- calibra wont turn over
- Black Plugs?
- hijack!!
- stand alone managment help
- advice please .
- miles
- Electrics on Cav
- Rev problem! Help!
- Cavalier gsi wanted - south wales
- Vectra service light
- 1995 Cavalier 1.7TD Help needed
- wet day
- sectional drawing thru a 5stud hub
- Back Pressure
- primary ignition switch Where is it? Help!
- Reverse Lights
- A quick and easy one this!!
- 'One Touch' Electric Windows
- Fitting DV now got PROBS!!
- Rear Lights not working......Help
- Need Info
- panel filter
- compression test results
- Vectra Key -- new one not working?
- Corsa GSi brakes onto Nova
- Close Ratio Box
- Bigger Servo ? informations needed
- Removing the standard alarm on a Calibra V6
- mpg
- Vectra B trip computer
- Mk 4 speedo inop
- Porting Kits...best one??
- Power steering
- Has anyone fitted aftermarket gauges in the center pod
- how much 4 this little lot?shoudd i use genuine parts?
- Stalling at every junction
- Vectra v6 computer
- PLEASE HELP- Tapping!!
- 2002 New Shape Vectra
- 2 rad fans ON CALLY.??
- brakes upgrade info
- Abs teeth on corsa c
- will these wheels
- quick help needed please
- gsi rear axles?? same or not?
- Corsa/Nova Rear wheel bearing
- removing corsa clocks
- 2.0 8v air flow meter?
- Daewoo Nexia / Vauxhall Astra Windscreens - Same?
- Removing Antenna on the roof of a Calibra
- zorst wrap?
- Vectra gone titsup
- Tuning Tips + Hints??????????????
- Removing heater matrix with A/C from Calibra
- battery flat car dead locked
- Low / erratic idle speed
- Rear fog lamp fuse keep blowing.
- fooking ecu codes
- HT lead and Dizzy cap question
- v6 brakes on astra
- gen on brakes
- ABS/TC lights on and speedo not working
- Emission Control
- Suspension query...
- Remote Central locking not working
- quick price guide....
- Knock noise when pulling away
- technical data links
- quick tyre size question!!
- ABS kicking in when it shoudln't :(
- Dead sunroof motor?
- Here we go................im a virgin though.
- waht innner CV joints do i need
- Wash/wiper Stalk Replacment-how?????
- Strut brace mounting points?
- Increasing boost via actuator?
- Calling V6 experts
- Vectra brakes ABS compatibility
- Cavalier Rust/nut Prob
- Possible defect on some F1 GSD2's
- Beats me, what can it be?
- Braking system pressurising problems...part 2 :-(
- braided hoses with wilwood
- Boosting problems
- Enclosed Induc Kit APIRO "DIAVOLO"
- Drums!
- ABS makes brakes poo! Cav T
- alarm doen't work
- Went to fill up the astra today and...
- Stalling!!!!!!!!!!!!!Help Please!!!!!!!!!!!!!!!!
- stalling!!!!!!!!!!!!!
- Difference in front-end between calibras! Help!!
- fault code
- Rev counter
- Astra 1.7TDS problem!
- New main/thrust bearings
- cav wing mirrors
- Corsa body panels
- Piston Rings ?
- my speedo's out any 1 know y?
- veccy pads last only 2000 miles?
- Charging help please???
- Vectra b anti-roll bar
- any views on ebc
- GSI niggles!!
- AirCon
- adjusting speedo needle
- handbrake light staying on
- astra mk4 speedo clocks
- Icv
- calibra sunroof
- what happened to neil adams?
- twin 40's
- Electric sunroof conversion Mk4 Ls Astra
- I pulled the fuse
- what size ring spanner ?
- overheating at idle
- Knock sensor wiring
- Help!!! fault codes
- Inner, and Outer Cv Boots
- y22se Knock Sensor
- cav sri 16v 2ltr m reg
- To bleed or not to bleed that is the Q
- 7mm Allen Key for caliper bolts? where from???
