How long does it take for laquer to fully dry....
Results 1 to 20 of 20
Thread: How long does it take for laquer to fully dry....
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    Anybody who's good with paint etc. Just relaquered some bits, and need to know how long they will take to fully dry.
    Cheers
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Re: How long does it take for laquer to fully dry....
    a week! I wouldn't clean, flatten polish or do anything to it for a week if you can incase chunks start coming out of it! I left my guitar that i sprayed and laquered on top a filler spreader thingy by mistake bout 2-3 days after laquering which stuck to it and pulled a small chunk of laquer away.
    5-7 days I'd say I think to be safe.
    please DrIvE slowly
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    Only reason i ask is because i rapped the bits up about 3 days after they were sprayed and ended up with the stitching pattern on the laquer.
    Aug 2003
    yeh, can do that just needs a rub down (wet sand) then use a compund to get all the scratches out (tcut or something like that) then polish to seal it! You should be fine with just a hard wet sand, compound and polish.
    But wait a week from application before you attempt it! otherwise your gonna be getting chunks coming off.
    please DrIvE slowly
    Aug 2004
    Durham
    Corsa 1200cc
    Dont no m8 i dont use it sorry, i got no hair to put it on m8 lmao
    Always with one eye on the law
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    put an arch on an escort last week,applied laquer,compounded and polished it 2 hours later.
    Need custom t-shirts?...www.deathgimp.co.uk
    Aug 2003
    tis risky though ain't it! feel free to risk the laquer coming off in chunks by all means. I've had laquer though that has dun that after 3-4 days (come off in chunks)
    please DrIvE slowly
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    Quote Originally Posted by BigbaRd
    nah no risk- excellent stuff cellulose,heating on for an hour and its hard as a hard thing
    Aug 2003
    hehe u know'z more than me
    Dunno if it's different with 2pack is it? or is it quicker to dry.
    please DrIvE slowly
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    i never use 2-pack as i don`t have any air fed gear to keep me alive,with cellulose and some heat lamps you can start fitting up after a few hours
    Aug 2004
    MOON
    TANK
    Two words is all you need to know>>...
    DATA SHEET
    MK3 astra only forum www.mk3oc.com
    Aug 2003
    lol
    I was told different by someone at a bodyshop with 2pack
    plus mine dun that after 3-4 days (chipped)
    must be dfferent with 2pack then
    please DrIvE slowly
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    lol
    with cellulose,on a warm day with no heating its touch dry in about 35 minutes,stick some infra red drying lamps on and its totally done in about an hour
    Mar 2004
    Nottingham
    Ventora & Yanks
    Not sure on the effects of heat lamps on celly 'cos I've not tried, but air drying you need to leave it ages. Even when its touch dry its not cured.
    2 pack can be cured out in 15 - 20 minutes.
    Thats one reason that pro bodyshops like it so much. You don't have to store a customers car for 3 days before polishing.
    You might well be able to do a quick polish on a celulose job in a couple of hours (yeah, I'v done that) but if you need to do any serious flatting on it you'll just break striaght through as its still soft under the skin. Yeah, I've done that too...
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    Quote Originally Posted by alistairk
    Nahhhhh cellulose takes next to no time to dry,it dries by eavaporation of solvents in the air.I`ve sanded runs out after a coupe of hours.
    Dec 2003
    Widnes UK
    Astra Coupe
    Yeah i just finished laquering some bits tonight and im gonna just leave them overnight b4 t-cutting them.
    They are already touch dry now after about 30mins.
    English should be so easy.......... I speaks da b*tch!
    Aug 2003
    Somethings wrong, can't be right I know yor all reffering to cellulose but the lacquer on my guitar it's been about 4 days since laquering and on the back where i've leant it against a hard edge it's left the indent on it! The mixture was perfect so I don't know whats going on. Too cold maybe when it was sprayed. Takes longer than 30 minutes be completely dry! Must do.
    This is 2pack mind! so I dunno
    please DrIvE slowly
    Oct 2001
    Herts
    Grale, Mustang, 535i
    2 pack will cure very fast with heat. Air dry you might have had the wrong type of laquer/hardener. Some combinations don't cure very well at room temperature. Even baked it will take a week or so to be fully cured (although it will be OK to polish once cooled from the oven).
    Cellulose will take a few days to cure properly, even when heated. You'd be surprised how long it will take for all of the solvent to flash-off. Don't know how long before it's OK to flat though as I have no direct experience using celly.
    Mike
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Compressor sprayed laquer put on properly should be hard enough after a week in normal temperatures.
    aerosol, usually ends up going on too thick, I wouldn't touch it for a couple of weeks at least.
    Mar 2004
    Nottingham
    Ventora & Yanks
    Rubbing out runs for repainting and final finish polishing are two different things. At the risk of sounding like a complete bodger I use a 2KW electric fire propped up on an old subwoofer box to force dry cellulose to rub out runs or trapped dust in basecoats. 45 minutes and away you go.
    The thing is that the organic solvents in cellulose thinners take a long time to fully evaporate, especially when trapped by several layers of paint and clear lacquer. What happens is that although the paint feels dry and set it does cut back much faster and even if you don’t rub through you have the problem that trapped solvent continues to evaporate and this dulls the finish. This isn’t a great problem if its your own car as you just repolish a week or so later but if you’re in the trade the last thing you want is to return a car to a customer and have it dull out and then the customer isn’t happy.
    I’ve also found that paint cut & polished quickly after application does not have the same depth of gloss as paint cut & polished the following weekend. This is especially true with solid colours. I did a hard top for a mate in gloss black and I couldn’t get a good enough gloss buffing the next day, so bad I went through in a couple of places. So I reprepped and painted and left it a week. Following weekend it came up like glass with almost no effort at all.
