PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Stainless steel bolts
  2. Perfomance Spark Plugs for Redtops
  3. Can I put 270mm discs on my 4 stud to replace 260mm discs
  4. HELP key fob problem
  5. BC lamp
  6. A/C fan - suction or blowing?
  7. alot of resistance
  8. Vectra Suspension
  9. indicators on permanently ???
  10. Mk3 astra 5 stud
  11. how do you test a fan switch?
  12. Anyone with a sri130 engine??
  13. how low can i go?
  14. no voltage goin to side light! any ideas??
  15. engine management light won't go out what could it be??
  16. Mk5 Astra Abs Sensor
  17. Mk3 Astra GSi Handbrake cable & bracket
  18. c25xe chip advice
  19. Corsa Wiring please look!
  20. 2 litre brakes not working
  21. c25xe loom to 1.8 astra gsi
  22. x18xe wiring loom help required
  23. Car wouldnt start what could be ?
  24. fitting electric windows to my corsa
  25. changing a corsa b to 5 stud
  26. 1.2sxi lowering spring onto a diesel?
  27. Brake pad change on Tigra - Help needed
  28. OMP strut brace for Calibra Turbo
  29. Lowering/Bias valve. Help PLEASE!
  30. Corsa B steering knuckles
  31. Do I need to weld it?!
  32. braided fuel lines smelly
  33. Fan Switch
  34. Speedo not working
  35. Impossible to find electrical/oil pressure fault
  36. Let wiring loom.
  37. anyone have an email for arno at eds motorsport germany
  38. FPR fuel pump relays
  39. my van wont start
  40. Changing the rear bumper
  41. Fuel pumps?????
  42. Corsa B Horn not working
  43. Whats the deal with changing the aircon compressor on cali
  44. corsa b handling probs
  45. can i buy an uprated coil
  46. brakes
  47. Hall effect switch cde 93
  48. fan issues, will not active?
  49. vectra sri cdti brakes
  50. temp gauge reading wrong in a 20seh conversion
  51. car not starting
  52. mk4 convertable front windows not working???
  53. whiteline arbs
  54. apexi avcr how do i check my solenoid valve is working
  55. Tow bar for a mk3 astra
  56. c20let hall effect sensor
  57. Secondary Air injection Pump?
  58. I was undoing the positive terminal on the battery and I managed to hit the car
  59. have somebody placement a/c in nova?
  60. 5 studding corsa c
  61. corsa c 308mm brake conversion
  62. Electrical Wiring diagram
  63. Brake Probs :(
  64. urgent help needed with fuel pump
  65. Master cylinder question
  66. swirl pots for fuel
  67. BumpStop
  68. Anyone running Alloy Rack Mounts on a Nova?
  69. colours of wires of c20let 1st gear switch
  70. Fuel pump to twin relay conversion
  71. central locking fault zafira 2L DTI 2001
  72. Wiring Amps into car
  73. misfiring!!!!!!!!!!
  74. MK4 Astra alarm after flat battery
  75. corsa c20let missing on boost
  76. Engine Loom Wires Spare After Conversion?
  77. c20xe starting loom problem, earth?
  78. Zafira Wiring Diagram
  79. can i use a phase 4 ecu to run phase 3.5 spec
  80. Converting a 2.0 Calibra to 5 stud?
  81. tapping out for a m12 bolt
  82. help! let immobiliser problem
  83. Best spark leads?
  84. Veccy B - Keyfob not working.
  85. What Brake Pads for Track use on 288mm V6 Brakes
  86. ABS System Removal
  87. Mk3 Astra Van Lowering!
  88. EML and starting issue
  89. cav x20xev crank sensor help
  90. indicaters stopped working
  91. vibration on braking
  92. Bleeding Willwoods
  93. confirm these spring b4 i buy....
  94. Astra VXR aux/ I pod connector issue HELP please!
  95. Tigra - rear wheel bearing play - how much is ok?
  96. Mk3 astra Steering Noise?
  97. Astra GSi Mk3 Front anti roll bars
  98. help needed to wire up temp sensor
  99. Astra G Wiring Diagrams Please
  100. Zafira GSI Towbars
  101. are evo 5 chips reliable
  102. central locking fault zafira 2lt dti comfort
  103. wideband afr gauge
  104. corsa xe type two mounts
  105. clunking sound???
  106. Wires in Electric Power Steering
  107. cav v6 volt and oil guage???
  108. cav mk3 stereo wire colours?
  109. Will This ECU Work ?
  110. Please help witch spark leads????????????????????
  111. Part number requried for Astra Mk3 GSI front bumper part
  112. Testers wanted for new ABS Amplifier product I'm selling
  113. crankshaft sensor
  114. What Brake Pads For Willwood 4Pots?
  115. Astra gte ignition switch renewal
  116. how to tune ride height and wieght distribution AVO coilovers
  117. Removing pins from electric plugs
  118. Is it possible
  119. v6 rev counter
  120. Fault between relay and fuse box?
  121. corsa b instrument panel
  122. Info on lowering a mk3 van...
  123. Veccy B - Electric door pins???
  124. new alarm fob?
