  1. Corsa sport ECU NEEDED!
  2. nova dash swap mk2 to mk1
  3. z20let ecu
  4. wiring wideband up
  5. x16xe corsa
  6. Astra g Key fob problem HELP!!
  7. Astra G 3 rear window seal replacement
  8. 20SEH water pump
  9. Corsa B 1.2 oil and battry light on with no ignition
  10. mk2 cavalier wiring diagram
  11. inline brake compensator valves
  12. Digi dash indicators
  13. Filler neck
  14. anyone got a corsa d haynes manual??
  15. Corsa B rear Coilovers
  16. p code x16xe
  17. rear brakes on a mk4 astra van help please
  18. Brake pads for Rally Nova
  19. slight knocking noise under braking and acceleration 53 Reg Astra 2.2
  20. Anyone ever used MG 4 pots on a corsa??
  21. anyone running 400 bhp plus nstandard valves
  22. Astra mk4 disks and pads same as 1.6 corsa sport
  23. 2002 1.2 Corsa comfort steering problem
  24. can you take top part of gear stick off?
  25. Mk3 cav rear trailing arms on a mk3 Astra ?
  26. C20LET Air Flow metter
  27. That was ****ed then... (Calibra rear subframe bushes)
  28. Digi dash rev counter help
  29. Brake Fluid????
  30. Vauxhall corsa non starter
  31. Corsa C 1.8 SRi Alarm Problem
  32. Mk3 Astra Suspension Choices
  33. cdx mk 2 cav , blowing white smoke through interior vents
  34. Corsa B C20XE speedo not working
  35. will a calibra dash/engine bay loom fit in a mk3 cavalier?
  36. wiring 2.0 8v to corsa
  37. Calibra Ignition Relay?
  38. mini shocks in corsa b ??
  39. Heated setas into 2001 astra sportive?
  40. corsa b, x14xe ecu fault??
  41. Replacement stalks for a Nova?
  42. Astra mk3 wiring diagram scans
  43. mk3 astra xe wiring problem help plz
  44. Sri cavalier indicator comes on itself..
  45. 2000 corsa b 1.2 sxi redtop help!!
  46. Hiss on brake servo vac Z20LEH Corsa C
  47. astra g 1.7dti (temperate gauge, outside temperate on console and heater problem
  48. Heater Control Panel Lights - Corsa B
  49. Corsa Clock Block Connector
  50. Vectra 2.2 Sri Y Reg Power Steering Issue
  51. rear springs and MOT
  52. Astra MK3 1.4 single point with Error codes 21 and 35 but no problems
  53. My Driver's Heated seat not working why?
  54. whre does the courtenay powercap hose connect to?
  55. Rear springs on astra H
  56. Electric window help - Corsa B
  57. no power to fuel pump
  58. Hubs
  59. astra twintop headlamp
  60. Electric Steering Pumps
  61. Caliper identification
  62. Vectra C Lowering
  63. rear suspension struts
  64. Corsa GSI C20XE Conversion - how to keep ABS working
  65. corsa d heater blower
  66. Astra 1.4 mk4 driveshaft same as 1.4 mk3?
  67. Astra G fan direction
  68. help grinding noise
  69. Working out spring rates for coilovers
  70. Will these brake fittings seal and work
  71. Found this Web site with vaux problem solving
  72. What suspsension fits vectra C
  73. Mk3 Astra Suspension height questions
  74. Broken Mk3 Astra Top Mount
  75. mk3 astra conversion
  76. mk4 astra bonnet strut problems
  77. what size fuel lines do i need?
  78. Astra G 2.2 air con fan running with aircon not on.
  79. Corsa C rear spring swap
  80. Astra Mk3 1.4 Heater Matrix
  81. Indiglo dials assistance required..... Dom/Andy K?.
  82. 1994 Corsa, Cooling fan not working
  83. Tyres wearing on the inside
  84. swapping Cally T strut for Vectra b units (advised, help and pic needed)
  85. Corsa XE Electric Speeedo
  86. egr valve cdti
  87. Electric powered hydrolic power steering pump
  88. How to align Astra doors?
  89. Zafira gsi coilover help
  90. Help plz wiring for Zlet in to corsa c Sxi
  91. P0130 & P0135 Vectra 2.0ltr
  92. Corsa easytronic starting problems
  93. cesaro center caps
  94. Astra mk4 Gsi clocks in sport
  95. mfd not workin properly
  96. Rear shoes wearing unevenly
  97. Tigra handling problems
  98. Picture of astra mk3 subframes
  99. Vauxhall Astra G Coupe Official 888 Suspension Shocks
  100. Astra mk3 rear beam bushes hole
  101. astra g power steering
  102. Steering wheel boss splines
  103. vectra b immobiliser
  104. X16XE knock sensor
  105. Removing and replacing Corsa B speedo?
  106. incar lighter
  107. how to stengthen thr bulk head on a mk2 cav convertible
  108. How can I improve stabiliser linkage? Mk2 Astra
  109. Lambda question 2.0 xev
  110. Mk3 astra Complete 5-stud Conversion guide
  111. innovate wideband problem
  112. Tips for c20let rocker gasket
  113. corsa b chassis leg - chassis leg (width)
  114. Bleed nipple size
  115. Strange scraping noise in low revs in every gear :S
  116. Socket size on a Astra 1.9 td drive shaft?
  117. Astra MK3 Wishbones bolts
  118. F28 gearbox / speedo issue
  119. alternator replaced
  120. C20XE into Mini ECU help
  121. Clunky steering...
  122. Will this Calibra steering wheel boss cancel the indicators?
  123. Tigra 16xe airbag info?
  124. No brake lights on corsa
  125. Astra G front pads change
  126. Need help on measuring up for rotors and bells
  127. In car bonnet catch snapped corsa B
  128. Astra mk3 N/S/F Caliper scoring disc
  129. a couple of mk6 astra questions
  130. Can I remove this part (Cav/Cali 4x4)
  131. 22 Spline CVs cheap ?
