- VDO GPS in Opel Vectra's
- Fag lighter blowing fuses?
- heater lights
- Very Quick Hep Needed
- cant get 17 isuzu running!
- V6 cooling question
- CD Changer Fuse
- code 24??? speed sensor
- Nova springs on an Astra
- PiperX filter
- Anti Roll Bar Bushes - Mk3 Astra Gsi
- fault code 37
- astra mk3
- corsa pas pipe connections
- mk4 astra v6
- removing tow bar...
- Autobox Diagnostic question
- Zafira GSi owners and Vaux Employees...
- wilwood dinalite
- Nova Hayabusa
- Cost of drilling 288mm discs to 4 stud
- spi to mpi
- coolant tank:spic & span
- mounting rear strutbrace
- C24NE in a Calibra.
- corsa pas pipe bust, any solutions?
- Vauxhall Astra mk3 -front hub bearing-
- Lumpy Astra G
- What anit-freez do i use in a 2000 Tigra??
- Astra GTE ABS Not Working
- Rear brakes vented ?
- calibra washer bottle
- adjustable konis on hatch v6.
- tigra spluttery
- Which wires for EM diagnostic? ASAP
- Urgent Answer need Quick
- 0.4bar is my max boost :(
- corsa gsi knock sensor
- Rev counter feed from electronic ignition
- Digidash Question
- corsa weights
- Hub nut tightening sequence
- astra mk4 brakes 'juddering'
- Slight Miss When Cold, Corsa Gsi
- Can I lower this car only by changing springs?
- v6 brakes fitted
- whats this?
- lambada sensor
- Wot size spanner do u need for the rod on a shock....
- Mk4 astra struts!
- falut code help
- in need of sum help please
- Corsa B 1.0i 3cyl Electrical Problems.
- i need a space frame help
- Omega Imobiliser problems.
- Calibra To Corsa Wiring
- Lowering the Rear end !!
- vectra gsi owners
- metal bracket
- Crinkly brakes when steering and braking
- Timing Disc.......Got has anyone :)
- Nova lowering springs fit a mk3 Astra?
- changing corsa 4spd box for nova sr 5spd
- FK Silverline x Vs Koni Yellows
- Cool running thermostats??????
- How much gas can i run?
- Does Calibra leather seats fit Cavaliers?
- bigger brakes: brake geometry question
- Paper Clip Reset Jobbie
- Brake Squealage
- ignitions dead, help!!
- Astra and Cavalier Compatability
- How to increse the compression ratio?
- Central Locking HELP?! - Driving me Loopy :(
- Vectra Multi-timer?
- Corsa B Lower Front Strut Brace
- How do u change the bulbs in a Tigra/Corsa MFD???
- Silkolene Pro S 10w-50??
- The way overboost works?
- Air Flow Metre Adjustment?
- ffs nothing is ever simple. corsa brake caliper problem. slight rant inside
- Close or Wide Ratio?
- Astra 3 Shock Absorbers
- Vectra Multi Changer problems
- Changing hand brake on 1.6 vecta-can this be done without taking off the middle box??
- Tyre question...again
- failed emissions. help!!!
- 2.0 ecoshed
- Does anyone know?
- Struts?
- keep brakes cool
- Mk3 Rear Seats
- Changing central-console lights - How To ?
- can someone show me which pipe goes to my icv? (pic)
- Car sittin too low - can I raise again ?
- Wolfrace Alloys
- Astra Sport
- Dodgey wheel...
- corsa GSI brakes
- Baffled by fault codes on 96 astra MK3?
- mk1 astra spotlight grill wiring.
- bigger brakes: brake functionality question
- 308mm brake question
- Delocking a car with dead locking
- Omega 2.5 V6 Alarm problem
- Weight of struts and rear shocks
- Mk1 astra 16V conversion, few questions...
- Duff ABS?
- 2.0 8v cheap mods
- Nexia/astra mk2 help
- Tyre Pressures on 19 inch wheels??
- Astra 1.7TD (17DTL) - Economic repair?
- info required on Immobilizers
- nova sport
- unwell calibra
- 18e
- cav gsi struts
- CV Joint
- V6 Timing Kit/Tools
- cutting out vectra please help !!!
