Epigrip 2-pack epoxy primer
Results 1 to 13 of 13
Thread: Epigrip 2-pack epoxy primer
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Thinking about getting a few litres of this to protect the prepped car till I can afford the paint I got picked out. Don't suppose anyone knows if it's reasonably weathproof? the car will be covered as well (most of it)
    It's called "EPIGRIP H795" and its a 2-pack epoxy (I already have the equipment to spray 2pack) anti-corrosive primer for aluminium and other non-ferrous metal surfaces. That's all I can find out. I've got enoguh of this to give the car an easy 3 coats maybe 4
    please DrIvE slowly
    Mar 2004
    Nottingham
    Ventora & Yanks
    Re: Epigrip 2-pack epoxy primer
    surely non-ferous means "not steel"?
    Aug 2003
    not sure:
    • ferrous [fer·rous || 'ferəs]
    adj. containing iron
    hmmmm much clearer now
    please DrIvE slowly
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    yeh non-ferrous means without iron, but steel has iron in. (Unless its stainless steel)
    Aug 2003
    shame
    please DrIvE slowly
    Oct 2001
    Herts
    Grale, Mustang, 535i
    On the whole, epoxies do tend to give good weather resistance. Your best bet however, is to get some chromated acid etch. You will probably want to use another primer over the top of this (your epoxy?) if you are leaving it for a long time though.
    Mike
    Mar 2004
    Nottingham
    Ventora & Yanks
    I thought stainless steel still had iron in it?
    Oct 2001
    Herts
    Yep, loads. That is what makes it steel. Also has a load of chromium in usually to make it 'stainless'.
    Mike
    Mar 2004
    Nottingham
    Ventora & Yanks
    ta, I thought I was going mad then.
    Non-ferous primer can be used on steel then?
    Aug 2003
    Amazing the knowledge of some miggers on here ain't it (shame about the other half of idiots)
    please DrIvE slowly
    Oct 2001
    Herts
    Quote Originally Posted by alistairk
    It shouldn't be, but I would imagine it would be OK. Especially if used over an etch primer. I don't remember coming across a 'non-ferous' primer before. Might be worth giving the suppliers/manufacturers a quick call to see what they say.
    Mike
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Quote Originally Posted by BigbaRd
    I take it you refer to me in this statement. sorry, honestly thought ss didnt have any in (why its used for sinks etc so it dont rust)
    Aug 2003
    lol no not atall m8t, it wasn't directed at you
    please DrIvE slowly
