Google
PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165
  1. will a...
  2. Rev Counter packed
  3. added cruise control to a 1.6 16v astra g
  4. NGK Iridium
  5. Spec differences for Vectra 96 and 99 models
  6. ** Grinding from front on hard cornering - C.V fooked? **
  7. Quick K & N question............
  8. starting procedure - v6
  9. rover 400 immobiliser
  10. wiring diagram
  11. Nova SR engin probs
  12. Calibra V6 speedo problem! advice needed
  13. Converting to distributorless ignition?
  14. Tire wear problem
  15. Corsa not heating up properly
  16. help
  17. Mk1 Astra 5 door
  18. Universal Electric Window Kits???
  19. Can i cahnge the battery in a Vectra key fob..
  20. GSI Running probs...
  21. vacume leak
  22. susp help needed plz
  23. Total Wiper failure - GTE 16v
  24. fault codes
  25. trouble with dash warning lights
  26. cavalier 2ltr sri help !!!!!
  27. 16sv mods
  28. Wheel Wobble/Vibration
  29. help needed plz
  30. front wishbone bush HELP....
  31. Bit of help please, Car wont idle
  32. Nasty noise from front suspension when steering...
  33. Puzzled about my emission test results
  34. Vectra main beam stuck on!!
  35. quickrack bearing Q
  36. Will a corsa strut brace fit over my 2.oL lump??
  37. HELP URGENTLY NEEDED Frustrating ignition problem ...... MK2 Astra
  38. vaux wheel bolts..
  39. vectra related questions. HELP PLZ
  40. afew vectra related questions
  41. How easy
  42. Picture request - back of Cavalier clocks (facelift)
  43. Reversing lights
  44. ECU trickery
  45. Traction Control Question
  46. Mk4 Astra ABS Query
  47. Tranny problems
  48. Brake problem Nova SR
  49. 16sv em light
  50. seam welding bay???
  51. Astra mk3 digidash
  52. Lower springs on GTE 16V
  53. much for cv joint
  54. Cav reverse lights
  55. ecu help
  56. Suspension Swap on ASTRA MK2 GTE 16V HELP!!!!!!!!!!!!!!!!!!!
  57. 2.0 + corsa = :) ?????
  58. How do MBC's work?
  59. Half A Cac
  60. interior roof rattle
  61. willwood brakes
  62. what do u think
  63. Changing FRONT shocks
  64. Cav 8v Tuning
  65. Astra mk 3 Koni kit
  66. I>d this x.e part and tell me what it does please!!!
  67. astra downpipe question
  68. Servicing help
  69. Cav GSi shafts on a Corsa 16v Conversion
  70. knocking noise..
  71. ICV problems again
  72. Cavalier - Auto reverse cutting in on front window
  73. immobilser/ECU
  74. brake caliper rebuild kits
  75. seh into mk3 astra electrics
  76. bleeding order for a nova..
  77. 2.0 into mk3 astra
  78. Modded Isuzu Guys where is your.......
  79. omega electrical faults
  80. Window Motor ( Rear )
  81. will mk2 seats fit a mk3-astras?
  82. Led's in Switches
  83. Running bad
  84. Bloody Brakes .... :(
  85. Clifford Concept 50 alarm help
  86. Would it be Ignition Module..the problem?
  87. wtf is my nova doing?
  88. Plug on v6
  89. nova front wheel bearing removal
  90. Help I'm Freezing!!
  91. Nova Sri Will not run right
  92. Brembos n 16s
  93. 5 Stud Dilema (NEED HELP)
  94. air flow increase
  95. is this possible (brakes/abs related) ?
  96. Replacing Cooling hoses with s/s - Alloy tubing
  97. air con rad
  98. Anyone ever worked on a P reg Escort Van?
  99. No Heater Blower But Theres Hot Air - Help!!!!
  100. Alternative alternators for nova?(100a+)
  101. how hard is fitting rear brake discs on a mk3 astra sport?
  102. Corsa thermometer overreading
  103. Help me get my car going!!!!!
  104. calibra cv joints.
  105. Low idle issues
  106. springs
  107. white smoke
  108. The correct coolant temp sensor
  109. Vectra TD Help
  110. Corsa rear wash wipe
  111. Boost problems
  112. vec b front fogs
  113. Zafira GSI - 'Coolant Level' CHECK ???!!!
  114. Scorpion system?? Advise needed
  115. GTE fast Idling
  116. Inertia Rolling Roads
  117. Corsa overheating
  118. Quick / easy question!
  119. oh crud no brakes...
  120. Vectra issues
  121. Nova CV Joint!!
  122. koni adjustable question
  123. whys my tempature gauge..
