Results 1 to 9 of 9
Thread: MOT regulations for welding floor
    May 2006
    Tadcaster
    Corsa B
    Hey guys I need to plate some areas on my nova project both sides need doing. What I need to know is do I need to put in the strengthening parts in new section like I cut out (pic below) and also will it be seam welded and will 1mm thick sheet steel be ok ?
    Re: MOT regulations for welding floor
    That's fine.
    Mot man would just look at it to make sure its no holed.
    May 2006
    Tadcaster
    Corsa B
    So I wont need to put strengthening in then ?
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    I'd use 1.6mm plate for the floor.
    If there was a crossmember under there it needs to be replaced too.
    May 2006
    Tadcaster
    Corsa B
    Hi Mark no theres no crossmember where I have cut out rot you can just see where it is in the pic to the right.
    The bit in the bottom pic on the right is the cross member, the other shaped did i don't think does anything for strength.
    MIGClub Member fennyLET's Avatar
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    What about needing to change the bit on floor were the VIN number is
    Nov 2008
    Isle of Bute
    got too many to list lol
    Quote Originally Posted by Mark T View Post
    i agree either 1.6mm or 2mm plate,
    fenny tbh the vin on the floor is almost never checked at mot but it is by th traffic boys if your carpet has the cutout if not they dont check it
    all i got for christmas was a sweater
    i wanted a moaner or a screamer
    Dec 2001
    Southampton/Reading
    The Pheonix
    1.6mm plate with a continuous weld. Obviously it would pay to weld the cross member like part up from below as well.
