- Nova 2.0 Coversion
- PS2 Laser?
- General Help Needed
- Help Needed
- Tapping
- i have just replaced handbrake cable ...
- Help with putting v6 into corsa
- Recon Aircon compressors ??
- twin webers question
- mk3 top mounts?
- Atra GSi few problems
- tracking and alingment
- Anyone know their VW Golfs?
- ARP Rod Bolts
- Which 2l 8v in mk3 astra sri?
- removing dash surround on Omega
- wheel bearing mk3 cav
- what coul it be
- Cavalier REAR shock absorber query
- Help Smocking Badly
- Bit of a flat spot
- Improving Astra Performance
- Corsa lower tie-bar brackets
- Mk3 Astra Sport Air Con, How Should it work?
- Oh! No! I'm trapped!
- Oxygen Sensor
- C Spanner size for Bilstein inserts?
- M12 x 1.5 or 1.75 for Track Rod End Balljoint?
- WHAT'S this part called ??
- weber 32/34 choke
- parking/side light removal
- Changing front brakes...HELP!
- nova 2.0 16v not starting (electrical)
- gte alternator
- Prepare to Laugh
- Oh no - What have i done??
- will it work
- Corsa GSI Sussy's on A Nova GSI
- MOT experts - Mine just failed emissions
- astra abs sensors
- Astra GSi's trip computer.
- Lowering a corsa
- What happens to brake fluid as it gets old?
- electric problem
- quick question nova clocks
- Purge kit
- Hot to get the bearings off the diff ?
- few problems (V6 Conversion)
- what bit do i cut???
- Rod Bolts, Rings and Bearing shells
- What parts do I need?
- A few questions about my Calibra
- Astra GTE Warning Light Panel
- Plastic windows
- What exactly do you need to..........
- Running in with new big end bearings
- 4 pot caliper question
- Trip Comp in an mk4 astra, is it possible????
- quick airbag question
- External Temp Sensor
- Prob With Rev Meter
- Corsa SXI Steering
- MK3 Astra leccy windows
- interior light has stopped working
- Suspension
- leccy window help???
- SUSPENSION KIT corsa b
- Nova/ Corsa front steering knuckles
- Astra Mk4 1.7TD problem
- Speedo/Revs dont work Vectra V6 sri
- 60 mm Drop
- How to fit brake disks & Pads to corsa B
- Brake shoes
- please help me!!!!
- nooby electrical question (corsa)
- anyone nr watford want to earn £150 fitin auto box on my elite?
- OZ Super T WRC Wheels
- Lost my hanze manual
- rolling road's
- Another Digital Dash Post........
- Flushing coolant...
- anyone can tell me where
- electrical fault
- Electrics Problem
- help needed please(shot peening)
- 3 alternators in 3 months?
- What fuse is for the stereo, Vauxhall Astra 2003 2.2ltr?
- How accurate are rolling roads?
- Bonnet release?
- how fast does the cars cooling fan spin?
- Brake bias
- part co phone number/website?
- calibra rear brake back plates
- V6 Wiring Problem - PLEASE HELP!!!!!!
- speed from rpm
- tuning
- Whats hot about MSD?
- astra g lower strut brace
- Astra G front windows issue
- speedo needle
- Carlton digi dash rev counter
- rear brakes locking up,before fronts,please advise
- Wishbone change, best balljoint splitter?
- (Crypton) GM test card asc1
- V6 into a Mk3 Astra?
- please can some one tell me.
- Annoying Knock
- wire up fans
- Tips on removing a stubborn bolt?
- Nova rear Drums
- Astra MK3 Steering nuckle..
- Need a tune up
- *URGENT REQUEST* Cav Dizzy
- Locking keyfob thing!
- Help Asap Vic To Be Carried Out
- Rebuilding front end, help!
- DIY flamer kit
- Failed MOT-need some advice(any MOT testers on here?)
- Springs
- Renault Laguna Starting Progkems
- Stuttering cav sri 8v.