  124. Central locking probs
  125. Part number for Bulb holder?
  126. The start of the killer
  127. Bald inside tyres
  128. where is the glowplug relay
  129. Vauxhalls with Traction Control
  130. c30ne Tunning..............
  131. central locking problems
  132. Central locking relay – Where????
  133. v6 ignition amplifier
  134. Suspension kits
  135. Flat Spot - '51 Astra 2.2 SRi
  136. cav sounding like a bike
  137. Corsa sport timing marks????????????? Urgent
  138. Heater Controls gone wrong!
  139. electric window problem
  140. digi dash lights problem
  141. Bottom pulleys
  142. Castellated Nut Mystery
  143. help please anybody
  144. Rev Counter Is Madder Than Hannible Lector!
  145. Wiring Diagrams - Corsa/combo
  146. Vectra Locks
  147. calbra 8v knocking at 2500rpm
  148. bit off topic but
  149. Cavalier Rear Electric Window Prob
  150. Help wit battery light??
  151. fan switch
  152. power steering
  153. springs
  154. 3.0 v6 rebuild
  155. Square to round adaptor question
  156. Improving MK3 Astra handling without a drop ......
  157. how 2 clean icv
  158. Help!!!!!!!!
  159. ebay link tat or not?
  160. Fault codes, paperclip test
  161. Knock sensor plug (red)??
  162. mk4 astra fault codes
  163. 2000 Astra 2.0
  164. how do i disable ABS on a cav gsi??
  165. 2.0
  166. Cesaro zorst info
  167. Raspy Enigine (Mk3 Astra GSI)
  168. Nova Sunroof Help
  169. Cav 2.5 V6 in2 Astra! *help*
  170. corsa cant pull away in third
  171. New Alt
  172. Security Idea (Could it Work?)
  173. price for middle pipe on astra estate?
  174. Warrior Motorsport - Ipswich
  175. VCarlton Breaks
  176. Wuring Noise
  177. Alternator Wiring ?
  178. astra mark 3 central locking
  179. Any one use Black Diamond Combi's
  180. Definitive ignition circuit testing?
  181. immobiliser removal on gte16?
  182. gsi brakes
  183. heated seats
  184. brakes question
  185. Some like it hot , I sure as hell don't right now .
  186. Help to identify
  187. wot wud i need
  188. V6 questions....
  189. epc question
  190. Track rod ends for rose joints?
  191. vauxhall vectra 2.0l gls idle problem
  192. standard nova track eq length shafts
  193. are all corsa swivel hubs (steering knuckles) the same
  194. TC Sorted
  195. Couple of Calibra Electrical Questions
  196. Rear Discs
  197. size a 2.0 8v cavalier brakes?
  198. what size battery on a 1,7td astra estate?
  199. discreet (internal?) mods
  200. brake upgrade problem
  201. mismatch tyres
  202. leak from rocker gaskit
  203. Antifreeze How Much.??
  204. knock sensor fault. Need advice
  205. Results of compression test - not good
  206. 4wd fault
  207. Locking mecanism on Corsa
  208. whats that for ?
  209. Quick question... Astra GSI mk3
  210. Battery Holding Charge
  211. Alternator dying?
  212. Corsa 4 sp auto box cold changes
  213. Corsa aircon fan and cooling fan
  214. corsa dudes.
  215. Astra Mk4 - Wiper arms stopping in different places.
  216. Opinions please!.
  217. will they fit??
  218. GTE 16V Faulty :(
  219. 2.2 bottom end
  220. brakes??
  221. merry christmas all
  222. whats a.....
  223. bigger discs please!
  224. 16v brakes on corsa
  225. Astra "F" mk3 C locking setup
  226. re-bore from 2.0 to 2.1
  227. Ecu question
  228. Brakes do nothing and make a grinding noise, what's wrong???
  229. Doors Locked
  230. Alternator Issues with TBs
  231. Question.??
  232. wheel locks easily
  233. lowerings springs?
  234. can someone name all the parts that make up the One touch windows in a Cavalier GSI?
  235. astra gsi handbrake changing help plz
  236. Does anyone know if....??
  237. V6 Torque settings
  238. Stalling of Omega 3.0V6 when warm
  239. digital dash in astra mk3 ???
  240. Washers?
  241. need some help on mk3 astra susp
  242. MK3 astra/cav suspension
  243. More Torque PLEASE!
  244. horrbile idle problem when warming up
  245. Grinding noise(s)
  246. GTE Digidash in a Sierra
  247. omega digi climate control prob
  248. Need confirmation on this point:
  249. Cav electric windows
  250. Astra GTE 2.0L 8V not fast enough!!!
