- Front Windows Playing Up
- faulty distributor caused car to stall?
- Astra mk3 handbrake stuck on - crunch!
- Astra TD....Were does this pipe go???
- Handbrake/Warning Light keeps coming on
- digi dash red switch on top and transducer?
- Rear Windscreen washer problemo
- will v6 brakes fit behind astra gsi rims?
- Tigra Suspension Change
- Astra Coupe Millage Not Displaying Or Full Beam Wont Work???? :s
- brake lines
- what to do
- Ahh, but which CV boots...
- Longer rear handbrake shoe pins, do they exist? Banana?
- couple of questions
- how do i turn the service inspection light out on a mk4 astra?
- wiring diagram for corsa c mfd?
- Nova Gsi Do We Realy Need The Exhust Heat Sheild?
- corsa gsi inner wheel arch
- lights not working
- need help badly lol
- any suggestions ? .....
- 2.0 8v omega's
- boot lifter and solenoid
- little ends
- Removing underseal
- Lowering front Astra Mk3
- Astra wheel bearing kit - which one?
- help needed please
- fao dom/electronic bods
- temperture needle
- Can someone in here help wit this?
- Running Problems
- FAO: Online Autosport MegaGas susp kit owners
- Tigra side skirts
- Rev counter
- No Power steering Can i up grade
- sri problem
- Corsa Problems
- Poxy Weber 32/34
- Cruise control?
- Help me identify fuses please (pic...)
- 5 stud conversion for mk3 astra gsi
- Astra Coupe Fault Codes
- few question..
- 6.5j and et42 better than 7j and et49?
- Ive read my fault codes 13 + 38 ???
- Silver box behind glove compartment in v6 calibra??
- limit
- vectra cruise control cable length
- What to Get
- do temp guages in dash break?
- C/L not working on a mk3 astra
- I have broken my rear electric windows
- Is this the traction control ecu on (M)Calibra V6?
- idle idling!
- Electric SuperCharger!!!!
- Can Someone Work Out My Compression?
- my V6 is slow, please help!
- Corsa vs Tigra Steering Racks
- Is this normal?
- meaning of a DTC code..
- I'm sure somone will know......
- shift point
- "My car topped out at....
- alloy wheel silver colour code?
- is it safe.......
- Astra GSi Immobiliser HELP!!!
- A persuit of perfection
- close to freeking out...
- Odometer Button
- 3.0v6 into vectra
- hello once again
- Swapping wiper arms
- Tas eccentric top mounts?
- Few GSi queries
- Magnex or Janspeed system?
- Yellow connector
- anybody no that size
- hello again
- Bleeding brakes
- Chasis Repair
- Omega Electrics ?
- Wilwood brake kits nova
- errrr wtf>?
- wilwood 4 pots kit
- K & N Panel filter. Do they work?
- wheel bearing question
- Quick wheel question?
- ECU light on!!!
- Recent Rolling Road Session
- new nos kit, no instructions
- Spare key
- Lower'd Cav
- Someone with EPC?
- Brown Gunk In Water
- Rear Brake Problem
- need some new front brakes..
- Will this work?
- CV joint help!
- Attaching rear view mirror
- ATE Brake Sensors
- 1.6 gls dash board
- 308mm brake pads
- Ticking noise from wheel
- Are Nova 1.2 hubs the same as...
- digital dash speedo
- Techy Qustion
- Electric speedo question...
- another manta question
- wheel fitament question (manta owners)
- spluttering gsi
- Help
- Quick Cav question...
- Rear Disc HELP!
- Tech2 question - VAUXHALL EMPLOYEES
- reverse to first
- whats faster????
- oops.........
- Bit of suspension help needed please
- traders on here?
- Golf Offset
- Quick question
- Awful smell coming out of the vents :P
- 2ltr 8v supercharge Question
- V6 brake question/problem and what new pads should I get... :D
- Golf Wheel Offset
- Rear Disc Conversions
- Is the idle supposed to drop dramatically when the fan kicks in?....
