  1. Anyone local to Farnbrough or around?
  2. as requested some pics of me car
  3. Nova Brake Set up advise
  4. Intersting Transponder Immobiliser discovery.
  5. Part number check please (EPC)
  6. Changing brake pads - what tools needed?
  7. Hone or not?
  8. Omega/Vectra wheel offset
  9. can this be done???
  10. speedo help!!!!!!!
  11. quick one
  12. astra mark 3 springs
  13. Speedo Problem
  14. HELP !!!! My car has a mind of its own ??
  15. Kinked Power Steering Hose, MOT Fail?
  16. Speedo Problem
  17. tech 2 and elite autobox
  18. strut brace problem
  19. e16se or 2 litre eco,into corsa
  20. shocks botteming out
  21. Astra Coupe Dash LED kits
  22. Strut Braces
  23. Ebay OBDII OBD II OBD2 OBD 2 Car Tool Scanner Code Reader
  24. De-Locked Vectra Handles on MkIII Astra
  25. FK Suspension Springs
  26. Boonet Release Mod (Mk3 Astra GSi)
  27. Final drive ratio 4 coupe
  28. Wiring Vectra Front Fog Lights???
  29. Cab Electric Windows & Tempreture
  30. boot solinoid
  31. Corsa Question.
  32. astra mk3 problems
  33. V6 TB standard size...
  34. me again
  35. V6 Calibra, Idling High???
  36. Shocks & springs!
  37. what are these
  38. Low pressure
  39. anyone know of an ecu repairers????
  40. checking ford ECU
  41. V6 Breaks
  42. Corsa B Adjustable Steering
  43. ABS Wheel Sensor, any ideas how to remove it?
  44. Can someone explain this graph please?
  45. cav gsi problem
  46. ecu help
  47. Cav GSI PROBLEM
  48. Tech 1 and Tech 2 - Where can i get one?
  49. Calibra drinking coolant....
  50. Astra GSI front anti roll bar.. is it 24mm?
  51. Gauges Options
  52. Gauge options
  53. Astra Electric Sunroof Q
  54. H4 bulb current
  55. astra mk3
  56. calibra 2.0i i6v
  57. cav been to vauxhall, soon to be sold
  58. 5 stud hub conversion on 1.6 16v corsa gsi
  59. backing boost off?
  60. Clicking noise
  61. Fitiing a new airbag after an accident
  62. ECU fault codes
  63. wierd watery noise
  64. V6 traction control
  65. internall wastegates
  66. removing nova doors?
  67. Do all Astra G's do this?
  68. nova ign barrel removal NO KEYS!
  69. 205/55 tyres on a nova?
  70. Okey ECU .. need help asap
  71. Input Release Bearing 1.7 td isuzu
  72. Astra g
  73. ECU help
  74. No closed loop in idle
  75. wierd problem
  76. High rev-up and unconnected hose
  77. mk4 v6
  78. dip stick
  79. Custom ECU`s
  80. popcorn cav?
  81. Astra 1.7td problems
  82. £40 for changing brake pads?
  83. Difference Between Astra Mk2 & Mk3 Beams
  84. strut brace
  85. Aircon re-circ hose???
  86. Thermostat
  87. Why did it happen?
  88. 1.5td nova speedo cable
  89. VX part number for vectra climate control fan
  90. Annoying noise
  91. 8v into 16v
  92. Heat resistant material
  93. height adjusting?
  94. whats wrong now?!
  95. 60A ignition fuses, where from?
  96. calibra v's astra mk3 suspension
  97. struts/springs
  98. Astra mk4 sri help
  99. no ignition?
  100. Rounded off :-(
  101. Omega/Veccy without external aerials
  102. rear discs
  103. ecu connector pin numbers
  104. Suspension bushes
  105. Info on removing vectra b speedo unit, please
  106. Octane sensor for 2.0 16v
  107. Vectra td Problems * Can anyone help *
  108. continuous idle problems
  109. CAI kit for Vectra SRi 2.5 V6
  110. airbox mod
  111. Ford escort question
  112. Rough idle when warm, car surges on high speed.please help
  113. starting trouble
  114. Info from EPC please!
  115. Vectra strange problem.
  116. EBC Brakes
  117. paper clip test ... no ecu light on dash ?
  118. Cleaning ICV
  119. Reverse Lights - Tigra
  120. astra mk3 sport
  121. Air con hell
  122. alternater upgrades
  123. Wastegate Advice
  124. Vectra Airbag Light?
  125. Ignition Systems
  126. how much nos?
