- Vectra Door Cards - Blonde
- Ringing noise then ABS fault! please help!
- Can anyone help?
- Pedal box to be fitted tomorrow. I hope.
- Request for someone with Banana.......
- will these fit
- astra gsi v6 conversion
- trip comp wiring
- how low 2 go (nova)
- Vectra cuts out at 75mph
- Pas Fluid Leaking Everywhere
- lexus lights
- cutting out problem
- Think clifford alarms draining battery
- Will mk2 electric mirrors fit a mk3?
- Turn traction control off ?
- GTE Wiring??
- Sputter bearings
- EM light on but no faultcodes
- ecu dr
- Just curious
- help needed ASAP!
- astra gsi trouble
- are 8v astra pas steering racks same as 16v
- Door handles
- Are Astra mk3 seat frames the same as Cav mk3 frames?
- Can any one tell me what markings are on Vectra V6 front callipers (288mm) ????
- steering rack
- Ideas on Cluch pedal end of Astra3 cable
- my new project
- can u convert from manual to electric?
- Best puller to use on a cav steering wheel
- nead advice regarding o/s suspention CLICKY/CLUNKY
- Dropped ?
- Possible to check if relay works?
- Dropped ?
- Fancy Laser 4 Way Tracking in Mids
- PAS Steering rack problem
- Corsa b gsi wiring problem
- Worn Wheel Bearings.
- Rotation on tyres and psi query LOL
- wiring up a v6 rev counter
- problem nova gsi
- MK3 Astra Estate Questions
- More Ponies on a small budget!
- Fitting GSi clocks in a 1.2i Nova....
- CV Grease - Castrol LM or CL?
- how difficult 1.7td into 15td corsa mk2 body?
- C22sel
- corsa CV' how many splines?
- 16v Callipers/V6 Callipers...
- Weird Smell
- MOT Failure on Emissions
- PAS Fluid Leak
- just bought an astra 2001 1.7dti
- Not working!!!!!!!!!!
- cally/cav shocks? The same?
- 4 pots + wheel size
- Astra pulling to left - inside wear on tyre, whats wrong?
- Part Number???
- 1 touch window guide?
- EBC Green Stuff Brake Pads
- Vectra dash faults, dials stuck at 10mph and 1krpm?
- im cracking up
- Distributor problems
- Urgent Quick Question
- Megajolt lite jr
- Cav - Astra weight difference
- Quick Question: Damper Perch Plate
- It this true?
- horrible tapping noise
- Leccy windows problem
- What offset ?
- boost fluctuating when holding boost
- M14x1.5 to 1/8npt adaptor
- correct set up 2.0 16v nova
- Info needed
- Rusty Bolts
- speedo in 2.0 corsa
- 18SE management problem
- vectra door cards and leccy window
- Would a..........
- ecu light cav mk3
- Brake Lines
- Steering checks - help
- swapping engines what will i need??
- Alfa 145 Discs with V6 Calipers on a Cav GSI, Will they fit together?
- digi clocks....?
- whats needed for electirc dash install
- cors a questions
- Astra rear beam......
- Mk3 lowered astra owners!!!
- bloody frontera. (urgent)
- cav heaters not working
- Help with Cally T 160 MPh clocks needed
- 1995 Cavalier Charging Light?
- getting a ecu out (mk3 astra)
- setting veniers with no timing marks
- electronic equipment for performance engines
- Nova Engines!!
- strutbracer.co.uk?????
- alloys
- Alloy filarments
- air tool coupling adaptors
- handbrake problem
- heater Matrix
- Insuluating Wires
- sunroof
- more v6 releated question -temp sensor
- Vectra Ac stopped working, help!
- Key sticking in Omega ignition
- 1997 corsa Suspension onto Nova....
- Just a bit of advice please guys....
- Heater blower effeciency..............
- RainX
- Traction Control questions
- cone filter??
- What are theses?
- does anybody know where i can
- 10K Boost any good....
- 2 litre corsa conversion in lincolnshire??
