PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Replacing MK4 Astra rear disks + pads
  2. ecu codes
  3. RS 1800 lump in Focus?
  4. Rear height adjustable suspension for Astra MK3 GSI 2.0 16v
  5. time to change my plugs
  6. part number needed!
  7. speed
  8. Please Help!!!!
  9. 1.7TD(Isuzu) Questions
  10. Vectra autobox problems
  11. Service info. for Y20DTH
  12. Ford Red keys (yes Ford I know!!!)
  13. grinding noise???
  14. Carlton digital dash??
  15. 2.0L 8v nova
  16. Have some money and thinking of this.
  17. Would MK3 Cav Hatch Suspension fit on to a MK2 Astra Hatch Sri ?
  18. Basic wiring help
  19. Zafira Spare wheel
  20. OBD for Zafira
  21. electrical problems!!
  22. Weird noise from front wheel/wheels??
  23. Cav Gsi break problems
  24. Corsa V6 teething problems
  25. wrong forum but hey worth a shot
  26. Corsa 2.0 16v insurance
  27. Parts Suppliers
  28. Rear disc conversion corsa 5 stud
  29. Dynamat vs flashband?
  30. wireing diagram
  31. Running Rich
  32. help needed
  33. don't f**king believe it
  34. transducer probs
  35. strange boost problem(overboost-big lag)
  36. universal back box fitting for a mate
  37. Omega Sunroof In A Cavvy
  38. toad a101 help needed asap
  39. high level brake lights
  40. car won't switch off v6 astra
  41. wet carpet
  42. fault code reading on a Y reg astra. need info for 5pm today :p
  43. Adjusting Koni Dampers
  44. fed up wiv cowboys
  45. igniton lights on(dim) plus no charge?
  46. pic request
  47. Wiring colours in GSI help
  48. High compression
  49. hazzard switch !!!!
  50. Arrrrrrgh
  51. Are Rear Brakes Important?
  52. Quick question. TB's
  53. This is really starting to annoy me!
  54. Rear Lights not working
  55. How hard is it to wire up a 2lite 8v in a corsa?
  56. jacked up to high
  57. i broke a bolt.........
  58. Autovaux help
  59. need to know
  60. no glow plug light ????
  61. gsi mk3 astra steering wheel?
  62. ngk 6 or 7?
  63. wiring problems
  64. siezed brakes
  65. Jacking up the front end without using the sills??
  66. need help
  67. cavalier V6 brakes
  68. improved alternator adjustment
  69. tempermental GSi
  70. crappy acceleration
  71. ICV could this be my problem
  72. New Wheels
  73. tyre pressure
  74. TX Star/Torx
  75. Are these the same ?
  76. V6 brakes, spongy pedal
  77. Corsa speedo problems
  78. Aberdeen area garages that will do this?
  79. lowering springs
  80. New brakes ;)
  81. is it really needed
  82. corsa sri into a mk3 astra
  83. astra GSi question
  84. Nut at top of front suspension strut
  85. Electrical gremlin in my tail light
  86. flushing the coolent casued water leak
  87. klaking noise
  88. nightmare
  89. up rated brakes
  90. vectra---clue less
  91. Cheetah Alarm
  92. air flow meter
  93. vwctra
  94. Could these ECU fault code probs be linked ?
  95. how do i remove the front grille
  96. cant get speedo to work
  97. Push button start
  98. MIGWEB well worth the membership.....
  99. Trust bearing for on top of Astra Mk3 Front struts
  100. NEW compression test results
  101. Just show's how reliable car's are
  102. Help! i have weird brown sludge...
  103. vauxhall imobilizer
  104. problem with corsa battery is getting drained over night
  105. astra problem
  106. fse mucked around with!
  107. Castle nut wont come off!
  108. compression test results :-(
  109. veccy wont tick over when cold
  110. Omega part numbers...Help!
  111. hw to remove the corsa v-grille.
  112. Any 1 Know
  113. problem help needed
  114. quick bit of help needed please
  115. Corsa B suspension problems
  116. 5 stud conversion. whats needed?
  117. What box in Astra 2.0L GTE?
  118. quik question
  119. some emission advise please
  120. extending brake servo pipe
  121. What gone on here?
  122. New Vectra :)
  123. vectra ,clocks
  124. re, the noisy hydraulic tappet when cold
  125. twin 40's
  126. Need advice on 100mph+ acceleration inprovement
  127. bigger brakes on 1.6 Mk3 astra
  128. ecu on cavy gsi
  129. corsa rear discs?