  127. Dodgy accelerating
  128. Hot Car!!
  129. Iffy central locking....?
  130. urgent help
  131. nova sr help
  132. Omega C rear lights on Omega B
  133. Wastegate
  134. boost
  135. how low can u lower a tigra ?
  136. ABS light!
  137. plug gap
  138. fault finder
  139. Tapping noise
  140. MK2 Astra GTE Digital Dash
  141. Help!! Warinng non vauxhall question!!!
  142. Quick question?
  143. Brake Pad Wear Sensor
  144. Airbox De-Restriction
  145. nasty clunk and noth in steering
  146. what brakes?
  147. 2.0 16v sri clocks
  148. Corsa question
  149. Quick answer needed!
  150. V6 parts manual - HELP!
  151. any1 know which fuse
  152. V6 rev limit
  153. Time to L.E.T.
  154. Why is the GM V6 so lame?
  155. Senator Alternator
  156. removing front doors off an astra 3 easy or not ?
  157. calibra springs!?!?!
  158. Late / early calibra sunroof.
  159. tas motorsport?
  160. cav speedo
  161. another nova conversion
  162. Some help please people?
  163. Retrofit Cruise control to 2002 Zafira
  164. Corsa Problems
  165. SFi box bolts
  166. Astra GTE roll bars
  167. actuator bracket question
  168. FAN Matrix Problem!!
  169. Nova smell's like gasoline
  170. Cav GSi Brake options
  171. buggered
  172. Cleaning The ICV!
  173. Air con Problems
  174. Running hotter than normal
  175. MK2 power steering rack
  176. Please help! its driving me mad! (suspension related)
  177. FAO ppl with bilstein cup dampers or apex-40mm springs
  178. Clifford problem
  179. Vectra B warning lights on (abs and Ecu,)
  180. Digi Dash taking the mick...
  181. Traffic Master
  182. Wastegate..
  183. car keeps cutting out!
  184. Vacuum query!
  185. wd40 or grease
  186. Very high temp ducting !!
  187. ar25 / ar35 auto box
  188. screen wash not working
  189. Door Plug Removal ON MK4 ASTRA???
  190. braking problem.please help.wilwood brakes onto a nova
  191. why the feck is my accellerator feel harder than my brake sometimes.
  192. Coolant how many litres?
  193. External wastegate question !!
  194. Will it run?
  195. ze22 timing marks
  196. My Car Squeeking
  197. rattle/rasp under load?!
  198. * E16SE into Corsa B - Advice needed
  199. Reverse Selecting Probs On 6 Speed Box
  200. Where can i get a decent air temp gauge?
  201. Help Needed!
  202. corsa problems :(
  203. Tailgate central locking
  204. cavvy problems
  205. Advice as to old and new key fob remotes
  206. 3.0 V6 bottom end knock
  207. MBE 912v3 help
  208. Cavy gsi brake on a 03 corsa?
  209. Electric Sunroof
  210. Parts Supplier
  211. horn problem
  212. V6 wiring - again
  213. Stalling Cav.
  214. "fail safe" engines...
  215. first year v6 engines fitted in calibras
  216. what to look for/ nova sr
  217. mk4 v6
  218. fitting remote centeral locking
  219. Central Locking
  220. Couple of q's.
  221. Wiring Diagram Required PLEASE HELP!!!
  222. coolent radiater size
  223. astra areial
  224. oxi / lamarda senser question.
  225. momo Boss kits
  226. cav v6 running problem
  227. Someone Plz Tell Me Which MBE Ecu This Is?
  228. Dash Fire
  229. Arch starting to bubble on MK4
  230. A/B plug question
  231. Help. Tracking issues.......
  232. astra tappits
  233. Deadlocking - not happening!
  234. Air con on a Nova
  235. battery/ignition warning llight
  236. Help shortening steering rack
  237. What's the biggest brakes I get get under a 16" rim ?
  238. Fitting LPG
  239. cav v6 supension
  240. Changing Front shocks
  241. what is annoying squeek
  242. Car Blues
  243. Private Work In North London
  244. electric windows & switches
  245. Nova 2.0 8v Water Pipe
  246. Hi-Spec Brakes?
  247. Strange (earthing ?) problem....
  248. 2.2 airbox
  249. Nova 2.0 Seh Advice
  250. washed keys
