any help or info on some huge discs that will fit my astra g as im using range rover sport front brembo calipers?? pref 360mm??? a.s.p???? desparate.. ta
use range rover discs and just get them re-drilled for vaux fitment
badryder_666, I don't know anything about AstraG suspension leg/ hubs etc however here is my 5-stud Calibra Turbo fitted with your calipers and the 360mm discs as per matt_b_uk description.
As you can see, things do get a bit tight around the wishbone.
Stopping on a penny anyone! jesus there big.
wich brake pump are you using mate ? the standart one ? and wich servo also ?
I dont suffer from insanity ,I enjoy every minute of it !
Are you asking me Chosta?
They were used with the standard Calibra Turbo master cylinder owhich at 23.8mm is slightly larger than some other Calibra models. I've sold this setup as the 19" rims they needed weren't suitable for the road surfaces I use in that car.
Standard pedal, yes it was soft.
