- 1.7 td Astra Van problems (Lots!!!!)
- 1.7d timing
- Died?
- Braking problem
- digi dash
- 2.5 v6 auto box problem
- Astra Topmounts
- MFD Question.
- quick calibra suspension question
- f***ing astra
- temp guage & speedo not working
- Corsa 1.2 Cheap brake upgrade?
- Car cutting out when revs drop....
- 1997 (R) Vectra 2.5 V6 Auto Wiring Diagram?
- anyone know what this is off?? (alternator)
- Digital Dash Testing
- charging
- What part is this? Part No inside...
- ARP Bolts
- mk 2 astra elec windows
- Anyone know anything about older Ferraris?
- Suspension just too hard *HELP*
- Gauges
- Tim Voltage Gauge
- Pedal box in astra or corsa b???
- rear disc conversion
- does anyone know
- V6 vectra Alternator HELP
- Brake troubles
- Symptoms of a duff CV joint ?
- Broken!
- gsi astra
- 2.0 conversion, is the car strong enough?
- Boost Problem
- cav code 73 low voltage
- digi dash bulbs
- removing alternator pulley
- Stil problems with the corosa (cutting out etc)
- my local garage has broke one of my willwood callipers! help (pics)
- octane module
- '98 cavalier front end grumble
- MBE Ecu wire up.......
- Caliper Piston Stuck
- astra mk3
- brake bias
- Attention all corsa owners
- help required quick
- Ashley advice lol....
- A/C Problem?
- wipers
- Method of removing a steering wheel without a puller
- E16Se
- How do you remove rear seat hinge
- Astra GTE Lock Set
- fitted 305mm 4 stud and brembs to a cav
- Mk3 Cav Bulb Check Unit Diagram
- Where to get TAS mounts?
- Brake problem
- back box
- ** Nova GTE central locking and leccy windows into Corsa B?
- anti trap windows?
- astra mk3
- Weber help please
- dis pac info needed
- elec problem
- any one point me to where i can get hall sensor
- Swapping ECUs
- *Dilema* After my close call antics...
- Best suspension
- omega 2.5 v6 water leak
- Steering lock
- Tuning a Astra 2.0 DTI
- air con problem
- Suspension Failure Big Time!!!!!!
- Help i need help!!!
- how do i fit brembo calipers
- air bag light flashing..
- tigra steering wheel removal
- Rad hoses any good as boost hose?
- Cone Vs Panel
- Magnecor KV85
- un-balanceable wheels
- pully
- Vauxhall TD Lump Tuning
- V6 HT leads
- Weird Sound!
- vectra rear central locking
- speedo sender thingy
- Best HT leads?
- Brake Booster
- brake questions
- Noisey top(?) end on 8v (vid to watch!) Any ideas?
- ideling problem
- ECU Compatibility
- PAS & AC in same 1.6 16v
- 2 litre conversion ???
- Braided brake lines
- Where to buy a set of Koni Shocks...
- pulsing electrics
- Just to confirm..
- Mk4 Astra blower problem
- *** Corsa B electronic steering column on Non-PAS Corsa B, Fitting?
- Speed signal wire/Cruise Control
- Tech 1 with all the cartridges
- Lowered springs + standard shocks ?
- cav front windows
- wide tracking a nova?
- cold air
- astra mk3
- Whats the easiest way of removing astra side repeaters?
- broken speedo help
- Ecu
- boost problems?
- calibra warning light
- will cav brakelines attach to a brembo caliper
- How to prolong..
- bulb gone in dash switch
- does anyone own an old 3 series bmw (2l or below)
- Fan not coming in .
- cav mk3 rubbing tyres
- Cavalier power steering
- Door latch gen needed
- Will my coupe fail its MOT without any reverse lights?
- power aerial wire colour
- bugger'd me veccy (again)
- Ecu Diagnostics on PC
- astra mk3
- aftermarket ECU's. whats what?
- How do you change an electric aerial?
- Anyone drive a new 1.7CTDi Astra?
- cr question for the experts
- MK3 Astra Suspension Opinions
- Electric Mirror switch as Electric Window switch
- astra mk3
- Foglight bulbs ??? MK2 GTE
- Knocking by braking and accel.
- Fault code 41 for a long time now
- which ignition ecu
- Abs Sensors
- astra 2l16v
- Turning over but not starting.
- knocking noise when going over bumps..
- ASTRA GTE Wiring prob??
- rear springs help
- Brakes
- Noise going round corners
- speedo problem... help???
- Air Con ?
- acumalater problems
- Astra GSi Airbox
- emmm
- Does PAS without without much fluid smoke?
- boost guage (content warning will be added later)
- more power steering
- Astra Mk3 lamp brackets??? Where??
- Vernier Loads
- Twin 40's information needed
- Lifter cleaning - What to use?
- which wilwood calipers?
- Changing Brakelines
- Following on.. electric problems
- Air conditioning
- heated screen aerial
- Mk3 Astra Suspension parts
- Corsa B Speed Pulse on the box
- help!!?? frontera side lights playing up...
- Corsa C Speed Pulse
- Bush bike speedo for Kit car?
- Advice Needed Please
- corsa gsi abs unit. which pipe? (pics)
- magnecore kv85 leads
- Converting Astra mk3 to 5stud
- Mk3 Astra LS Handbrake Adjustment Help?
- Where would you buy these from.....?
- Pug 306: Rear brake drum removal
- help digi dash wiring mk3 astra?
- advice on vectra V6 SRI
- calibra electric funroof
- BCP7EVX NGK Platinums
- Saxo Brake
- help
- Urgent help needed please
- which suspension for 2l Corsa??
- Whats that smell???
- help me please car's gone dead
- Silicone Vacume Hose
- Will a six speed fit....
- How to remove Corsa clock?
- had the porous fix.........putting it back together?
- what size of wastegate ?
- Air Con Filling
- Still havin problems with the corsa.. can you help please
- calibra boot lock ?
- re-circulation
- I Need Ur Help Please Cosa Questions
- whats best to underseal a car?
- Weird ticking noise...
- Door handles
- Mini Motos
- Best suspension set-up...
- Coolant temp help
- any difference in MK4 astra shocks/springs?
- quick question
- this is funny
- wots the wiring to change a anologue clock to a digital clock on a cavy?
- help
- Fitting Air con
- can anybody please help????
- Astra Merit Electric windows from scratch - Help needed!
- Noobie from the U.S. with Noobie questions
- changeing the thermostat on a 1.7tds astra
- Arse, mucho help needed
- radio codes
- Flamer kit installed, but no flames
- witch wilwoods?
- all electrics flashin'
- steering wheel trembling
- Corsa Strut Brace
- Does any ony no how to clear fault codes???
- corsa managment light
- miss firing quick question
- digi dash will not read speed correctly
- what is disc offset
- Part No Check On EPC please
- 20seh into corsa sport
- arp studs
- psp
- Ford question, airbag light flashing?
- Bigger front brakes on my mk3 astra
- Re Shelling?
- Gsi fog lights....
- Best Way To Remove Nova Rear Window Surrounds
- Howdy :) + Question
- Corsa Emmisions
- nova gsi running odd..had mishap
- help digi dash instuctions for mk3 astra
- Mk 3 brake woes
- power steering query...
- clonking noise from spring and strut
- rev counter change from 4 cyl to v6
- vectra fault codes
- Whats actually broken here?
- How hard to hit steering column before breakage?
- throtle cable
- simtec 56.5 fault codes
- Astra GTE Fault codes
- diag port?
- How can u tell if an ecu if faulty
- faulty fault codes reading?
- Omega Light Switches
