Plastic primer
Results 1 to 13 of 13
Thread: Plastic primer
    Aug 2002
    Bucks
    MK4 Van
    Plastic primer
    Hi
    I have this primer i bought awhile ago. OCTORAL PA65
    Was wondering how its used, its like a very thin solvent type.
    Aug 2002
    Bucks
    MK4 Van
    Re: Plastic primer
    Or whats a good way to paint GTE bumper strips? ive tryed with Halfords plastic primer, but it seems i can always pick it back off with my fingernail.
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Re: Plastic primer
    i think their all different, i ordered upol plastic primer which I ain't used yet. Not too sure if that's meant to be mixed either doesn't look like it does, just looks like a spirit!!
    please DrIvE slowly
    Aug 2002
    Bucks
    MK4 Van
    Re: Plastic primer
    it wouldnt be mixed with the paint, would it?
    Aug 2003
    Re: Plastic primer
    nah, it eats into the bumper slightly (metlts it a lil bit for it to grip on and not peel) just i think with some of them you have a catalyst/hardener for it to work, ain't looked at mine propperly to see if their was a hardener.
    please DrIvE slowly
    Aug 2002
    Bucks
    MK4 Van
    Re: Plastic primer
    Cool, Thanks for that, makes sense.
    I will look into if it needs a hardener.
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Re: Plastic primer
    The upol plastic primer I used couple of weeks back was straight out of the tin; ie no thinner. It was 1k celly tho so def no hardnener!
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Re: Plastic primer
    Plastic primer i have used from a spray can hasn't seemed to be much different than usual primer. I did my front bumpers with normal primer and the rear with plastic primer, i know i could easily scratch the paint off with my nail on either bumper( i scratched some of the paint off wiping mud off the bumper). Don't think they would take a pressure washer.
    They ain't got any stone chips yet though.
    Also i think the texture of the bumper caused it to take crap, cus i sprayed m3 mirrors and eyebrows and they came out shiny, and the paint took well, can't even mark it.
    Mar 2004
    Nottingham
    Ventora & Yanks
    Re: Plastic primer
    textured plastic is always trickier than smooth plastic. thats why they sell the stuff that eats into the plastic to kinda etch it.
    Oct 2001
    Herts
    Grale, Mustang, 535i
    Re: Plastic primer
    If it looks like a solvent it is probably a plastic primer containing Chlorinated Poly-olefins which are particularly good for adhesion to Poly-propylene bumpers (which the majority of car bumpers tend to be). It doesn't 'eat in', but forms a chemical bond. The reason it looks like a solvent is because it is about 95-98% solvent. It means that the film thickness is only about 2microns.
    The most important thing about plastic is to prep it properly. Personally I would clean it with a proper plastic cleaner using a scotch pad, wash it off with clean water, leave it to dry and then wipe it over with an anti-static wipe.
    Mike
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Re: Plastic primer
    Yeh I find degreasing the surface really beneficial too.
    MY ASTRA 3 FOR SALE - UNIQUE SHOW CAR, ONLY now £1295ONO - http://www.migweb.co.uk/forums/showthread.php?t=235022
    Aug 2002
    Bucks
    MK4 Van
    Re: Plastic primer
    Right so it should acttually stick with this primer then (better had for £30 for 1L) do i spray it on or can i just brush it on?
    Thanks for the advice.
    Oct 2001
    Herts
    Re: Plastic primer
    Spray it on if you can. The one advantage is that it's really easy to clean your gun afterwards!!!
    Mike