  130. vectra air bag (HELP)
  131. suspension differences in vectra estates
  132. 2.0 litre bottom ends
  133. Thermostat
  134. Mk 3 Astra Drum to Disc
  135. can u clean an ecu?
  136. astra mk3
  137. centre console switch
  138. Removing gsi rear seats ...
  139. brakes
  140. Zafira 2.0 DTI
  141. HELP!! :( how to remove airbag steering wheel
  142. alternator questions (again)
  143. what gain am i looking at
  144. suzuki swift dry hydraulic tappet?
  145. Calibra tyre size??
  146. help really needed
  147. Omega Help Needed
  148. ecu
  149. Am i dim or what?
  150. resetting the ECU
  151. splutering and miss firing at high speed !!!
  152. does omega cruise control require an ecu
  153. vectra
  154. which side light wires
  155. corsa warning light (pic)
  156. section 8v pics???
  157. lowering an astra on nova springs?
  158. Lost reverse and fifth
  159. urgent help needed
  160. How do I remove the rotor arm?
  161. starting the v6 astra project!
  162. vectra
  163. Bit wierd......
  164. Rear wheel bearings, big job?
  165. springs are they dead??
  166. Detaching brake hose from lower arm (rear) on Calibra
  167. steering problems...help!!!!!
  168. Corsa Dash computer
  169. 2.0 Sport Astra MK3 Brakes Poor - ABS ?
  170. 1400cc 16v corsa stalling at low revs
  171. Really irritating flat battery problem
  172. over heating
  173. vectra
  174. airbag removal
  175. How Low?
  176. calibra electric problem
  177. Weber Alpha plus ECU pin diagram
  178. Interior bulbs sizes
  179. Electric mirrors - mk3 astra
  180. need some info on V6 engines please
  181. Trouble starting car....
  182. Anyone know how to read off fault codes on a Daewoo Nexia 1.5 GLXi?
  183. siezed brakes refurbed?
  184. Sticking Windows
  185. Booked in for this!!!!
  186. Tech Plug, Part 2
  187. webber 40's fitting question
  188. T reg Corsa stutters at 2000rpm
  189. ECU reprograming
  190. Auto electricians help needed
  191. how do you cure drivers seat sub frame from creaking?
  192. Wheel Prob
  193. Tyre pressure
  194. Astra Mk3 2.0 Sport Spec ?
  195. corsa/calibra automatic questions!!
  196. knocking from front
  197. Intermittent non starting.
  198. Corsa 2.0l gsi 16v
  199. newbie here
  200. corsa lowering??
  201. astra gsi anti roll bar link replacement
  202. Astra mk3 Gsi...
  203. astra gsi jerking when slowing down
  204. which is best on a gte nova?
  205. Public appology
  206. Mk4 astra brakes ??
  207. car stereo switches of randomly...
  208. problems changing to the light grey clocks on calibra
  209. any one know?
  210. rear brake conversion
  211. i'm a bit confused.....
  212. IAT sensor help please!
  213. nova gte idle problems.
  214. M tech 2.0 corsa short shifter
  215. Changing V5
  216. Astra Mk3 antirole bar
  217. torque wrench purchase? which one?
  218. y isit back firing and dropping to 2 cylinders
  219. Tech Plug?
  220. Relays everywhere!!!!
  221. ABS Fault code - No ABS!
  222. combovan rear disc conversion
  223. Calibra brake warning light probs
  224. Calibra probs again
  225. MOT failed
  226. Help Needed, CavGSi Springs onto Mk3 Astra??
  227. urgent help needed
  228. Calibra Multilock help needed
  229. Urgent Help Needed
  230. lowering mk3 cav/carlton
  231. slim line fan
  232. What do Astra LS alloy's look like
  233. Fitting Omega One Touch sunroof and setting up
  234. Missfire help
  235. boot strutsnot strong enough
  236. front strut
  237. Will it fit
  238. Heaters not working
  239. how to switch power steering off?
  240. Front Suspension Setup Overhaul?! -What to consider?
  241. Whats needed to convert my mk2 astra from 4 stud to 5 stud???
  242. What do i need to do to match a...............
  243. MOT And tyre Tread ?!?!
  244. Changing rear brakes pads
  245. need one quik
  246. Idling Question
  247. where is it
  248. Corsa(C) key central locking problem??
  249. Corsa Conversion Guide Advice Needed
  250. boost loss