- Cav intake probelms
- Cav diagnostic plug
- loosing coolant
- How much compression should a E16SE have?
- Astra F window mechanism
- Fault Code 28
- Ok, what next ?
- Front suspention struts loose
- digi dash display
- some vectra upgrade questions!!!!
- mpi or spi
- anyone put 4pot calipers on the rear brakes?
- twin 40s peugoet
- Fitting Of:
- Vauxhall Specialists
- speedo replacement
- What will I need to get 12s... N/A only...
- trusted rollin roads in scotland
- Nova 2.0 Coversion
- PS2 Laser?
- General Help Needed
- Help Needed
- Tapping
- i have just replaced handbrake cable ...
- Help with putting v6 into corsa
- Recon Aircon compressors ??
- twin webers question
- mk3 top mounts?
- Atra GSi few problems
- tracking and alingment
- Anyone know their VW Golfs?
- ARP Rod Bolts
- Which 2l 8v in mk3 astra sri?
- removing dash surround on Omega
- wheel bearing mk3 cav
- what coul it be
- Cavalier REAR shock absorber query
- Help Smocking Badly
- Bit of a flat spot
- Improving Astra Performance
- Corsa lower tie-bar brackets
- Mk3 Astra Sport Air Con, How Should it work?
- Oh! No! I'm trapped!
- Oxygen Sensor
- C Spanner size for Bilstein inserts?
- M12 x 1.5 or 1.75 for Track Rod End Balljoint?
- WHAT'S this part called ??
- weber 32/34 choke
- parking/side light removal
- Changing front brakes...HELP!
- nova 2.0 16v not starting (electrical)
- gte alternator
- Prepare to Laugh
- Oh no - What have i done??
- will it work
- Corsa GSI Sussy's on A Nova GSI
- MOT experts - Mine just failed emissions
- astra abs sensors
- Astra GSi's trip computer.
- Lowering a corsa
- What happens to brake fluid as it gets old?
- electric problem
- quick question nova clocks
- Purge kit
- Hot to get the bearings off the diff ?
- few problems (V6 Conversion)
- what bit do i cut???
- Rod Bolts, Rings and Bearing shells
- What parts do I need?
- A few questions about my Calibra
- Astra GTE Warning Light Panel
- Plastic windows
- What exactly do you need to..........
- Running in with new big end bearings
- 4 pot caliper question
- Trip Comp in an mk4 astra, is it possible????
- quick airbag question
- External Temp Sensor
- Prob With Rev Meter
- Corsa SXI Steering
- MK3 Astra leccy windows
- interior light has stopped working
- Suspension
- leccy window help???
- SUSPENSION KIT corsa b
- Nova/ Corsa front steering knuckles
- Astra Mk4 1.7TD problem
- Speedo/Revs dont work Vectra V6 sri
- 60 mm Drop
- How to fit brake disks & Pads to corsa B
- Brake shoes
- please help me!!!!
- nooby electrical question (corsa)
- anyone nr watford want to earn £150 fitin auto box on my elite?
- OZ Super T WRC Wheels
- Lost my hanze manual
- rolling road's
- Another Digital Dash Post........
- Flushing coolant...
- anyone can tell me where
- electrical fault
- Electrics Problem
- help needed please(shot peening)
- 3 alternators in 3 months?
- What fuse is for the stereo, Vauxhall Astra 2003 2.2ltr?
- How accurate are rolling roads?
- Bonnet release?
- how fast does the cars cooling fan spin?
- Brake bias
- part co phone number/website?
- calibra rear brake back plates
- V6 Wiring Problem - PLEASE HELP!!!!!!
- speed from rpm
- tuning
- Whats hot about MSD?
- astra g lower strut brace
- Astra G front windows issue
- speedo needle
- Carlton digi dash rev counter
- rear brakes locking up,before fronts,please advise
- Wishbone change, best balljoint splitter?