- v6 calipers on GTE astra
- blowing fuse
- Inadvertly reactivated my Alarm dooh!
- Bent or Damaged Diveshaft????
- 288 mm calipers with 284mm disks
- Rear Electric Windows
- Relays/Fuses
- Knock sensor
- brake problem annoying me
- V6 -1 = running on 5
- nova/corsa steering column comparison...
- Leccy Wing Mirrors
- Opinions on 2.0 8v GTE
- help
- clocks
- sunroof calibra help
- quick question: calibra-astra suspension.
- Aircon question...
- evaporator ? what does it do ??
- What a bodge !!!!!!! shocked !
- Removing the ignition key lock surround??
- HELP! sports button!!
- astra f central lock problem?
- Diff change on F15CR
- Metal rollers
- 200SX Big End Bearing Change
- Cooling Questions...
- what wheel hub to get for a corsa 2.0 wiv cali v6 disks
- calibra fan wont kick in!!!
- question!
- A very new angle on home made T bodies..
- how to clean
- in dispare
- Electric windows on Calibra....
- Random starting problem
- mk2 astra..bad earth????
- What a game a GTE is...
- inspection symbol
- F.A.O Someone who know's bout mk3 astra
- Quick temp gauge question
- thick
- quick calibra back box question please reply asap
- core plugs
- Gsi Ecu
- speedo playing up
- help needed ASAP............... please???
- aircon problem. help please !!!
- Astra Mk3 is it GSI or Sport
- ecu
- Mini Cooper superchargers
- Thick black negative wires by doors in a Calibra
- Brake Disc Help
- fan
- Vectra Rear Deadlock
- Digi dash bulbs, Where can you buy them from?
- AIR CON pump leak can it be helped ...
- Mounts
- astra rev counter
- mk3,bonnet
- nova conversion
- 1,7 td too 20dti!!!!!!!
- Air conditioning system - could it be faulty?
- nova 2.0 16v zorst
- Interior fan speed a bit pants
- new cars heater/blower power is cr@p
- FAO clifford concept 300 owners
- Are master cylinders ever pressurised ??
- torx bolts
- transistors
- Anyone needed to replace a Vauxhall auto box?
- Strange Electrical issue. (Vectra)
- dis-pack question?
- Removing steering wheel with airbag?
- Urgent!! No battery light
- Corsa lack of and adding Rev Counter
- Q; squeeky brakes.
- Widest Tyres
- need help quickly-knock sensor
- cav airbox?
- Fitting Air Con to a Calibra
- Mpg
- Small device on H/Matrix with rubber hoses on V6 Calibra
- Opening up digidash
- 16v conversion help needed..
- ABS prob
- Air Leak
- Alternator probs
- quick question steering colums
- rev limit problem
- Getting shot of the airbag!
- What springs
- how to ?
- "F" in Cally T time/temp display?
- Stretched bonnet pull - adjust or replace it?
- 2ltr gsi in a tigra??
- 160 clocks
- Vectra Brake Issue
- Goodyear or Avon?
- INDICO hoses...?
- Custom Airbox's
- ASTRA 1.7 D M reg. Gettin` Hot
- Core Plug Help Needed
- Will this...(Nova Strutbrace)
- Omega info...
- Short Socks
- Stats please
- seal sets
- rear disc conversion...
- Fault Codes
- cool running thermo and switch? how do i know if i hav 1
- wheres my ht leads gone???
- Cavalier 2.0l 16v Mreg
- Moving battery to boot, a few questions please...
- Jacking up a nova back end, where to?
- Checked tyre treads religiously. Advise please
- Vectra Di starting problems were to look first!
- Part numbers needed
- wiring fan so stays on with ignition off
- Thermostat in my Astra?????
- Calibra 8v Starting Probs
- Corsa C Wingmirror
- Fan not cutting in at 102!
- question
- Homemade front strut brace?
- Do any ABS brake master cylinders have different bore sizes?