- Timing chain problem!
- What does this mean on my dash?
- Cavalier SRi Suspension
- Half Broke M2.5 ECU? or other strange fault
- Urgent, please help
- Error codes - Car died earlier
- boost on Zafira gsi
- where is my icv??
- Banana pic of tie rod ends
- Perfromance Thermostats
- Taco hookup
- what would cause my hub to do this?????
- MV6 Loosing coolant
- biggest brakes behind my 15" irmscher wheels?
- Smoking
- sri vs mpi
- bannana request
- V6 Intermitent start Problem - AGAIN
- Senator ABS warning light!
- Mk3 gsi 160mph elec/mech speedo drive?! ABS?!
- fitting front calipers
- Replacing rings: 'idiot's' guide needed!
- cavalier temp gauge not working
- Wastegates and S13 Manfolds....
- cav electric arieal testing with no stereo
- how to change h/light bulbs in 02plate vectra
- Partco for nova conversion parts?
- side repeaters
- Need 2 no!!!
- Dizzy into DIS
- Nova firing on 3 cylinders when cold???
- how big of a job???
- Strange rolling road result (and crap)
- Air Horn
- How bad is this?
- high pitch whistle/whining noise on cav
- combo 1.7d to be a 1.7td
- fault codes - what do these mean?
- Help with my Toyota...
- using alarm with deadbolts
- Convert
- Help cav heater NEVER blows warm air...
- lcd dash rev counter in a v6 nova help
- Bugger
- MK3 Cav electric mirror motors
- Vectra remote central locking
- Boost levels gotten lower
- Nova Brakes / Brake Servo Unit
- problems! rev limiter cutting in to early!
- Size of Vectra gsi front discs...
- Yet more problems - PAS
- threads wrung in chassis! help!
- deadlocks
- door handle
- Quick question: will H&R sport springs off a Cav fit a MK3 Astra ?
- Rev Counter Not Working
- 2.0 16v nova problem,PLEASE HELP!!!!
- Brake question...
- fastest gsi mk4
- what is this warning light for?
- For those running 25+psi boost
- how to wire digi dash
- omega digital readout
- judderin
- Cheapest place to buy brake hoses
- corsa sprint c fitting guide.
- Retro fit fogs
- fog lights
- Cheapest ICV??
- EBC Discs quick question
- how to guide
- Aerial
- ICV quickfix
- Leads for V6 - what and where from?
- speakers
- v6 in astra
- hose trouble
- just got my pro tec mounts
- cav seats in a mk2 astra
- quick question
- Nova question
- astra mk4
- Nova Gte, Flat Acceleration Help!
- Vauxhall Zafira Airbag Module
- corsa steering wheel
- abs rear discs gte 16v??
- Brake lines, where to.
- digi dash probs
- Light on in dash - help identifying?
- slow to return to idle
- Cav mk3 GSi / SRi 8v Rear Disk Setups
- Electric mirrors mk3 astra gsi
- Idle prob
- New Astra Questions.
- Help with Air Tools
- aldl cable
- 95 or 98 RON
- wats appenin with my car lol
- ecu
- not idling
- rear wheel drive idea
- Is it a car? Is it a lighter?
- Nova Hayabusa
- EPC problem - unauthorized access..
- cally interior into corsa?????????
- What will a 16v cally electric sunroof fit?
- Corsa Reaction to drilled air box?
- A few corsa sport questions
- electric sunroof conversion
- checking aircon gas level results and questions..
- Omega 3.0 v6 into mk3 Astra??
- sfi box replacement
- corsa/nova mount?
- Astra MK3 LSi Front Fog Wiring?
- Vibration!!!!!
- not a PERFORMANCE VAUX but a vaux all the same!
- Fuses Blowing ??
- Red light on Mk3 Astra Hazard Switch??
- Astra GSi ABS ECU fault - code 55.
- Corsa C
- Heating Problem.
- redline
- Corsa V6 Brakes
- cant fit me spot lights
- mk4 astra rear brakes
- Digital dash - speedo not working
- Knock Sensor Problems
- Springs
- Nasty squeek
