  1. washed keys
  2. how easy is it to change a reverse light swich
  3. supercharger
  4. cav diff swap
  5. Hmmm - i think it's knackered
  6. refurbing calipers
  7. 3 seater nova
  8. Running a 12v lead from the battery to the boot on my Mk4 Astra???
  9. Upgrading my Vectra spec
  10. Which colour wires do you need to short to get fan to stay on??
  11. Strange fault
  12. My reverse lights don't work!!
  13. central locking
  14. Vectra Tyre sizes.
  15. Is my car lowered??
  16. Strange electrical problems??
  17. Which 1.7 TD is which?
  18. Clifford concept 300 questions
  19. A Hi and a few questions.
  20. Pretensioner Question
  21. corsa eleccy sunroof
  22. 98 Octane RON Plug ??
  23. Mk 3 Astra alarm problems.
  24. tyre choice, yokos or better
  25. electric sunroof conversion
  26. HELP just fitted full scorpion system and
  27. uprating gte 16v brakes
  28. HELP! Right sensor but Different CONNECTOR+WIRE COLOURS!?? *PIC HEAVY*
  29. :s comp bulb removal
  30. Octane plugs
  31. Air COnditioning... Make a difference in cars power??
  32. MK4 Astra starting problems
  33. brake fade
  34. Should I buy this Senetor or not????
  35. Corsa Gsi brakes?
  36. nova mk1 to mk2 dash conversion
  37. cav tubo computer
  38. disc dilema
  39. Dizzy for webers
  40. Battery draing current!
  41. couple of problems (corsa b)
  42. Electric Mirror wiring & fitting again
  43. EM light always on
  44. Strange central locking problem!
  45. Horn fuse?
  46. 20seh conversion
  47. Cruise Control into Mk3 Astra *HELP NEEDED*
  48. Nova Clocks / Instrument Panal
  49. What a laugh!!!
  50. Sunroof onetouch
  51. Astra 1.7td acceleration problems
  52. quick nova question
  53. air suspension
  54. Just fitted PAS.....but have a problem.....
  55. Weird idle
  56. oh sh11111111t
  57. electricdonkeybottombiters!!!!
  58. Astra GSi mk3 time/date... display
  59. MK1 nova stereo wiring
  60. whats the adress of the site to find out part numbers???
  61. Coolant Hoses - Confused!
  62. Identifying ABS sensor wheel
  63. T.f.s - Attention!!!!
  64. Vacum Hoses Where?
  65. electric window help plz
  66. Calibra thermo temps?!?!?!?!
  67. Inconsistant Running
  68. 20seh
  69. 1.7TD Towing??? Help.
  70. Changing Aircon condenser
  71. rev limiter
  72. Rad Fan speed Resistor
  73. CV Boot
  74. Lowring springs
  75. Omega Co2 Probs
  76. Suspension costs...any ideas????
  77. Steering Vibro
  78. What is this?
  79. multi changer wiring
  80. power steering
  81. Golf Mk3 Rear Disc Conversion for Corsa
  82. actuator bracket, question?
  83. Pulleys
  84. Astra G DTI 16V Hesitating!
  85. what is a hub assembly kit
  86. Power steering on a combi van
  87. actuator??
  88. Courtnay Actuator - Uprated one
  89. Sorry Non Vaux But he used to have one!
  90. Question needed answering
  91. Magnex stainless
  92. Still running hot!!!
  93. F13 CWP ratio's
  94. Mk2 Astra brakes still leaking (help)
  95. which plug is this! (mk3 Astra GSi)
  96. central locking
  97. leccy window fuse astra mk2 gte
  98. What broke 1st, rod or piston???
  99. My car handles like a off road vehicle........
  100. rear electric windows
  101. Electronics help- is Dom still around
  102. WTF? are nova hubs off set/ center?
  103. emission light
  104. can u have power steering on a 2.0 16v corsa which started life out without pas?
  105. Help!!!!
  106. Nova brake question
  107. a little help
  108. how to / step by step guide
  109. Power Steering Quick Rack
  110. Top speed of a cav GSi in 2nd
  111. Cavalier vs. Astra Motors?
  112. V6 knocking. WHY???
  113. avo suspension
  114. squeaky springs
  115. Rolling Roads: Are some graphs at the wheel and some not?
  116. 308mm discs?
  117. thermostat?
  118. bypassing leccy window switch
  119. Battery Charger Help !!!
  120. astra GSi Knocking at full lock
  121. mk2 astra central locking
  122. Changing alternator on CallyT
  123. power steering rack..........
  124. weird fault codes!
