PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Please Read
  2. Outside temp guage not working
  3. Inj system
  4. MK4 Astra ECU light concern
  5. Astra gsi discs
  6. can V6 IRS accept a diff and shafts
  7. washer warning level
  8. Brake line joining
  9. squirms on bumps any ideas???
  10. can the beast be blown?
  11. Is this normal?
  12. mattj likes big bores, you heard it here first.
  13. Stalling problem.... please help
  14. Cav Gsi Front Bumper
  15. any-one no of any machinists/tuners that will enlarge standard tbs
  16. Cavi GSi Idle problem?
  17. need help,couple of questions.
  18. cavalier shocks
  19. people who will machine enlarge standarb tb down south
  20. Senator 24v 3litre cruise control problem
  21. Cally speedo help
  22. Will a 16v/V6 rad fit the CallyT?
  23. Short shifter
  24. vectra sri f18 box
  25. Ugh, confused, please help with errors
  26. digi dash plugs
  27. Astra/Cav rear hubs
  28. advise please
  29. Corsa frames onto cav leather
  30. airflow meter swap
  31. MOT and V8 Question
  32. Need guide in distributor cap replacement
  33. Outside Temp sensor Help!!!!
  34. Very Quick Question here!
  35. how do i do it
  36. Are These Legal
  37. Would you fit your own lowering springs?
  38. Vectra Di,Glow plug or compression start??
  39. what do i do now
  40. idling problems
  41. given up
  42. traction control
  43. Plugs And Leads For My Astra
  44. indiglow lights
  45. Biga Brakessss
  46. How to Use a Multimeter?
  47. Astra mk3 suspension front legs.
  48. windscreen in cav
  49. look what i got
  50. new sport v old sport????
  51. How do you stop thieves taking my Cali
  52. brakes
  53. Help
  54. Connecting Alternator
  55. Lowering a MK3 astra.
  56. -31 atuator body sizes?
  57. code 93, hall effect switch (low voltage)??
  58. Loose front end on Cally T & removing struts.
  59. urgent help needed
  60. Alternator Light
  61. Trottle Body Mod?
  62. help on corsa needed
  63. car stereo wiring
  64. Corsa missfire
  65. Differences between to Calibras 2.0L8v(K),2.5V6(M)
  66. Help Needed Urgent
  67. calibra bolt pattern
  68. cav suspension query
  69. silicone hoses, will cav/cally fit astra3??
  70. dispac lead positions
  71. having lots of trouble starting (v6)
  72. misfiring detection
  73. Z22SE timing chain -((
  74. nova wiring diagram for dash?
  75. Starting problem
  76. low voltage on airflow meter.??
  77. compression test help
  78. combo van rear disc conversion (help)
  79. combo van rear disc conversion????
  80. Astra sxi Problem HELP !!!
  81. removing front wheel bearings...
  82. Nova problems, any ideas?
  83. Cav/cally V6 5 Stud Hub Size
  84. Help compression problems
  85. Problems with Mk3 Astra Rollcage Fitment
  86. how to upload a pic
  87. Fixing Coolant Tempreture Sensor
  88. Washer jet pumps
  89. Hi
  90. Ventilation switches astra Mk3
  91. Water In Footwell
  92. HELP! Locked out of car!!!!
  93. 2L 8v donor car
  94. Advice needed for lowering Cally (pics)
  95. would a worn differential cause steering probs
  96. Excessive movement, steering rack..
  97. adjusting handbrake help please
  98. can some one help
  99. Wanting to feed cold air to filter
  100. Temperature Gauge
  101. its a hot and sticky one!
  102. Benefits of rear discs and pads
  103. What's the biggest size front brakes I can get...
  104. Which profile tyres to choose ?
  105. ABS update
  106. Alternator finally dead?
  107. MK3 Astra 5-stud conversion
  108. hi rpm when idle
  109. Astra Mk4 Running Crap!!! HELP!
  110. weber help
  111. NOVA + Cav SRI Castle hub nut sizes?
  112. anyone with webbers on novas look in here
  113. gsi to sri
  114. mk3 -40mm!!
  115. Astra GTE Lights On Buzzer
  116. Astra f idling problem
  117. Urgent! Steering Rack!!!!
  118. rad lengths ??
  119. 8v solids
  120. should ecu light come on with o2 sensor disconected?
