spraying problem
Results 1 to 10 of 10
Thread: spraying problem
    Aug 2004
    bristol uk
    vectra 2.0 sri p reg
    spraying problem
    just sprayed my bumpers then later i put the lacquer on,it looks good but still has a very dull look to it,it almost still looks like a mat finish!i have been told to wet and dry back(1200) or (2000) which i started to do but it was really starting to scratch the paint work and i was finding it really hard to polish up...even then it still looks dull....how do i get it so it looks like the glass finish of the rest of the car??many thanks
    Oct 2000
    Portishead
    300ZX TT & Passat R
    How many layers of lacquer have you got on there?
    You can't just rub it back and leave it, you need to get the cutting compound on it and after cutting back with then you need to bring the shine up with lots of polishing.
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Not enuff flatting between the layers of paint IMO
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Quote Originally Posted by CraigGreen
    Don't flat between the layers, can do with solid, but not metallic.
    Aug 2004
    bristol uk
    about 7 quick coats of lacquer,so is g3 the best stuff to get hold of?how much does it cost and how do i go about bringing the shine then?
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Ok, your locals motorfactors should be able to get it. It's not expensive. I buy it by the tube and it's around £10 a tube.
    You use this in quite an abrasive action after flatting back. But make sure you have an even dullness all over from flatting back. No low spots (indicated by small shiney bits). Don't go over the same spot too many times. Even action. Buff off with cloth. It'll still not be shiney, but it should be very smooth.
    After this, bring up to shine with polish. AG Super Resin polish is adequate. Again, you need to be quite abrasive with this. You also may need to polish and buff a good few times to get a good shine. You'll see the more you do it.
    Jul 2004
    Swindon, Wiltshire
    bmw 730 on 22s
    what brands of lacquer and hardner are you using cuz mixing paint products can fook it up as well mate try and you same brand 4 both lacquer and hardner
    www.AT-LEAST-ITS-NOT-A-SAXO.com
    Aug 2004
    bristol uk
    yes it was the same brand of paint and lacquer i didnt use hardner cause the paint was part paint part thinners,i was using a basecoat!but im still alittle confussed i was told apply the paint but dont rub back!then apply lacquer then i am ok to rub back....so if i was useing 2pac paint would that of gave it a better shine?
    Oct 2000
    Portishead
    300ZX TT & Passat R
    No, you NEVER rub back the base coat metallic. You'll shag up the metallic paritcles changing the shade.
    Aug 2004
    bristol uk
    cheers si
