- Rev counter help needed
- urgent
- central locking problem
- Whole Internal Heating system ideas
- astra isuzu tappet setting
- Calibra illuminated grab handles: size and fitting?
- torque
- New Wishbone Bushes Need Help Please
- Central Locking Issue?!
- rear brakes on a Zafira/Astra
- DOHC timing
- digi dash help (i've tried searching)
- Does this look ok?
- correct offset for a cav gsi
- spacers in alloy wheels? ? ? ?
- high output alt
- power steering query
- Et45 On A Corsa B ???????
- nova pics wanted
- dodgy dizzy
- transducer query
- Corsa Problem!
- wilwood 4 pots...
- mk3 astra 1.7tds
- How do i disable an air bag?
- Brakes ahhhhhhhhhhhhhhhhhhhhh help / info please
- corsa just cuts out
- Astra mk2 front hub/wheel bearing
- Jerky Corsa!
- mk3 astra power stering prob...
- how to remove the steering shaft
- rotor arm on the dizzy, how does it come off??
- Power Steering Fluid Renewal
- which willwoods
- Trouble With Total Closure Fitting Help Needed
- Mileage correction companies
- Annoying rasp at 3.5K rpm
- temp sensor
- astra mk3 gsi time display question
- troubled nova
- Help Please With Fitting My Astra Mk3 Rear Strut
- Fitting Rear Electric Windows in a Vectra
- Greenstuff Pads (Part Numbers Wanted)
- wilwood 4 pot fitting
- Wiring Help needed for mk3 GSi Trip comp!!
- Hydraulic Handbrake Granada Calipers
- Another Lowering Question
- servicing - D.I.Y or get a dealer?
- 40mm drop
- how hard is it to do the following removal/fitting
- Lowering question..
- 2000 'V' Astra 1.7 Envoy TD interior upgrade?
- can anybody shed any light on this?
- snooper s4 probs??
- code 117
- ECUs
- Wishbone replacement-how do I free that sleeve from the bolt?
- Aircon Refill Kits!
- top hat sensors?
- Pulses per mile from a digi dash sender???
- Traction control and ABS issues
- Front Brake grind/cruch NON-VAUX
- fuse keeps blowing
- Vauxhall Frontera 2.2dti 1999
- refilling a chargecooler
- Help!!! ABS fault finding
- Can you change the colour of a digi dash?
- MOT Time
- Vectra Traction Control fault
- Is my car as good as scrap?
- Astra GSI MFD display unit into a 1.4 merit
- ASTRA 1.7tD coolant loss
- How much air in my system!?
- Which is better K&N or Pipercross? And why?
- sterring lock
- CAVY 60mm DROP
- Astra: 3 years old, 60k miles £1200 for a new ECU. HELP!!!
- Slow to heat up
- nova leccy windows
- A strange question...
- Astra Mk3 Banana Pic Request Pic
- o/t Ren clio auto probs
- RWD cars
- Mk3 Astra GSi-External Temp Sensor
- 5 stud vauxhall astra hubs
- MFD (Corsa)
- How far do i dare push it
- Best 16" tyre size for GTE Astra
- HUB/bearing/sensors urgent!!!
- Mk2 Cavalier Convertible
- Running in how many miles
- Aircon Help
- Mk3 Astra front struts/springs advice needed.
- G/box ratios for 1.7td cav/1.7d
- Refilling coolant
- thermostat on v6 vectra
- Vectra Estate Bumper Removal
- severe shakes - got the DTs
- Aldl Connector
- Astra and corsa problems
- me == lucky
- Clock Printed Circuits Melting Itself?
- Getrag 240 Speedo output thread size
- Shouldn't there be vac' pipes going to this??
- Power Steering Pulley Problem
- Adjustable Top Mounts
- Strut Brace help needed...
- astra mk3 1.7tds problem again
- [corsa b] power steering to non-power steering
- opel kadett 76"
- GTE wishbone replacement.
- Calibra Central locking
- Machined hub for Corsa (where can i get 1)
- URGENT,Please help!!
- panel removal
- corsa speedo
- Apex springs with Koni adjustables?
- Rear disc conversion
- TB's Trumpet/Ram tube length
- barb things?
- swirl pot....
- which bits?
