spraying mesh
Results 1 to 17 of 17
Thread: spraying mesh
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    spraying mesh
    Hi,
    As Im respraying my car at the mo..... (cue hint pic of progress
    .....I was going to change the colour of the mesh I have on it (front grill and bumper and rear diffuser) from the aluminium finish it is supplied with, to black.
    Do I just whack on some etching primer followed by black?
    Would you recommend using my compressor or are aerosols going to be ok, afterall it is just mesh - and would you recommend matt black or metallic black- does it really make a difference other than metallic needing laquer and therefore slightly more durable?
    Thanks for your help in advance....
    Chris
    ps- would YOU spray the mesh black or keep it silver (bearing in mind colour of car????????????????????)
    Oct 2003
    manchester
    astra sport 5dr
    Re: spraying mesh
    that colour looks lovely mate, if i were you i'd leave the mesh silver. but if your goin to spray it make sure you give it a lot of coats as it will stonechip badly.
    if your doing it black why not get the mesh powder coated as that will be more durable than paint and it will keep the finish longer than the paint.
    also have you thought about white mesh? it might look good on that colour
    wallet inspector
    hand over your wallet
    MIGWeb User angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Re: spraying mesh
    When I converted my grill to the badgeless version....I used stainless mesh and wacked on some smooth hammerite
    Black looks good but depends on what car I suppose!
    You'll probably get a better finish with the compressor
    Try spraying a spare bit if you have one and offer it up to see
    I did this before sealing the mesh into the grill surround
    Mar 2004
    Nottingham
    Ventora & Yanks
    Re: spraying mesh
    ooh, that looks good. What colour is it?
    if its aluminium mesh you get a special primer for aluminium so I'd use that.
    If its stainless then I think an etch primer will be fine.
    or get them powdercoated for best finish and durability. Shouldn't cost much. I had 4 suspension springs done for £17.
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Re: spraying mesh
    thanks for the comments guys, the colour is Alfa's Azzuro Nuvola and its my first attempt at a respray (and first attempt using a compressor!). I'm not sure if the mesh is stainless or aluminium!!
    And im still not sure if black would look better than silver- I think I may finish it all then roll it out of garage with all trim on and silver mesh and do a poll on here.
    Hadn't thought of white mesh before- I'll go and hunt for some pics to see what it looks like.
    Thanks again
    Chris
    MY ASTRA 3 FOR SALE - UNIQUE SHOW CAR, ONLY now £1295ONO - http://www.migweb.co.uk/forums/showthread.php?t=235022
    Mar 2004
    Nottingham
    Ventora & Yanks
    Re: spraying mesh
    Nice, I know the colour, It looked nicer than that as the Alfa shade can often look "dirty". I thought it might be that mythical Calibra / Cav Turbo special edition blue I've been trying to track down for ages...
    Looks really good, especially for a tricky shade like you've chosen
    Feb 2003
    Swansea, S. Wales
    2001 Astra SXi WIP
    Re: spraying mesh
    Quote Originally Posted by Cesaro
    ...the colour is Alfa's Azzuro Nuvola and its my first attempt at a respray (and first attempt using a compressor!)....
    feck thats amazing...love the colour
    was it expensive/litre?
    ps stick with silver mesh imo
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Re: spraying mesh
    SHOULDN'T BE ENCOURAGING PEOPLE TO KEEP TACKY SILVER MESH. love the black, does hammerite come in spray cans? I can imagine painting it on with a brush would look a mess (would clump up in the holes in theory)
    i've always preffered slats myself:
    please DrIvE slowly
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Re: spraying mesh
    well here is the front bumper with silver mesh........Im not too good with photoshop so can't make it look black as a comparison (without just flood filling the whole area)....
    Feb 2003
    Swansea, S. Wales
    2001 Astra SXi WIP
    Re: spraying mesh
    Quote Originally Posted by BigbaRd
    SHOULDN'T BE ENCOURAGING PEOPLE TO KEEP TACKY SILVER MESH....
    carplan do a special effect pearl paint/laquer, spray that over the silver mesh or replace with ali bars...
    Aug 2003
    Re: spraying mesh
    all u do is desaturate it then adjsut these settings to get black
    Black mesh (and smaller number plate)
    slats (and smaller number plate)
    please DrIvE slowly
    Aug 2003
    Re: spraying mesh
    this might interest you too:
    http://pre-auto.com/sema
    it has metal slats (ali bars like projectjordan says) in the bumper (as long as you d0n't try making it look like an intercooler should look nice):
    please DrIvE slowly
    Feb 2003
    Swansea, S. Wales
    2001 Astra SXi WIP
    Re: spraying mesh
    ....slats (and smaller number plate)
    thats what i'm talking about
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Re: spraying mesh
    I must admit I do like the ali slats, but to be honest I have no more energy or time to do that- maybe later when Im bored of the mesh. Anyway, I think slats in a rear diffuser would look a bit odd.
    I think I'm going to go with black mesh- I like the subtlety on the otherwise 'uncommon' custom kit I got on it - silver looks a bit too ott.
    Big thanks to BigbaRd for the photoshops, cheers m8
    Chris
    Feb 2003
    Swansea, S. Wales
    2001 Astra SXi WIP
    Re: spraying mesh
    perforated ali sheet?
    Aug 2003
    Re: spraying mesh
    thats ok sitting here bored anyway (cant move cause i just had an op on both knees lol)
    please DrIvE slowly
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Re: spraying mesh
    I just used a tin of smooth hammerite I had kicking around
    Couple of light coats brushed on with the mesh placed over a bit of paper to catch drips, then when dry just rub any lumps off the back.
    Have just done another one with the same good results
    Does come in spray cans and would be easier I suppose....not sure what finish it'll give