  125. urgent help needed
  126. calibra trip computer
  127. Nova, replacement door rattles worn hinge - fix ideas?
  128. Random connectors
  129. freeing off calipers
  130. what brake pads should i buy?
  131. which is better 2 tune
  132. corsa c
  133. airbag light
  134. TIGRA Owners - Private Plate T1GRA!!!
  135. TAS Nova/Corsa quick rack help please
  136. 130mph then ecu light appeared....
  137. zorzt - will it fit
  138. what year did the dth start on the vectra ?
  139. Another Sensor Problem
  140. Suspension Question.....
  141. Cr 12.5:1
  142. Corsa rear brake swap
  143. expansion tank
  144. 1.7td what mods can i do...
  145. Custom PCB & component manufacture.
  146. Got an Error Code 19 from my diagnostic port
  147. finally started my 16v nova
  148. Brembo discs and calipers...
  149. Will all Brembo calipers fit?
  150. Astra Distributor
  151. Could one sided tyre wear be beacuse cars too low???
  152. Omega elite warning
  153. Astra Illuiminated sunroof switch
  154. Astra mk3 1997 Arctic - ABS or no ABS?
  155. lower mk3
  156. Omega multi func displays
  157. quick R&R question.
  158. Zaffira GSI suspension.
  159. Omega Probs
  160. anyone used Manse Vehicle Management in cairney hill? (fife)
  161. Strange startup probs....
  162. Abs probs .
  163. Back on the road at last...
  164. air conditioning
  165. 3rd horn :s
  166. 16v calipers going on a corsa
  167. MV6 tyre size
  168. Fault code
  169. Traction
  170. Nova Strengthening Kit
  171. water temp dial does't come out of the blue
  172. astra v6 project
  173. Problems all over the place, but not getting any fault codes
  174. I spotted trouble ...but how do i replace?
  175. spax adjustables any info please. mine r broke
  176. Can you machine et35 to et40/42/45?
  177. Removing Heater Matrix from Calibra with A/C
  178. n2o
  179. any 1
  180. Could my thermostat be broke????????
  181. nova clocks different?
  182. distributor problem?
  183. Chokes on dellorto 45s
  184. help me
  185. MK3 Astra GSI steering wheel
  186. Nova bonnet cable
  187. Heated Nozzles or Hotshot?
  188. How Low
  189. astra gte rear brakes
  190. Innovate motorsport wideband?
  191. Astra Audio Please Help
  192. Quick zorts problem query
  193. low hanging Zorst!
  194. Corsa Telltale - Spanner light
  195. EML light
  196. Steering problems continued - Has the rack dropped?
  197. Digital Dash Conversion
  198. Where Is My Diagnostic Port?
  199. Upgrading Clocks
  200. Sport Brakes on to Merit.... (Astra F)
  201. what is this
  202. converting dis to dizzy
  203. Problems starting 95 MK3 Astra
  204. Brake pad help....
  205. V6 running rich?
  206. Mk 3 Astra heating motor problems
  207. Boot Lid problems plz help!!
  208. Suspension querey
  209. Rear Springs
  210. Rad Fan Switch
  211. smoking battery?
  212. Cally battery drain
  213. Cav V6 Front Struts On Astra Mk3?
  214. Help !!!!!
  215. Central Locking
  216. Alloy steering rack mounts
  217. Nova GSI/GTE heat sheild
  218. V6 Calibra, intermitant start fault
  219. Won't Idle!!!!
  220. Omega MV6 specs?
  221. Suspension?
  222. fooking ecu AGAIN
  223. Brake brackets
  224. cav v6 alternater
  225. Brake Servo Pin refitting (Nova)
  226. Dash removal, big job?
  227. Corsa EPAS into Nova query...
  228. Mk3 dash into mk2 astra wiring help needed please
  229. Suspension advice Astra GTE needed!!!!
  230. what's this under my passenger seat?
  231. Wer is the ICV on a V6
  232. What the hell is this???
  233. mk3 astra steering problem
  234. rear strut brace
  235. Just installed K&N
  236. Cav V6 Rear Beam/Astra MK3 Question???
  237. Electric sunroof
  238. Over revving?
  239. how hard is it to fit air con to astra mk3
  240. Strut Brace Fitting
  241. question regarding production runs on Novas
  242. thread locker?
  243. Can't Understand The fans plz help?
  244. Car Key Fob Prob !!!!!!!!!!
  245. how thick would this bit of metal be?
  246. removing cv joints ahhhh am i retarded
  247. had a bit of a dilema
  248. Temp Sensor stopped working after fitting stereo, any ideas??
  249. Cant sort rear lights on Nova SR??
  250. speedo
