rust and cracking on a corsa b's b pillars
Results 1 to 17 of 17
Thread: rust and cracking on a corsa b's b pillars
    Jun 2010
    hey guys, looked through a couple of threads about this and noticed alot of people are saying that there is some sort of kit/mod that vauxhall made for it, anyone know where i can get this from? cheers
    MIGWeb Moderator
    Midlands
    Nowt
    Re: rust and cracking on a corsa b's b pillars
    Vauxhall?
    Jun 2010
    ]nova boy roy
    Re: Cracked pillars and patches of fading on my Corsa B
    Cracked B pilars !!! this was a recall from vauxhall and there is a mod for this !! its a metal plate that come as a pair for n/s and o/s they get glued in place (yes glued in) first off they get welded up then the mod panels get glued in place then the outer part gets filled then sprayed !!!!!
    is this not right then? and would vauxhall still sort it out as it was a recall? or is there like a time limit to a recall?
    Nov 2007
    Peterborough
    XE'd Mk1 Escort on TB's
    All corsas that didnt have a sunroof crack there
    MIGClub Member justin1970corsa's Avatar
    May 2010
    somerset.
    corsa vxr,nova 3dr hatch.
    my old corsa b ,sri cracked there ,so i welded it up ,& painted it up so that it was unoticeable, but my n reg corsa sport & my t reg corsa sport that i have now havent got cracked pillars :]
    Nov 2005
    Egham, Surrey
    Vectra CDX, Daewoo Matiz
    Th N reg Corsa i have just got has a cracked passenger B pillar but not the drivers side for some reason
    Apr 2010
    southport
    2008 civic diesel
    i've never seen this, and i've owned around 15 corsa b's various ages some with and some without sunshine roof's
    MIGWeb Technical Moderator Dale's Avatar
    Jul 2006
    Swindon
    Monty / Vinnie (AstraVXR)
    Quote Originally Posted by leemini25 View Post
    I Have 95 LS without sunroof and it hasn't cracked!!
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    My L reg gsi cracked and that has sunroof, my L reg diesel cracked and that didn't have a sunroof, and my R reg corsa never and that did have a sunroof! To name but a few! It's a bit hit and miss but it's my understanding Vauxhall did do a re call on this and have heard about a plate being bonded in, and the later shells had them from the factory iirc
    Nov 2005
    Egham, Surrey
    Apparantly lowered cars are more at risk from this too but not sure on its truth (mines lowered 60mm as it goes)
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    nah i've had standard ones for bombing to work and back and they've been cracked too
    Awaiting Email Confirmation
    Mar 2010
    Lockerbie Scotland
    Corsa C20LET & Nova C20XE
    its a strange one i've had it on standard sris and sports with and without sunroofs i was always under the impression it was to do with being lowered but as dewis said it happens to standard cars too. i now run 300hp c20let in a 2000 shell and touch wood it hasent cracked
    Jay
    Jay is offline
    Oct 2008
    Fife,Scotland
    Corsa B
    I have an R plate Corsa with the sunroof and it has cracked,tbh the reason this happens I
    Think is because the whole body of the car will twist slightly and crack there because it is
    A weak spot in te car.
    Captain we just can,t do it....just don,t have the powerrrrrr!:)
    Previously known as - Vauxhall_Redtop
    Jul 2010
    Stafforshire
    Corsa B LET
    My L reg has
    Nov 2005
    Egham, Surrey
    later cars have a stuck on modified plate fitted inside the b pillar
    Wales Regional Co-ordinator slash's Avatar
    Jan 2006
    South Wales
    Astra GTE
    they all go vauxhall solved the problem on post 97 cars.
    Jan 2011
    Stoke On Trent
    Reanult Sport Scenic 182
    There was 'apparently' a fix yes but ive had to repair a 2000 1.2 Sxi with sunroof which suggests to me its more nonsense or fitted at random, best and only way to fix and stop oit coming back is same as i always do it, prep the whole are back to bare metal removing the obligatory rust, air saw the crack so it has an equal straight edge, use a crew driver and hammer and dent the now fine cut inwards, now fill the dented in groove slowly with weld bit by bit so as not to warp the quarter, refinnish it back so its all flash with surround metal and MAYBE if needed youll need a slight skim of filler, either way though youll need the whole quarter and door repaiting so as its not ever noticed again :-/
    Wayne