- Can anybody help please?
- wat size Mk3 astra front speakers!
- New brakes, same old problem...
- HH plate kit questions...
- Quick Speedo Cable Removal Question
- cliking noise/?
- spring help
- First post.. help wanted.. fixing steering
- Rear disc
- thoughts needed please???
- Thermostat gauge not working.....
- GTE Digidash Kinda Dying
- Silicone hoses...worth it or just for show?
- calibra 1992 16v problem,help me pls
- LED in heater switch
- e.c.u problem
- Boost gauge query
- Reverse light connection
- Central Locking - Lock/Unlock Wires
- Installing ABS into astra GTE mk2
- cavvy diplomat leather in corsa
- external wastegate help needed
- voltage stabilizers any good ?
- corsa heater matrix
- 17tdl knocking
- Vectra GSi brake upgrade on Cav T
- how do i reset ecu
- Temp Gauge, Hazard Lights, Display Panel
- nova 'klunking' noise
- ECU Light Wire (what colour)
- Couple of corsa Gsi problems
- Why would boost get higher with time?
- DHLA vs DCOE
- best v6
- tophat question - silicone hose size??
- wheres best to get a 'live' from?
- Astra Mk3: Setting off the Airbag.
- will a mk2 k&n fit a mk3 cav
- vauxhall corsa revs counter faulty, maybe?
- Compression Results.......(photos)
- corsa floorpan, identical to nova?
- are corsa b and nova steering knuckles identical?
- How to do a Compression test
- silly question
- corsa rally car.
- rolling road again
- Aircon seal refurb cans
- Mk4 Astra 1.7 tds smokiness problem
- Does A Mk2 Back Box Fit A
- takes 2 heats on my 1.7 tds
- exceeding wheel offsets
- Vectra not starting, various ECU faults plz look
- Which brakes????
- creaky wipers
- Stopping black gunge entering intake..??
- pipercross my astra 1.7tds
- Astra GSi ABS Light
- digi dials wont fit!!!
- changing mk3 astra bottom ball joint
- omega v6 into calibra
- Audi TDI - non start - alternator?
- Wideband 02 sensors
- lowering a corsa
- Omega Sunroof Question
- Maybe an electrical problem?
- Tools i`ll need to change the brakes on my cavalier
- Mk3 Cav GSi Trip Computer into Mk3 Astra, is it possible?
- How Can You Tell If A Corsa B SXi Has ABS Or Not???
- request
- Gsi trip computer
- 2.0 corsa (help me keep my missis happy!!)
- How to make a Corsa B handle well?
- vented discs
- Idling High
- Oh no what has happened!!!!
- New actuator but still cr*p boost....
- does ford recaros fit straing on to nova subs
- kangaroo jumping
- fibreglass parts
- Wiper's problem, HELP!!!
- is it dangerous?
- decisions,decisions
- Newbie Here, Electric Prob, Help Needed Pls...
- after doing a conversion
- resetting ecu on 2001 astra
- speedometers
- Fitting wheel spacers, longer bolts???
- astra/Kadett 200tS info
- Lack off acceleration
- New front shocks for corsa, they supposed to push in and out?
- no brakes
- nova overheated 2day
- Top strut probs
- discs and pads....
- Can you re-drill the plate on the hub to fit rear disks to a corsa?
- v6 not running right
- Omega V6, presurising the coolant...
- cav DID temp not working - sensor/wiring ok
- Few wiring questions.
- Another "brake servo" question
- Digital Speedo
- bottom pulleys
- calibra SE7 ecoshed ECU codes
- Final Drive ratios
- Urgent! My car just died!
- cant open my rear pass side door
- Vectra Idleing Problem
- New car trouble
- Instrument panel - calibra
- Wierd Brake Light problem, please help!
- MK3 Astra Trip Computer
- Braking Upgrade
- V6 auto
- Engines
- 2l 16V Brakes
- Read Fault codes but dont understand 2 HELP!!
- Pic question??
- Is my V6 electric or cable speedo
- astra gtw handbrake cable length
- airbox
- astra 1.7 td
- Compression test
- Low Revs
- Cav Gsi Rear Crossmember Chassis Fixing Insert M14x1.5
- sluggish Start
- help needed
- V6 Conversion
