Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 51
Thread: how 2 fabricate a performance intake manifold.
  1. #26
    Feb 2008
    lee-on-the solent
    j reg cavy gsi turbo
    Re: how 2 fabricate a performance intake manifold.
    you are right Benn i just shortened the cable so it would fit, and is very close to the fuel rail, as soon as it stops raining im guna fit the manifold, hopefully this saturday/ sunday (14th-15th) providing i dnt have a hang over, but will upload pics as soon as is fitted and running!!
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    What colour has that cam cover been painted mate?
  4. #28
    Feb 2008
    lee-on-the solent
    its guna metal grey with green and silver metal flake! and the spark plug cover is a cut up carbon fibre sun strip lol
  5. #29
    Quote Originally Posted by James P View Post
    Bring it to the meet so we can have a look dude.
  6. #30
    Feb 2008
    lee-on-the solent
    wat meet?
  7. #31
    Oct 2002
    Sweden
    Astra MkI
    Impressive work dude, But! you kept the restrictive area.
    The runners are very small at the flange to the head.
    Did you port them out before welding?
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  8. #32
    wat meet?
    South Central meet was today...
  9. #33
    Nov 2008
    hastings
    let nova, let astra gsi
    if power gains are noticeable would u make 2 order?
  10. #34
    MIGClub Member c20letian's Avatar
    Jul 2009
    Kent
    Calibra 4x4
    i know vauxhall spent millions on design and testing but yours looks so much better...
  11. #35
    May 2008
    flying past your GPS
    like escaped
    i have 3 such inlets knocking around the lock up...if i give you them
    could you do me one at good mates rates?
    iam thinking technically here
    the piece may have better over all flow gr8 for high end turbos as the cross section either side the TB inlet is greater than the sum of 2 branches with bigger cross section=better flow efficiency - but not sure if torque at low revs is compromised
    if you get a dyno to prove would be good...let mass order commence lol
    loosing weight is the only modification for fellow fat bst'rds
  12. #36
    Feb 2008
    N.Ireland
    Cavalier Turbo
    Brilliant Work
  13. #37
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    I think you'll have trouble with air to 1&4 as 2&3 will be trying to steal all the air as it comes in! You needed to taper them towards 1&4 to try and prevent this!
    Here's mine
    there's the full inlet build in here
    VauxSport - Vauxhall advice and chat forum :: View topic - dewismotorsport's Corsa b gsi LET
    it's pretty much a straight bolt on uses standard rail (bar a 90 degree bend)and all other features
    I'll making some for people, £200 for above design, or can make to any design you require! PM me on here or vauxsport.com
  14. #38
    Jan 2002
    ayrshire scotland
    like a saint-9points
    Quote Originally Posted by dewismotorsport View Post
    Here's mine
    I'll make some for people £175 if supplied with old manifold or £200 without, to any design you require! PM me on here or vauxsport.com
    have you had a before and after run done on a dyno with this fitted by any chance? and how does it fit, its a tight squeeze in a corsa?
    rodgerq
  15. #39
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    No I haven't as I'm still building my new engine up, that is my prototype, I've since made a slighty different one, which is in the sandblasters as we speak but will post up pics when I get it back, heres a before pic:
    am waiting on one of my customer for the dyno run but using my maths it should definatly flow a lot more air, and with a lot less resistance over standard
    fits on a Corsa as that's what I designed it for, you just have to move the header tank slightly
  16. #40
    Jan 2002
    ayrshire scotland
    well i'd be looking to fit into a nova which has more bulkhead space anyway. very interested in the dyno run results!! easy enough to put the LET TPS on the 2.5 V6 TB?
    rodgerq
  17. #41
    MIGClub Member crombievts's Avatar
    Jun 2007
    Dingwall
    type r yO
    id be interested in buying one of these. id supply my standard inlet. any info on fitting the v6 throttle body. how long roughly would it take to make
  18. #42
    Aug 2008
    Peterborough/ketton
    Corsa
    any chance of a huge favour?
    this dimension?
  19. #43
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Yeah no worries mate, I'll post up on Monday as I don't get it back from the sand blasters till saturday
  20. #44
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by rodgerq View Post
    rodgerq
    the vectra V6 throttle bodie TPS sensor is the same as the LET's mate so direct swap
  21. #45
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by crombievts View Post
    Yeah not a problem just PM me, I aim to make them in 2-3 weeks, postage is £12 first class with Royal Mail and you can normally pick up a vectra V6 throttle bodie off eBay for £20-£30 delivered or cheaper from scrappy, what else do you need to know about it? It's 64mm so larger than a LET and it uses the same TPS sensor as a LET
    the throttle bodie in the picture is a modified one to 76mm/3"
  22. #46
    Jan 2002
    ayrshire scotland
    where'd you get the modified larger TB from? if the dyno results prove conclusive i'll be interested in one of these aswell.
    rodgerq
  23. #47
    Dec 2002
    Essex
    Lada Riva
    Looks good , both of them .
  24. #48
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    rodgerq
    it's a standard size throttle bodie but with a 3" pipe welded onto it, is what I meant sorry
  25. #49
    Jan 2002
    ayrshire scotland
    ah right a get ye. ad only be using 2.5" boost tract at the most, no need for 3" for me. keep us posted on the dyno results
    rodgerq
  26. #50
    Feb 2008
    lee-on-the solent
    im just putting the manifold on now, ill upload some pics whilst it goes together as ive taken the engine out to re-build it
