Which plates (numbers) do people recommend putting on as i've heard the whole kit is a bit OTT for road use.
Thanks in advance...
anyone please...
Critical areas are front suspension lower arm mounts, strut tops, bulkhead.
No, now f*** ***.
ive fitted them all but save your money and just weld up every seam should be good enough
Ive got this kit on my nova and has made a world of difference! it handles like it had a smaller engine in the front, not the valver
Well you won't need the sump guard mounts or the sill stand mounts but other than that i would fit them all . you may get away without fitting the rear beam plates also.
