I should hopefully be fitting the K26 some time soon. I've got some of the Halfords manifold paint and it says it can withstand up to 650degC. Has anyone else used this stuff or similar to paint the manifold or even the turbo on an LET? According to my EGT gauge the exhaust gases normally run at about 800degC rising to over 900degC when under heavy load (that was with a K16 so I would expect the K26 to run lower temps as it shouldn't be working as hard?). Would I be right in thinking the manifold itself should be cooler than the actual exhaust gases? When I tried lagging the downpipe with the best stuff you can buy it just fell to bits after a few months so I don't want to try that. Any advice/comments welcome![]()
