  1. Please look (Speedo question)
  2. stripping a astra for drag racing
  3. astra sdti info
  4. help for my onboard computer!!!!
  5. starting from cold
  6. SFI BOX bolts different sizes??
  7. Problems Starting Corsa
  8. Problem Starting Corsa
  9. Astra mk4 service
  10. Identifying Isuzu 1.7TDs and 1.5TDs...
  11. Silicon Hoses
  12. help needed with 4 pots
  13. please help
  14. Calibra 16v - No Foglights Working
  15. were to find the diagnostic plug on a nova gte
  16. Code 39 after fitting AF gauge??
  17. venier pulley's setting ????
  18. performance help...
  19. ecu and immobiliser
  20. calibra gauges
  21. FAO Mark T!! Mk4 rear hubs on Mk3?
  22. redline
  23. Urgent help needed!! AF Guage Fitting!
  24. Hazard Warning Switch
  25. Astra coupe trip comp
  26. worth it
  27. lowering spring question
  28. who can get my corsa running??!!
  29. Anyone work for Ford??
  30. how low can i go?
  31. Manual Help Wanted. Prepared To Pay Well. Or At Least Advice!!!
  32. astra gte a1606 + window closure
  33. wierd speedo
  34. towbar electrics help
  35. Nova GTE F13 vs MK2 Astra F13
  36. Astra MK2 GTE central locking
  37. tyres?
  38. Astra GSI (mk3) rear bearings/hubs!
  39. Removing Air Con from Corsa B
  40. Cav mk3 disk rear beam on mk3 astra
  41. Topmounts
  42. frontera 2.4 i slow
  43. big brakes 15" wheels?
  44. corsa C central locking
  45. v6 calibra rear brake problem
  46. what torque settings
  47. Brake pipes.......
  48. vauxhall parts download
  49. Thumping noise coming from the rear of the car when braking?
  50. My Nova is Dead? Or is it? Help What Do I do? Advice Appreciated
  51. distributor timing
  52. need someone in the south yorkshire area to look at my corsa
  53. astra gsi brake calipers
  54. stereo wiring corsa
  55. nova gte
  56. ECU warning light
  57. Worth getting Spax adjustables?
  58. Rear disks conversion and strange rumor
  59. timing chain
  60. Astra G MK4 Suspension and Handling improvement
  61. Wiring up this LCD dash on ebay to a Electirc speedo on V6 Calibra
  62. Pain in the arse
  63. What Size brake discs does my Tigra have??, R they the same as Corsa GSI???
  64. vectra central locking again !
  65. is this a 2.5 or 2.8
  66. cav boot black panel. hatch saloon different
  67. What are these mounts called? Joined to hub/bracket/body
  68. under performing sri
  69. 2.0l di starting probs!
  70. alternator
  71. astra mk3 mfd temp
  72. Calibra Dash Lights
  73. part numbers for discs?
  74. Problems with idle control
  75. Its Leaking! But what is it?
  76. Heater Motor & Resistor
  77. Advice on Plugs - Corsa sxi 02
  78. Alarm Prob - Can anyone help please?
  79. astra pulling to the left
  80. Tigra shafts fit corsa?
  81. Vectra Handling
  82. cors B 1000cc 3 cylinder electrical prob.
  83. quick Q!
  84. Clonking on steering from left to right.
  85. Help with buying a vectra
  86. trip computer 93 astra gsi
  87. Poorly car.....
  88. Spare parts online
  89. Omega towbar wiring
  90. Angel eye's
  91. MBC Boost pressure on Ph2??????????
  92. Boost query .
  93. alt question
  94. Alernative brake servo for Mk1 Astra GTE.
  95. Ok, I'm a bit stuck
  96. Gte digi dash into mark 3 astra
  97. wots gauges can i have???
  98. Senator Tuning?
  99. How do you remove the wires and pins from a trip computer Plug?
  100. Symptoms Of Sensor Fault
  101. CV boot
  102. Vibrating Nova
  103. Electronic speedo read through the ABS??
  104. accelerate and a starnge clanging noise starts
  105. Looking for a Vauxhall Mechanic Southampton/Hampshire
  106. help
  107. Astra mk3 Mc pherson upper spring seat
  108. Astra GTE
  109. Corsa Sri Tuning - Help !!
  110. Help - Alarm probs!!
  111. what colour wire for the hazard lights? vaux corsa/tigra
  112. Astra g Rear drums to Discs
  113. Ignition only management
  114. Bass effecting EM
  115. Standard FSE
  116. Strut tops
  117. astra engines
  118. thermostat replacement on Cavalier V6 (1994)
  119. ODBII socket on Vectra
  120. What's this? Electric window motor thingy.
  121. Whats the difference between..
  122. Time of the month
  123. Will this fit?
  124. astra digi dash in cav gsi
  125. question!