- Astra Mk3 Steamin Up
- bleed nipples
- Alternator, relays or wiring?
- Boost guage mk3 astra
- Isuzu haynes manual
- Ill Car
- Cavvy 2 cally airbox conversion
- how to make it louder
- Cavalier Ride Quality...
- Nova Lights...Please Help!!
- mmmm will it fit....
- Any Thoughts ?
- Motorsports Parts bias pedal box
- strut brace
- diff too loose ???
- bmw e30 dead lock stuck on?
- astra 8v conversion
- astra mk2 ECU not coming on
- Advice Need for 20NE!
- v6 into a mk3 astra....
- Bodge of the day.
- Quickish rack idea.
- what size the thread on brake fittings (nova)
- Airbag warning lights - turning them off?
- testing a trip computer
- need help quick wiring astra gsi multi info display
- Need quick response!!!! CV question
- Mirror glass problems
- AFR gauge readings
- Mikalor hose clamps, where from?
- Removing Corsa MFD
- Help needed plz!!!
- windscreen washer jets (NOT LED ONES)
- New actuator has made my car feel worse!
- vecky airbag problem
- alloy bottom pulleys
- New ABS sendor needed
- HELP REQ'd - Fitting new toys
- Bonnet swap
- Shocks on a Mk3 Astra
- Rear Screen Heater
- izuzu td again, but please read, need help...
- MkII Astra convertible elec window motors
- Rear Disk Brake issue
- Unscheduled under bonnet steam cleaning.
- Wiring up cheap alarm....
- Ignition Advance @ WOT?
- Corsa B Experts, Strange question for you!
- Am i mistaken when i say...
- Central locking!!
- Astra Aerial
- Daewoo Nexia Remote Boot into Astra Mk3 (pics)
- Dashboard remove
- ball joint seperator
- MOT Testers or Pro Mechanics Help Please
- power steering problems
- Lowering cav v6
- a few calibra questions (pics)
- 8v conversion
- leccy window problems
- corsa offset sizes
- temp guage and cold air problems.
- Astra GTE Fan
- Expected gains?
- Digi Dash wiring
- anyone know......
- what r the best mods for v6 cav
- I doubt anyone will know but.....
- Coolant Temperature Sensor Query
- Another weird question from scottish muffin
- Astra topmounts...ergh!
- Electric speedo v6
- Mission tomorrow, Need all the advise/help i can get
- chassis legs
- Meta Alarm, 2 button remote + LED
- Any clifford wiring diagrams needed! Any at all
- from cav into astra
- silly question of the day
- trip comp wiring
- Airbox for calibras
- Lowering problem
- temp sender?
- All electrics pulsing! Please help
- wishbones...again
- Running Rich and Failed MOT
- astra bed.
- strange electric window problem
- Astra GSi Brakes on Corsa GSi???
- 2001 Astra Servicing
- Steering problem after hitting pot hole
- rear suspension
- which spax or billies??
- cavalier v6 help??>>>
- a couple of underpiston cooling ideas to throw around.
- A/C gas type - Cav '94????
- Astra Water leak
- stalling round corners!??
- Astra G/ MkIV suspension diagram
- Rally Spec rear bilstein bottom mountings
- Boost gauge on a TD????
- Quick question on light bulbs.........
- Spi To Mpi
- No Rev limiting on my Calibra !
- oxygen sensor wiring
- HH Nova welding kit, which plates??
- heating adjustment bulb
- Astra Mk4 Keeping blowing bulbs?
- K&N Help
- Idle Speed Queries
- Vectra Buying tips
- Astra 3 suspension clunk
- Steamy windows.....mk4 astra coupe??
- digital dash help (luton area)
- more problems on the astra
- Ignition lights
- EPc Picture please
- Been on the rollers all day and had a few problems :(
- will a corsa b rear axle fit nova?
- GSi odd idling
- Volkswagen question...
- Boost control
- Cabrio questions????????
- Cavalier running odd.
- trip computer probs astra gsi
- Dead Battery?
- corsa conversion
- back box fitting problem.......
- major problem quick help needed
