which paint is better 2 pack or base and laquer
Results 1 to 19 of 19
Thread: which paint is better 2 pack or base and laquer
    Oct 2003
    england
    i want to get my car painted in a pearl flick paint which paint is better to use in terms of a shiney finish and quality should i use 2 pack or base coat and then few coats of laquer
    friend of mine says 2 pack gets scratched very quickly
    May 2001
    52.26320° -0.81374°
    2.0 16v Astra GTE
    Re: which paint is better 2 pack or base and laquer
    Your friend's advice should be avioded. 2-pack is very durable.
    Which would a pro body-shop spray? 2-pack. Why? Because the finish is far better out of the gun than acrylic or cellulose.
    Veni,Vidi,Scubi
    May 2004
    Birmingham
    Vectra saloon 2.2sri
    the range rovers used a form of 2 pack a long time ago and u couldnt use t - cut unless u wanted to cut it to the primer
    May 2004
    Birmingham
    2 pack is a lot harder than cellulose
    if u have the working environment ie vaccum and dust free with a decent few £k spray gun then by all means do a 2 pack
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    2 Pack Hardener is really dangerous stuff.
    If you are doing it out side you want At LEAST a Charcoal cannister mask.
    Inside you want an Air Fed respirator with Charcoal cannister.
    Cellulose is far less hazardous, and a Charcoal cannister mask will do.
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    is celly harder wearing then?
    May 2004
    Birmingham
    i sprayed my nova with a gravity feed spray gun and small compressor
    http://www.hvweb.co.uk/michael/0522%5F0002%2Ejpg
    http://www.hvweb.co.uk/michael/0522%5F0001%2Ejpg
    cant knock that considering I did most of the spraying outside when the sun was shining and their was no wind
    UK
    Cav turbo and XJR
    2 pack
    Jul 2000
    2 pack is good but WILL kill you if you breathe it in. Never the less, it gives excellent shiney results, without having to G3 it till you're red in the face.
    I felt very sick for a couple of days after spraying a mini without air feed
    BRB
    Sep 2001
    sunny liverpool
    cavEco Zafira
    ephid0r, that looks pretty cool. at some point i will be doing my beetle (can't afford a pro job so it's up the old learning curve again)
    what sort of equipment / materials did you use (a bit more detail please!!)?
    Chiba Sprawl
    The Beetle Restoration Progress
    Try not. Do, or do not - there is no try.
    May 2004
    Birmingham
    just went round the car using 800 wetndry and rubbed the shine off the paint then resprayed
    the spray gun cost like £40 and the compressor cost £40
    i got it from a car paint shop in bromsgrove
    used cutting compound from halfords and t cut with some resin polish to protect the paint
    u just use a lot of elbow grease in rubbing it down and cutting the paint
    just use your original paintwork as primer if spraying same colour otherwise u will need to rub it down even more perhaps to the metal and prime the lot
    with rust i used 150 wetndry, I did a user guide on using filler on roybacer
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    So you used cellulose then? Did you laquer it or just use solid colour?? (ephidor) looks good, how long did it take you to get the shine using cutting compund?
    Sep 2001
    sunny liverpool
    cavEco Zafira
    Quote Originally Posted by ephid0r
    have you got a link for that? (i don't really frequent roybacer)
    Chiba Sprawl
    Jun 2003
    Luton
    Calibra Turbo
    For a pearl flick you'll be using base+laquer anyway, as 2 pack is for solid colours.
    Apr 2002
    at pub when offline.
    GTE 16V mk2 + Cav T
    Quote Originally Posted by Kruger
    Thought it was a 2 pack base coat and 2 pack lacquer anyhows!
    Defo heed the advice about the mask as a min requirement, you can go into a fit at a hint of that gear sometimes. Although ui think they do air drying 2packs now which are a lot safer, although still not that safe.
    Can also be harmful to pets and small children even at a short distance, last thing you need is a neighbour's dog or worse still child getting ill from it, especially if the neighbour clocks what you are upto and points the finger.
    Quote from specialist Ford engine builder -
    "Wish it was Ford that built the XE...thats one great engine..."
    Sep 2003
    scotland
    cav GSI
    2 pack is a paint system ,celly, synthetic are paint systems as well.most modern car finishes are 2 pack you will strugle to find modern colours in celly paint system.99.9%work done at my garage/body shop uses 2 pak system from start to finish.base coat is simply the colour without the shinny stuff in it that gets added later and is harder wearing
    Sep 2002
    Stockport
    Astra VXR-Cav Turbo
    I painted my car with a 2Pak solid colour 2.5litres of it. Didn't use any laquer over the top as there was no need to use it with a solid coulor. Laquer is only needed on mettalic colours. I sanded the whole car down with p400 DA disks (DA- Dual action sander).
    Do this all over then buy some tack rags and go over the whole car before u paint it. Then away u go with the paint, it doesn't really matter how bad ur painting skills are it cud turn out all dull and not a shine on the car, even if u get some runs in it u can still flat the runs out with some p1500's wet and dry paper and then buff it up and it will be perfect.
    When u have painted it u need to Flat it down using the 1500's paper wet, do it all over and wipe it using a rubber block to see where the orange peel still is. Then Buff the whole car with a big grinder and a G-mop on the end of it, And use G3-cutting compound to bring it up like glass. This is what i did on all my cars, heres one of them.
    May 2001
    Essex
    Cavvy SRi 16V
    Its all 2 pak....with any metallic or pearl you will need a base coat, and the lacquer is 2 pak. Vauxhall did experiment with a single coat metallic IIRC on 1990 ish astras and is was ****. Cellulose is only any good if you havent got a respiratot coz it isnt as dangerous as 2 pak, its easier to get hold of and use than 2 pak and its ok for some thinfgs but isnt hard wearing.
    2 pak is the best and only thing to use IMO, for a really shiny finish use good quality lacquer and apply a few good coats, then flat it all back using 2000 grit, then polish it with a cutting compound and polishing machine, that way it will be totally smooth.
    ____________________/\____\o/______________________shark attack!!!
    Jan 2003
    Derbys
    xe engined Cyclone
    Two pack proper goes on thick and hard, no spray issues from the gun, and flat down before it sets. IE it gives a cracking finish from the gun. BUT for the reason stated here, it is dangerous, but that aside it is very , very brittle. stone chips become 10mm dia.
    B
    Dangerous B
