Results 1 to 13 of 13
Thread: what metal is this
    Feb 2008
    weston-super-mare
    20xe mini + 20xe corsa b
    what metal is this
    it is magnetic and when heated it makes a white layer onto of the metal but it cant be welded with a mig welder i need to ad a section onto this it is the throttle lever arm off a bike throttle boddie and it isnt ally cheers james
    Feb 2007
    fife
    corsa sport + GSi
    Re: what metal is this
    Is it maybe steel with a zinc passivate coating? looks kind of yellow? try cleaning it up with a grinder first
    Sep 2004
    Nottingham M1 J26
    Cars. Loves: Dirty sluts
    Aluminised steel?
    Feb 2008
    weston-super-mare
    yeah tyhat must be it i did clean it up but the weld just didnt seem to want to penatrate will give it another go cheeers mate
    Feb 2008
    weston-super-mare
    any way i can weld aluminised steel pal
    someone has managed to weld it befor as i have a pic of a modified one some were
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by tinxy View Post
    I haven't ever done aluminised steel but I'd take it to somewhere I could tig it. I'm not sure if the coating (whatever it is) could be skimmed off and then weld the steel underneath or if it's "mixed" with the steel ie the same throughout
    Feb 2007
    fife
    corsa sport + GSi
    Sounds like it is passivated, the weld just sits on top and bubbles up. Aluminised steel does the same like the length's of exhaust tubing
    Feb 2008
    weston-super-mare
    yeah pal thats what it does so just skim it rite back and it should penatrate ???? thanks so far guys
    Feb 2007
    fife
    corsa sport + GSi
    Aye worth a try, as Nemesis said tho if its a metal mixed in with the steel then it wont work.
    Probably just going to be coated steel if its a mass produced part.
    Wales Regional Co-ordinator Tathan's Avatar
    Jun 2002
    Wrectum
    aluminised and zinc galvanised are just a coating so should be fine when cleaned up. if it's not, then it's an iron alloy with a lot of something in it.
    MIGClub Member Lugy's Avatar
    Sep 2005
    Midlothian, Scotland
    Vectra DTi/BMW E30
    Could also be stainless, though quite unlikely.
    Jun 2002
    Wrectum
    decent stainless isn't magnetic though, only the semi-stainless nickel free ones are iirc,
    Feb 2008
    weston-super-mare
    ground it back plentey and cleaned it up and it welded spot on in the end cheers guys james
