  1. Someone Please Help
  2. ecu wont clear the fault codes????
  3. Urgent Assistance Required (vectra 2 Ltr Eco-tec)
  4. where does the lamda senser go? (bad spelling)
  5. Trip computer
  6. any one know cost
  7. backfire when cold?
  8. How to wire a fan override switch
  9. 20 SER fast idle???
  10. What's happened to my brakes?
  11. Question about front TOWBAR on a corsa B
  12. 57i on vec gsi
  13. How does a jig work?
  14. speedo's stopped working....
  15. Rev Meter !!!!!
  16. Cav MKIII error 92
  17. Parts Prices
  18. speedo behaving oddly
  19. Peugeot 405 td tuning
  20. Fanny switch
  21. 1.5TD questions?
  22. Help!!! I'm locked out
  23. Basic Car Check Info
  24. Dizzy for 45s
  25. Eps
  26. how easy is it to change bulbs on centre console
  27. maybe this thread should be in the humour section
  28. Solid or Vented Discs??
  29. fooking error codes !!!!
  30. Astra Mk2 GTE 16v Strut Brace
  31. Which suspension ??
  32. V6's in MK2 astras
  33. Air con questions
  34. info needed, astra gte
  35. tigra/corsa clocks
  36. FSE PBV Codes
  37. Ignition Barrel Replacement
  38. Corsa sunroof
  39. windscreen
  40. wiring harness
  41. Astra GSi - What's that plug under the boot for?
  42. ABS coming on
  43. v6 calibra auto....
  44. Astra gsi rear axle HELP
  45. Trip computer
  46. Digi Dash into Corsa b
  47. Removing reservior from mk2 Astra GTE master cylinder....
  48. Calibra V6 onto Mk2 Astra
  49. Stalling problem (Eco crap)
  50. removing servo on a mk2 astra
  51. front brakes creaking
  52. No Middle Box??
  53. leccy sunroof
  54. if the tracking is out......
  55. WTF is with my ABS?
  56. Brake disc sizes...HELP!!
  57. immobiliser....
  58. help
  59. BRAKES!!! Vectra v6 sri...
  60. Black Distributer Cover
  61. urgent cars dead
  62. No brakes!
  63. V8 in a Calibra?
  64. i want the softest suspension for astra mk3? what is it?
  65. Bilstein Sprintline > Calibra
  66. over heating
  67. Lmao
  68. PAS Rack on Mk3 Astra GSi...
  69. Why can't I post a thread in for sale?
  70. Wiring in Small LED's ???
  71. V6 on TBE's ?
  72. doh, my sensor plugs dont fit :( (pics)
  73. Digi dash miles???
  74. MBE 941 Config File
  75. ABS code 16 .
  76. 3.0v6 into cav...
  77. temp problem
  78. hall sensor code
  79. Starting Problems
  80. astra mpi
  81. Rust Problem!
  82. gsi trip computer problems
  83. Metal on metal sound on full lock...?!
  84. central locking not working
  85. Brakes dont work!!!!!
  86. SPI to MPI
  87. ECU light comes on ??.
  88. Cruise Control
  89. Boost gauge issue
  90. fitted digi dash now have problems.
  91. Cutting cross member?
  92. is a volt gauge,a good idea
  93. Digidash speedo calibration?
  94. cally upgrades
  95. MK4 Cabby roof small problem with it sticking
  96. problem with bleeding brakes off
  97. Wireing Diagram!
  98. distributor required?
  99. any good
  100. GTE clocks in a GSi
  101. Rear discs upgrade.
  102. Error code help please
  103. Which one..
  104. Front Windows Playing Up
  105. faulty distributor caused car to stall?
  106. Astra mk3 handbrake stuck on - crunch!
  107. Astra TD....Were does this pipe go???
  108. Handbrake/Warning Light keeps coming on
  109. digi dash red switch on top and transducer?
  110. Rear Windscreen washer problemo
  111. will v6 brakes fit behind astra gsi rims?
  112. Tigra Suspension Change
  113. Astra Coupe Millage Not Displaying Or Full Beam Wont Work???? :s
  114. brake lines
  115. what to do
  116. Ahh, but which CV boots...
  117. Longer rear handbrake shoe pins, do they exist? Banana?
  118. couple of questions
  119. how do i turn the service inspection light out on a mk4 astra?
  120. wiring diagram for corsa c mfd?