- How do you dismantle a cv joint for boot removal
- HELP S.M.V (Save my Veccy)
- Fog Lights help please!!!!!!
- alarm queries
- Rough running Nova GSi - any ideas?
- Newbie Question
- Boost problems under load
- Suspension Upgrades.
- Corsa EM Light
- Cav Sri 8v's????
- Kadett GSI 16V stalls ramdomly!
- Those coolant filler cap with sensors on Astra GSi's
- Grinding noise at mid revs.
- Koni Confusion... RSK - SSK
- Well, its stainless...what make?
- Warning
- is kseal any good?
- Battery
- Help Me Please!!!!
- brakes locking help please,sorry its a nissan
- Arp Rod Bolts
- Dodgy Brakes?
- power steering pump fitting??
- ecu code
- What boost can i run ??
- Calibra V6 into Astra
- Astra Mk4 14i 16v LS pollen filter
- c30se
- Leakdown test results
- Mk4 Astras
- idle probs
- Well i finally found after....
- which engines go straight in...
- how to adjust suspension (konis)
- Wiring Problem
- pipes on sr nova?????
- cleaning perspex windows
- is this repairable?
- sounding good
- fuse19 how many amps?
- digital air temp gauge
- How do you make a MK2 astra handle well?
- mk2 cav inner cvjs
- help needed urgently
- Just got my Astra back on the road and now this!
- 5 Stud conversion...
- Help please
- corsa battery not charging
- Where did my post go?
- Astra 14i 16v Vreg under seat sensor?
- Steering arm rod..?
- New big end bearings?
- is this possible
- ICV question
- Nova GTE Running s**t! Help Plz
- EPC help
- is this a good idea
- Brake force/pedal question.
- too hot
- cant get my nova to run
- corsa rev counter
- Mt 215 Tb's
- Speaking of disc conversions..........
- who does variable pressure regulators other than fse
- Rear Disc Conversion PROBLEMS!
- :: PLEASE HELP :: rev counter interference - alternator?
- blown fuse??
- Speedo Question(MK4 Astra)
- Astra 1.6 CDX immobiliser/CL probs...
- GTE digi dash problem
- central locking control module
- please help me with this one please
- f13 differences - Wide / Close
- V6 Omega Overheat Problems
- 16i astra into 14i corsa
- 1995 cav cdx spongy brakes...
- anyone fitted on eof these?
- Track rod ends help
- Idle problem
- Carlton: elcectric rear windows & door lock probelms..
- Vectra 3.2 V6 GSI
- V6 Wiring to Astra GSi
- ecu fault codes???
- nova gsi speedo cable????
- finding handbrake cable online ??
- Check these out
- Uh oh
- immobiliser wiring on 1.6 16v
- how much 2 get 5 stud discs redrilled
- how much is a knock sensor??
- How Low Can You Go?
- Nova Big hub bearings?
- Cally Sunroof How 2?
- astra mk2 & mk3 front struts
- how
- Mileage Counter non illumination
- Central Locking to REMOTE Central Locking...
- how much............
- who re-drills disks? & much??
- Nova f13 help required
- Nova - 4wd ?
- 4WD Nova
- Can a 4wd run on 2wd? (fuse 19)
- Will a strutbrace of a astra gte fit the lowerspec models (merits etc)???
- Rear Elec Windows/Mirrors
- Vx220 questions
- what reg car would i find
- Air Bag
- making GRP moulds for parts?
- need to know please
- wiring question
- Nova GTE start problem
- Anyone with TIS CD
- fault codes
- still smokin after h/g
- Ultra Sonic Injectior Cleaning
- Part number please
- Arb Spacers?
- Brake Problems...Spongey pedal
- buying a 2nd hand zafira...couple of niggles
- Astra Gsi 2.2 conversion?
- Flat spots through the rev range..
- reving up another problem
- info on gt25,gt28,gt30
- Toque Curves
- quik question
- Electric Mirror Upgrade
- Any One
- corsa central locking