  125. 5 stud conversion on mk3 astra gsi
  126. tyre wearing on inside nova
  127. new ebay rev counter ....
  128. Now this is a proper charge temp reader
  129. Gsi Corsa C20xe ABS issue
  130. can a standard xe fuel pump take 300 bhp
  131. Corsa rear disc brakes - how to?
  132. How to get inner tie rods off Vectra?
  133. where is fuel pump relay on a corsa b 1.2 sxi
  134. 99 Omega ign. barrel / imob questions
  135. Speedo Miles out Help
  136. What rad best replaces the cali turbo one with stock cooler
  137. 2.5 v6 chip
  138. x16xel engine fault code
  139. Corsa fuel pump fuse location?
  140. Exhaust help please
  141. are saenz shot peined con rods any good
  142. rear calipers
  143. lowered car scrubin
  144. Steering Rack
  145. LET starter motor wiring?
  146. Equal length setup mount bolt size
  147. Knocking from the rear
  148. speedo problem
  149. corsa speaker problems, is it the speaker or the wiring?
  150. Position springs back
  151. Flashing EML on Ignition
  152. Urgent help required - replacing broken window
  153. Help needed!!!
  154. corsa b dash loom wires
  155. corsa lmf rear disk convertion kit
  156. what's the front brake pad minimum thickness on Tigra?
  157. By-passing secondary air injection
  158. Mk4 Astra top mount question
  159. Nova hubs into bearings using freezer+oven?
  160. converting corsa drums to discs help
  161. Astra Coupe Turbo Squeek/Grinding Noise
  162. v6 4 stud brakes
  163. Which Alternator?
  164. astra mk2 (kadett) turbo water radiator
  165. no live
  166. Recommend me some suspension...
  167. differences between cav gsi 4x4,cav and calibra turbo rear transmission assembly?
  168. temp get to point when fan kicks in engine stalls
  169. cant get petrol in the nova
  170. fitting strut brace om mk3 astra
  171. Help - keep losing power to fuel pump vectra
  172. corsa auto
  173. airbag plug which way round ?????
  174. mk3 astra gsi suspension ?
  175. coil pack feed
  176. does apexi avcr work of the revs or speedo
  177. 2ltr hub re-think
  178. HiD kits. any good??
  179. What Suspension kit for mk3 Astra TD ?
  180. Help - Wiper Fuse Keeps Blowing
  181. how to cover up ecu
  182. problem when enginge is running
  183. steering wheel not right after xe
  184. c20let ecu codes 13 and 113
  185. Vauxhall Nova Driveshaft Bearing....
  186. c20let corsab steering rack....
  187. xe running Ford Eddis setup with blackbird boddies
  188. ECU Identity help please
  189. Fits EPS of Corsa C in a Corsa B?
  190. Central locking on Corsa b keeps unlocking
  191. mk3 astra coilovers
  192. Removing wires from instrument panel
  193. Where to get polyflex bush inner sleeves from
  194. vxr nurburgring wiring
  195. slim line fans!
  196. master cylinder
  197. REC and Fitting a Bypass relay
  198. seat belt - replace
  199. Brake Master Cylinder
  200. Wheel wobble at around 60mph...
  201. slider pin rubbers swelled
  202. astra coupe display
  203. F28 HELP
  204. LMF Total Close wiring help
  205. Sound system (Remote Wire)
  206. What Clocks
  207. nova tempature gauge
  208. 2.5 v6 disc but as a 4-stud.....
  209. Nova Electric Windows ...
  210. changing to 5 stud
  211. Calibra Dashboard
  212. 20V fiat discs
  213. why would this be off?
  214. vectra rear and front brakes. HELP!!!
  215. Astra G Power Steering Help
  216. astra mk4 1998 no spark and no fuel
  217. c25xe pipes from inlet
  218. X20XEV wiring to corsa B
  219. calibra v6 springs
  220. mk3 astra 1.6 spi front disk size?
  221. Vectra C can't start after battery removal
  222. wiring fuel pump to a switch
  223. c20xe manifold on x20xev
  224. corsa camber isue
  225. Calibrating Clocks
  226. MK4 Astra hub size?
  227. corsa b rose joints
  228. Vectra Rear Wiper
  229. Goodridge Banjo bolts's pitch/size
  230. astra gte fuel pump relay
  231. mk2 astra power steering????
  232. Nova wheel bolt dimensions?
  233. removing the valve from the aircon connector on calibra turbo
  234. air/fuel gauge
  235. no spark from ht leads
  236. Corsa XE wiring issue
  237. cav gsi v6 chip
  238. cav gsi trip computer
  239. coil went pop now car can get a spark ?
  240. Alterator Problems
  241. X16xe ecu probs
  242. mk3 astra 1.7td lowering kits ???
  243. corsa/nova steering wheel boss the same?
  244. Felicia suspension feels a bit... wooden.
  245. mk3 cav clutch cable
  246. Multi timer location?
  247. External wastegates (Tial)
  248. Crankshaft sensor?
  249. Cavalier 4 stud to 5 stud conversion
  250. wiring help