  126. Can you buy a temp switch that kicks in earlier???
  127. vectra ,problem
  128. Car died under load
  129. front suspension question
  130. Battery Clamps
  131. Vectra Tapping tractor noises
  132. silkolene 10w 50 pro s any good??
  133. Poor running help!!
  134. vauxhall specialists in scotland??
  135. Can you shorten gas struts?
  136. Cavalier mk3 (1995) 1.8 brakes
  137. Vectra V6 Auto to 6 speed Manual conversion
  138. Astra Mk4 cuting out
  139. Part number Check
  140. MBC fitting help please
  141. Strut brace to fit 2Lt 8v Nova
  142. Cav Sri dead!!!!
  143. Digidash Wiring and Corsa B
  144. Odd Carlton electrical problem...
  145. cavalier glsi 1598cc is dying please help!
  146. Nova 1200cc Air box
  147. ARB Bushes
  148. temperature sensor
  149. can anyone help or had this problem
  150. Brake question...
  151. 2.0 16v in corsa c
  152. ** Early Corsa b steering columns...are they the same?
  153. Corsa Wheel Bearing?
  154. 2.0 8v corsa conversion
  155. 7400 Rev limiter with stock rod bolts
  156. alternater or battery
  157. corsa rev counter
  158. error fooking code again !!
  159. why i wonder?
  160. anyone got a simple answer to this one???
  161. battery
  162. Almost a P2 Cavvy!!
  163. 2.0 16v Nova Coolant Pipes
  164. over boost
  165. amal bypass.
  166. plumbing a charger
  167. 3.0L into a V6 Calibra
  168. Converting MK3 Sport to Electric Mirrors
  169. cav/vectra parts
  170. ASTRA COUPE 2.2i NEED HELP PLS
  171. fitted new core plug now it leaks
  172. slow idea
  173. Changing MK3 astra front hub bearing, will a mk2 strut casing fit for now?
  174. Speedo help
  175. Where to buy new sensors
  176. nova max speed
  177. Senator Digital Dash
  178. reversing lamp switch not working
  179. MK3 Astra leccy sunroof
  180. lowering a corsa b.
  181. Rear Disc Dilema?
  182. corsa c clocks into corsa b???
  183. wire in foglights on corsa sport
  184. brakes on a v6 calibra
  185. Courtenay Springs ?
  186. vauxhall tigra - adding remote entry central locking
  187. Suspension Mount Bearings
  188. Front spring removal without spring compressors
  189. Assistance possibly required - Mk1 Astra
  190. V'all Omega alarm fault
  191. Dodgy Idle
  192. Central locking problem??
  193. sri springs
  194. Corsa car insurance!
  195. mk3 astra suspension
  196. *Dilema for M.O.T.*
  197. Central Locking is Haunted
  198. Calibra Digi Dash
  199. Astra Strut tops
  200. confused about ALDL plug and code..
  201. throtel body the same???
  202. 4 pot callipers
  203. All Koni suspension users..
  204. Do I Change
  205. Sealed bearing
  206. Non-ABS cars getting ABS Hubs.... (MARK T PLEASE READ)
  207. Aircon question
  208. NGK plugs, what do they fit?
  209. help me
  210. is there any 1
  211. Astra g projector angel eyes wiring
  212. Veccy starting trouble
  213. Time for a service???????
  214. 4wd mk2 astra is this possible?
  215. piper cross i.kit
  216. fiesta vs astra
  217. Not as quick as it was?
  218. Cr*p brakes on Vectra
  219. 5psi of boost .
  220. Brakes..........
  221. to much hot air
  222. Spaceframes
  223. What size thread, disc to hub bolt, 96 Cally T ?
  224. Astra mk4 dash dials into Astra mk3
  225. Can anyone help please (Remote C/L) Vauxhall Corsa
  226. Anti Roll bars
  227. 150 amp Alternator..
  228. Can anyone recommended....
  229. Carlton GSi 3.0 24v Performance details
  230. Heated seats, wiring???
  231. bloody isuzu 1.7d
  232. ford fiesta hub nuts
  233. dash lights
  234. Whats this connecter?
  235. Replacing Cavalier Gsi standard suspension for all round TA Koni's What tools ?
  236. Irmscher suspension springs. whats your opinions?
  237. fault on digital speedo help
  238. DIY Electrical cutout/anti theft???
  239. Cavalier V6 Thermostat
  240. help needed
  241. Attention all vauux owners!
  242. Senator AUTO cutting out!
  243. Noisy Big End
  244. nova heated screen
  245. Lost code on CAR400 and Vauxhalls code didn't work
  246. wiring diagrams
  247. Are you supposed to uprate top mounts?
  248. corsa problems - really really bad running. longish post
  249. Would this mod work?
  250. Vectra Rad dimensions?
