm steel plates and might be worth putting the chassis strengthening kit on as well if your going for big power
    May 2006
    Tadcaster
    Corsa B
    Thanks for the info guys will get it cut out and repaired.
    Dec 2008
    West Lothian
    MK 3 ASTRA GSI
    i would just replace the crossmember
    PS3 ID ferris_gsi ADD ME
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    /\ but then you need to put it on a jig, which is not something most people have access to. and if you dont use a jig, then it will almost definitely go out of shape.
    thats certainly repairable anyway, no point in making extra work for yourself for no reason by replacing the whole cross member
    [SIGNATURE] [/SIGNATURE]
    May 2006
    Tadcaster
    Corsa B
    Hey guys I got some metal today and set about repairing the crossmember this is the first side
    I will do the other side tomorrow.
    May 2006
    Tadcaster
    Corsa B
    Final pics of the crossmember repair now in zinc primer and seam sealer.
    Looks good.
    May 2006
    Tadcaster
    Corsa B
    cheers Benn