  121. Nova strengthening kit spare parts left over ?
  122. please god no
  123. MOT due, what do i need to check on my car before i take it in?????
  124. Kangarooing
  125. sensor problems
  126. HELP in Southampton (Nova) long post
  127. Compression test results...
  128. Torque Wrench
  129. hub sizes
  130. Low compression.. Whats it all about..
  131. Mk3 Astra bushes
  132. Where to buy a size 12 spline bit
  133. astra suspension
  134. Bike Race Can
  135. oxygen sensor
  136. bump bump bump....
  137. stupid computer
  138. Adjusting senator brake pads...
  139. Rings ?? and running in !!
  140. Golf VR6 question
  141. where can i find them?
  142. Astra Mk3 cental console
  143. Disabling the passenger airbag
  144. 17inch alloys
  145. Vectra Di just stopped working
  146. ebay item looks abit funny check this
  147. quick temp gauge question
  148. Identify my chargecooler
  149. digi dash
  150. people who helped me in past 3weeks.
  151. nova 2.o
  152. v6 cooling hoses!
  153. Noise
  154. Koni/Eibach suspension set up on Calibra V6
  155. oops....
  156. Major Problems!!!! Help S.o.s Call!!!
  157. Knocking noise (mk3 astra)
  158. Changing an ECU
  159. What Bolt? (cav suspension)
  160. Rev Counter Probs Again
  161. Dad's Zafira?
  162. What Does This Mean Help Please
  163. MK3 Astra GSi rear suspension advice please peeps!
  164. Help... Car making noises
  165. IRS/torsion beam rear disc differences?
  166. best back box for sri 16v
  167. astra gsi rear discs to 5 stud?
  168. Quick Shift on a corsa
  169. sh*t braking - any ideas?
  170. Nova steering wheel
  171. Help on delco 16v calipers on corsa
  172. Any good??
  173. 12 Spline Drive
  174. JE's (steveboyslim ones)
  175. Koni Adjustables - Help Required
  176. cold air??
  177. EM light.. Low voltage to...
  178. Help quick
  179. hall sensor
  180. Tell Me Everything About Twin 40s PLEASE
  181. shortening digi dash???
  182. Suspension kits
  183. How do you get to the sunroof switch?
  184. wiring new clocks up
  185. tyres
  186. Belmont lowering and wheels
  187. Inlet Temperature gauge
  188. carlton digi dash
  189. bike TBs
  190. astra belmont lowering
  191. Advice needed re:radiatior calibra
  192. electrical probs, nearly there help needed tho
  193. help with a PAS problem??
  194. Easy Question...
  195. Bit of a downgrade
  196. It'd be a bitch wouldn't it??
  197. wiring add on to TIS
  198. quick Q
  199. Calibra Handbrake Cable- How much?
  200. Carlton Gsi 3000 probs????
  201. Pop bang - GTE 16v *help plz!*
  202. Strut brace help needed.....
  203. Newbie need a little help astra estate 1.7 Td
  204. How much to replace a lost key?
  205. ASTRA MK 3 Light switch problem (2nd replacement)
  206. underseal
  207. Astra 2.0 16v rear axle on a nova?
  208. Nova sri mileage
  209. Rev counter
  210. Boost gauges
  211. Help Locked Out
  212. electrical probs again. half sorted
  213. suspension question
  214. air lock in heater system
  215. Lowering a P reg v6 vectra SRi
  216. Cav 2.0 16V abs error code 24 & RPM problem
  217. Hazard light in center console
  218. any ABS specialist on here
  219. Just bought some koni adjustables
  220. Cavalier 2.0 16v fault code 24 & RPM problem
  221. astra gsi springs
  222. v6 does not stop running stright away
  223. corsa suspension pics (hit curb)
  224. AFR guage
  225. judderin
  226. omega suspension
  227. alarm problem any ideas
  228. Omega wishbones
  229. Tracking Keeps Becoming A Problem
  230. flasher relay
  231. Quick PAS question....
  232. mk3 astra gsi traction control
  233. airfilter
  234. Whiteline kit - Corsa Handling (not suspension)
  235. airfilter
  236. astra undeersteering badly! help needed
  237. Nova Gsi Sunroof Problem!
  238. removing snapped bolts
  239. super unleaded? real octane increase?
  240. Running car in
  241. Changing Bulbs again (sorry)!
  242. Cavalier 2.5V6 CDX replacement front discs
  243. Ignition Selection!!??
  244. Question about side repeaters
  245. Shot peening
  246. astra brakes
  247. Remote Central locking Problem MK3 Astra
  248. brake fluid is going down slowley ??advice plz
  249. Best brake setup?
  250. Leakage
