Any spraying experts on MIG?
Page 2 of 2 FirstFirst 1 2
Results 26 to 34 of 34
Thread: Any spraying experts on MIG?
  1. #26
    Oct 2001
    Herts
    Grale, Mustang, 535i
    Yeah, best thing you can do is rub back with some 1500 or something, another coat of primer and then rub that back a little and hopefully you should be able to hide it. It depends just how bad it is. You might need a couple of extra coats of primer.
    Mike
    MIGWeb Moderator
    Midlands
    Nowt
    Cool, cheers.
    Paul
  4. #28
    Oct 2001
    Herts
    No worries mate. Let us know how you get on.
    Mike
  5. #29
    MIGWeb Moderator
    Midlands
    Nowt
    Just back from the workshop.
    Hit it with a few more coats and it appears to have gone.
    Will leave it to dry overnight.
    Paul
  6. #30
    Dec 2004
    Colchester,Essex
    PuntoGt|AstraGte16v
    buy a product called guide coat once sprayed on to the area with filler if anything is going to show through once paint is applied the guide coat will show it up, then you will have to sand down on these areas that have come up.
    Also there is no mask which is not air fed that is suitable for spraying 2pack, in our shop we have these new masks called fly masks that can withstand a very small level of Isocyanate but not enough so you can spray body panels with it..
    trust if ya gonna use 2k you will be needing an air fed mask, to risky without jus for the sake of a few panels
    Danny
    Astra Gte 16v
    |Any Paint and Bodywork advice needed pm me|
  7. #31
    Oct 2001
    Herts
    Quote Originally Posted by D4NNY
    A very light dusting from a black aerosol will also do this job nicely.
    Mike
  8. #32
    Feb 2005
    Quote Originally Posted by dogsy
    you can now get masks that are not air fed but are suitable for spraying 2-pack. ive got a few and they are excellent, cost about £25 but you get a decent amount of use out of them.
    I found this on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=7950414601
    Is this what you have? where else can you get these
  9. #33
    Mar 2004
    Nottingham
    Ventora & Yanks
    I wouldn't trust it. I have a mask very similar to that I use for non-Isocyanate spraying and I know how much solvent I end up inhaling even though I have the mask on because of the fit round the face obviously isn't 100% as everyones face is different.
    There is also no protection for your eyes. Isocyanates like to enter your system via your tear ducts.
    Some decent goggles and one of those masks will be far better than one guy I know who's protection consists of "holding my breath"
    I guess it also depends on how often you spray. Once every 3 or 4 years and I'd say your fine (2 pack probably won't even exist when you do your next one), but if your doing a few cars a year then def. get the proper air fed neg pressure seal kit.
  10. #34
    Dec 2004
    Colchester,Essex
    PuntoGt|AstraGte16v
    yeh they are very simular to what we sell mate BUT as ali says it will not protect you enough to spray large amounts of Isocyanates, if your after a nice gloss without using cellulose jus use a polyester basecoat with a single pack laquer.
    Astra Gte 16v