  132. Cv joint/ wheel bearing! C20XE Corsa
  133. corsa b20xe brakes?
  134. x16xe conversion
  135. Corsa B speedo not working?
  136. X20XEV Alternator fit 1.2 16V?
  137. car pneumatic jacks
  138. Epas into Corsa B?
  139. Desperate need of help for my Calibra speedo issues
  140. Brake pedal quite soft
  141. Coilover Advice Needed
  142. Looking for an air compressor, What's best???
  143. corsa c speedo how does it work with engine conversion?
  144. corsa b wire colour for the interior lights
  145. corsa b how do i remove the speedo clear plastic cover
  146. Limp mode issue on vectra cdti since bad fuel ( no faults codes) Im lost??
  147. corsa digi dash help
  148. Astra Mk 3 rear disc conversion.
  149. What can cause a hard brake pedal?
  150. best place to get z20let remapped
  151. Fuel pump ground wire
  152. Corsa b bonnet raisers
  153. Signum rear end rattle Argh!!!
  154. Brake servo vac hose size
  155. What do i need digi dash
  156. KMS ECU programming/connection
  157. Egr valve problem
  158. Corsa B Brake upgrades
  159. Corsa B compatible speedo
  160. CorsaB 93 c20xe suspension?
  161. Corsa B Heater Problem
  162. astra mk3 handbrake adjustment
  163. Brake lights
  164. fault codes. vectra C.
  165. how do i do falt codes reading on a vectra c
  166. powerflex -ing my '96 cally turbo
  167. 20seh starter wiring
  168. Astra mk3 brakes going to the floor
  169. megajolt cranking advance
  170. HID problem
  171. when doing engine conversion electrics....
  172. car immobilized
  173. 1.7 dti mapping horror!!!......
  174. M32 gearbox into a Corsa C
  175. Vectra/Cavalier GSI digital tacho problem,need help ....
  176. Airbag Code
  177. c20xe 2.8 motronic
  178. Removing abs unit for track day use
  179. Cruise control help
  180. 1.9 CDTi EGR Removal
  181. vectra b c20let
  182. Calibra rear shock mount diagram please :)
  183. vectra b missfire
  184. Rear Drum - Hub Nut size? corsa b 1.0
  185. parts quiz astra gte 16v
  186. wiring warning lights up on digi dash
  187. Coupe Fuse 20 (windows) keeps blowing
  188. zafira odometer/trip display light malfunction.
  189. Will these calipers clear 17'' wheels?
  190. C20LET Motronic Ignition Management
  191. Fitting 16v brakes on my nova
  192. Astra Gsi Mk3 Intercooler Questions
  193. 2005 Tigra 1.4 - Heater control panel 'dead'
  194. C25 XE into MK2 GTE Electrical issues
  195. How to remove Corsa gsi front bumper
  196. Calibra turbo Front Bake Disc. - help
  197. help using feeler gauge
  198. Car pulls to the right?
  199. Factory alarm & power windows
  200. astra gte digi dash (oil level) where to connect
  201. Bleeding ABS brakes - Mk3 Cav
  202. speedo on r25-r28
  203. size of brakes 1.4 and 1.6 corsa?
  204. spa gauge help
  205. C20LET not starting, could this be the problem, look at image
  206. Cavy Windows
  207. Code 27
  208. C20xe starter
  209. MBA9A4 or DTA S40 Pro?
  210. code po410+
  211. will nova front springs fit a mk1 astra?
  212. Negative battery lead help needed ASAP please
  213. Ecotec engine noise
  214. Ebay Coilovers?
  215. Can you get a polyurethane version of this Calibra bush?
  216. Women and weather = broken car
  217. battery cutting out on Corsa B!
  218. Will the C20LET start without the mini loom
  219. Slimline fans
  220. 3cyld corsa c no throttle ??
  221. Clocks Mileage
  222. Corsa GSI Engine Mount HELP PLEASE!!!
  223. Ron plug c20let
  224. heated seats
  225. Tracking Troubleshooting
  226. Vectra Rear Windows wiring diagram
  227. Overcharging alternator
  228. Astra coupe/3door suspension
  229. Loss of power to dashboard-loose earth connection?
  230. Corsa C/Later style caliper swapping
  231. em light on corsa b 1.2 16v ecotec
  232. Fault 49 high voltage
  233. Vauxhall nova top fire wall/wiper motor re position (project)
  234. Water inside car still!
  235. opcom
  236. digi dash x16xe ???
  237. how to wire z20let in astra van 1.6
  238. Corsa b 1.5TD Fault please HELP
  239. Bleeding Issue After Fitting Vec V6 Brakes
  240. OBDport wiring mk4 Astra c20let
  241. Corsa b, what do i need to make it electic power sterring
  242. Caliper fitments...
  243. LOW VOLTS! 11.9V with engine running, 11.1V with headlights and heaters
  244. Anyone dismantle a MkIV Astra hub?
  245. Rose joint arrangement and sizes?
  246. Calibra rear subframe strengthening (damper mounting point)
  247. mk3 astra subframe bolt problem
  248. Mk4 astra coupe wing mirror.
  249. Eratic idle (X14XE)
  250. Rev counter Only revving up to 4000 rpm?
