- Break servo
- V6 brake conversion problems
- Which panel filter for a Corsa b
- Bugger!!
- Ford Recaros into a MK2 Astra
- Fitment Of Aftermarket CAS!
- wiring of ignition barrell
- wheel bolts
- Horn
- Cavalier + Astra mk3 fuse numbers
- Which cars had the electric aerial ?
- Quick Question
- aftermarket pulleys
- wiring help V6
- Alternator charging and general battery stuff
- Alternator problem??
- varying idle, heater matrix "gurgling", loosing coolant. HELP!?!
- quick question nova gsi
- Calibra V6 Release bearing
- 8v and 16v rads
- 2l 8v problems!!!
- Actuator weak or not?
- springs for a omega estate
- Lowered final drive
- Temporary hissing noise on startup
- Final Drive ratios
- would one tooth make this much difference
- Info on GTE pulse senders for dash
- Stealing Nova's........
- mk4 astra TD
- how do u adjust the emissions
- Shock absobers - should they extend?
- difference between OHC and CIH ? pics inside
- battery charger
- veccy sri thinks its a drifter
- ABS light on...........how do i go about fixing it
- Brake Bias
- Corsa 1.5 TD running temp probs
- smoking
- the next stage....
- nova 1.3SR electric sunroof?
- Nova F10 Close/Wide Ratio Box
- how to check 1.7 td
- nova suspension onto a corsa
- GSi Trip comp.
- Astra 888 Performance
- 2l 16v Brakes on Nova
- sri 130 or standard 2 litre ?
- DTA management setup! The basics !! lol
- v6 cav wiring diagram
- Astra Mk4 Air Con
- help needed asap
- 2.4 c24ne specs ???
- heater problem? astra gsi
- Steering Rack Problem
- airbag
- Brake Judder Part 3
- Bonnet Lifter Problem
- Pleeeeeaaaaaasssse Help
- Brake pad Warning
- Idle - Done a search/Read the threads so...
- tyre profiles for fast road nova
- 205 1.9 gti missfire 3000rpm
- How do you check ecu fault codes when......
- New rear brake shoes / drums for astra g???
- Refitting ignition barrel .
- Nova Brake Servo's
- Brake servo ....- Lexmaul
- Adjusting rear brakes on Cav
- Air Con not working?
- bad vibration
- Can this be done easily?
- Astra 1.7 D Probs
- yodely! wiring diagram for iso plug ...
- fog light wiring
- gte digi dash into an mk3 astra?
- wiring in front foglight?
- Ashley
- Where to buy poly bushes?
- whats this connector ?
- Abs
- volvo brakes
- Brake Master Cylinder
- 195/55/R15 tyre pressure??
- V6 Auto Problems - Only CLEVER people need read ;-)
- Renault owner seeks Tuning advice
- Please help identify [pics]
- corsa c barrel
- Part Number help !
- Have I bent my lower arm???
- Help
- i wanna put leccy mirrors in an astra cesaro
- battery charger prob
- ECU's and "learning" question.
- ecu light bulb can i swap another warning light
- extending the intake route
- Calibra V6 - Auto to manual
- Suspension (top mounts) shot...
- Astra MFD
- adjustable nova steering colunm
- nova rear quarter windows
- Windscreen wiper motor keeps cutting out
- Air con not working
- astra mk3 gsi brakes
- mk 4 astra v6 engin conversion
- Nova Lowering help
- help needed
- butterflys on vec v6
- sensor question?
- vauhall warranty claims question
- Fitting Astra MID into Calibra.
- Auto To Manual swap
- Help Needed With ECU Numbers
- Query... Cav Gsi Rad hoses *pics*
- astra van 17dti gm lump
- car weights, nova gsi and corsa 1.2
- Question On Springs!!!
- Technical Help Needed
- were are the knock sensors??
- Calibra door lock: key barrel poles and wires?
- Strange Noise
- A quickie re: difference in astra brakes
- heater fan regulator going mad !!
- V6 Emission Problems
- Overheating calibra
- Will removing my battery for a while turn off my warning lights?