  121. Nova Gsi Do We Realy Need The Exhust Heat Sheild?
  122. corsa gsi inner wheel arch
  123. lights not working
  124. need help badly lol
  125. any suggestions ? .....
  126. 2.0 8v omega's
  127. boot lifter and solenoid
  128. little ends
  129. Removing underseal
  130. Lowering front Astra Mk3
  131. Astra wheel bearing kit - which one?
  132. help needed please
  133. fao dom/electronic bods
  134. temperture needle
  135. Can someone in here help wit this?
  136. Running Problems
  137. FAO: Online Autosport MegaGas susp kit owners
  138. Tigra side skirts
  139. Rev counter
  140. No Power steering Can i up grade
  141. sri problem
  142. Corsa Problems
  143. Poxy Weber 32/34
  144. Cruise control?
  145. Help me identify fuses please (pic...)
  146. 5 stud conversion for mk3 astra gsi
  147. Astra Coupe Fault Codes
  148. few question..
  149. 6.5j and et42 better than 7j and et49?
  150. Ive read my fault codes 13 + 38 ???
  151. Silver box behind glove compartment in v6 calibra??
  152. limit
  153. vectra cruise control cable length
  154. What to Get
  155. do temp guages in dash break?
  156. C/L not working on a mk3 astra
  157. I have broken my rear electric windows
  158. Is this the traction control ecu on (M)Calibra V6?
  159. idle idling!
  160. Electric SuperCharger!!!!
  161. Can Someone Work Out My Compression?
  162. my V6 is slow, please help!
  163. Corsa vs Tigra Steering Racks
  164. Is this normal?
  165. meaning of a DTC code..
  166. I'm sure somone will know......
  167. shift point
  168. "My car topped out at....
  169. alloy wheel silver colour code?
  170. is it safe.......
  171. Astra GSi Immobiliser HELP!!!
  172. A persuit of perfection
  173. close to freeking out...
  174. Odometer Button
  175. 3.0v6 into vectra
  176. hello once again
  177. Swapping wiper arms
  178. Tas eccentric top mounts?
  179. Few GSi queries
  180. Magnex or Janspeed system?
  181. Yellow connector
  182. anybody no that size
  183. hello again
  184. Bleeding brakes
  185. Chasis Repair
  186. Omega Electrics ?
  187. Wilwood brake kits nova
  188. errrr wtf>?
  189. wilwood 4 pots kit
  190. K & N Panel filter. Do they work?
  191. wheel bearing question
  192. Quick wheel question?
  193. ECU light on!!!
  194. Recent Rolling Road Session
  195. new nos kit, no instructions
  196. Spare key
  197. Lower'd Cav
  198. Someone with EPC?
  199. Brown Gunk In Water
  200. Rear Brake Problem
  201. need some new front brakes..
  202. Will this work?
  203. CV joint help!
  204. Attaching rear view mirror
  205. ATE Brake Sensors
  206. 1.6 gls dash board
  207. 308mm brake pads
  208. Ticking noise from wheel
  209. Are Nova 1.2 hubs the same as...
  210. digital dash speedo
  211. Techy Qustion
  212. Electric speedo question...
  213. another manta question
  214. wheel fitament question (manta owners)
  215. spluttering gsi
  216. Help
  217. Quick Cav question...
  218. Rear Disc HELP!
  219. Tech2 question - VAUXHALL EMPLOYEES
  220. reverse to first
  221. whats faster????
  222. oops.........
  223. Bit of suspension help needed please
  224. traders on here?
  225. Golf Offset
  226. Quick question
  227. Awful smell coming out of the vents :P
  228. 2ltr 8v supercharge Question
  229. V6 brake question/problem and what new pads should I get... :D
  230. Golf Wheel Offset
  231. Rear Disc Conversions
  232. Is the idle supposed to drop dramatically when the fan kicks in?....
  233. Cav intake probelms
  234. Cav diagnostic plug
  235. loosing coolant
  236. How much compression should a E16SE have?
  237. Astra F window mechanism
  238. Fault Code 28
  239. Ok, what next ?
  240. Front suspention struts loose
  241. digi dash display
  242. some vectra upgrade questions!!!!
  243. mpi or spi
  244. anyone put 4pot calipers on the rear brakes?
  245. twin 40s peugoet
  246. Fitting Of:
  247. Vauxhall Specialists
  248. speedo replacement
  249. What will I need to get 12s... N/A only...
  250. trusted rollin roads in scotland
