I have a question or two:
My Manta has filed MOT because of fair bit of rust on the floor panels, so i have stripped the carpet and underlay, and chisseled off the bitumen stuff that just came off in brittle chunks and not as sticky gungy stuff, due to the age of the car (23 yaers old)
So I exposed the rsuty areas and can now see all the rotten steel and big holes, so the question is
1) Do I weld new material from below the floor or from inside the car?
2) or do I cut the new material just the right size for the hole so that it does not overlap the hole to be welded, hence it could be welded from either top or bottom, welding from top would be a lot easier as you won't have to get under the car and weld against gravity)
and what is the best welding method? Mig weld or gas welding ?
.jpg)
.jpg)