- Mileage on a V6
- One-touch leccy windows
- Heater doesn't work [Astra 92]
- Fitting Indiglow dials
- electric window wiring diagram for a mk3 astra
- cruise control wiring problems
- Compression test results?
- 97 3.0 Elite Auto Box
- need a bigger rad
- you hav got to laugh
- Astra `99 1.7dti van electrics
- Ajustable dash board lights
- Steering feels 'loose' from dashboard.
- Octane boosers/achieving 100RON
- cooling fan stuck on !!!!!!
- Horrible clattering/tapping under load
- Multi Function Display Help
- Where is the earth point for my handbrake?
- £1000 HP Gains
- Fiat 20vT 4-pots
- Raer pad + disc change on 2000 Astra 2.0Di
- 2L 8v PRoblems
- Help with my impreza
- non airbag steering wheel horn wiring
- cav gsi trip computer
- vec gsi brakes under 16" softstars ???
- Upper spring seat problem on Astra MK3
- Tuning help
- very heavy astra steering.
- Any Ideas???
- weird nova
- Astravan Sportiv 2.0Di info wanted
- Polybushes and antiroll bar
- how do you convert to 'remote' central locking?
- Efi Q
- seh won't rev
- Top Suspension Strut Mount/Bearing Price??
- Astra mk3 Suspension
- power steering pumps? which one?
- Fault code help please!
- Ignition help required.....
- Meriva MFD into Mk4 Astra
- wiring
- suspension do they come with hubs????
- Spongey Brake Pedal
- 60mm Drop Springs On Standard Shocks...
- Over filling
- Running Rich and Top Speed
- TB's installation
- Clicking from rear and random ABS light
- Might have a problem with my Astra MK4..
- tappin gsi 2000
- nova pully problems
- Dodgy Dash omega
- Astra Mk3 Estate V6 Conversion ?
- what other makes of car
- need help fitting boost guage
- GTE 16V still not running right
- corsa for sale
- Enlarged Top Hats.......?
- sensors sensors sensors
- suspension query
- Does anyone know what this item is called
- Can anyone tell me what sensor this is please
- Bad Cav GSi Idleing Issue
- replacing window need help
- Mk2 GTE strut brace
- adjusting timing
- temp gauge not working
- EPC Help
- Nova 1.g Gsi Fault Code 36
- URGENT - ABS sensor - Cavalier SRI
- Whats the correct way to remove the bump stripes pls?
- Ford Fusions..anybody know them?
- urgent, WTF SMOKE
- Wierd overheating problem
- bleeding my tigra rad
- rebore and SEH to 2.2???
- brake problem!! please help, i need to get to work in the morning!
- abs warning light
- 2 quick questions
- Conversion table?
- dixie
- Juddering steering - Corsa B - HELP!
- Omega V6 - limp home mode
- ECU Codes
- I need help on fitting 2.0 16v into corsa
- flash code not flashing?
- Sluggish GSI
- gsi 2000 probs
- Airbag steering wheel replacement
- where is the ecu light on a gte 16v?
- actuator?
- Electric sunroof MK3 Astra
- vectra v6 lower divider
- vectra V6 help required
- mk4 2.5 v6 astra help
- Astra Mk3 Temperature Sensor Not Working! :(
- Traction
- should i scrap it?
- Urgent Please Please Someone Help!!!!
- hdi engines
- All the little pipes
- Astra runs, but not for long.
- Fault code ?
- windscreen removal...
- Flashing/pulsing EM Light
- electric arial
- central lockin
- air con
- will a large vw/ seat ibiza 4 stud disc fit a vauxhall
- servo?
- fan
- what is the difference?
- Air Con Disconnected??
- comp test results pleae look help
- uh to the left, to the right, keep it going, keep it going, ticking is not right....
- Electrical/Plumbing Diagrams!
- How do you tell an ECU???
- calibra bonnet
- phaze two querey
- Lop-sided...
- Threaded wheel bolts...
- Astra GSi buggered
