- Tigra Wiper Fuse Blowing
- Mangled Sills aka Revenge of Wind Jack LOL
- How many miles should i get from a tank??
- Technical Question!
- gsi into gte trip computer
- What compression results (psi)
- OMP break pads????
- egg smell
- E M S fault codes, Information please :D
- Its that time of year again!!!
- filter cleaning question
- Power steering
- Lighting module? behind glovebox on Calibra V6
- corsa-b heaters??
- Different colours of Cosworth YB rocker covers?
- **Help Please** Speedo Clock code numbers
- Pierburg 2E3
- Astra GTE - steering pulls to left
- big brakes
- front and back electric windows switches
- 2001 Astra Sri Erratic Coolant Loss
- heres a question and a half for you peeps
- Help! Please!? (CALIBRA HELP)
- 1.5td corsa
- BRAKE PADS - where to buy
- seats??
- M-tech Corsa 2.0 16v Conversion shafts question...
- Air Mass Meter Out Of Range?
- mk 3/4 astra suspension
- Anyone with EPC?
- Calibra brakes/suspension on Astra mk3
- PI suspension kits
- how the feck does it come off?
- autowatch alarm instrutions
- Vauxhall service kit?
- Quick V6 Vectra Question
- 14nv c12nz????
- 14nv 12nz need advise
- Apexi and gauge fusing?
- novarev limiter problem
- Water sound behind dash + broken key
- just done paper clip test any gen on codes please..
- zafira alternator
- Nova running
- v6 brakes without bleeding them?
- ECU Light on can anyone help
- Omega 2.5TD Boost gauge
- TD comptability
- Omega Speaker sizes
- mk3 cav subframe bolt question
- wierd nova dash again
- What do eccentric top mounts do?
- any ideas
- Seen this before
- gte 16v wiring
- 2.0 8v 'Waterways' diagram anyone??
- HOW DO YOU MAKE A CAV GSI A BIT QUICKER & CHEAP!!?
- MK2 Rear Discs, Can they....
- Ecu Vacuum Pipe?
- How do you turn on cruise control?
- Traction Control on Vauxhalls..
- adjusting boost on a 1.7TD any gen?
- Remote Central Locking - Doesn't quite unlock..
- Nova Power steering
- Vectra problem
- K&N Cleaning
- i know its prob been asked before but please help!
- Please Help ECU Light
- Part Co?
- 16v suspension on 8v
- bad steering when cold !!!!!
- Question for the V6 Boys
- Warped Brake Discs
- What cars ran the Pierburg 2e3?
- Poor running hen cold
- monsa gse 3.0
- Astra G SRi to GSi conversion
- Omega Cruise Control Problem
- Well my friend reckons.....
- Got trouble with my cavs clifford alarm can you help?!
- advice on astra coupe
- Quickshifter
- Cav/cally window motors...
- Astra Workshop Manuals
- 3.0 v6 into astra mk3 gsi
- Whats This?(Part Number Inside)
- bloody astra
- light on my key not working?
- Astra mk3 Full system?
- astra mk3 wiring??
- Saab 95 EM light question..
- cav gsi springs/shocks
- Omega heated seats, help!
- bmw 525 not running help
- i think my speedo needle is out
- 1996 Vectra SRi 2.0 16v - Coolant Gone, Overheating
- Help removing wiper
- scraping noise form under the diff cover plate
- '52 Astra Coupe mk4 rear hub query
- distributor cap?
- Apexi for Vauxhall??
- 5 Stud Conversion on to a Nova
- corsa digi dash
- Brake arrestor???
- AFR readings.
- buying apexi ltd edition boost controller what parts should be with it
- 1.7 dti astra g
- Electrical problem with Calibra V6 -> no lighting
- Poor start from cold, jerking and poor mpg ?
- HM "gurgling!"
- Anyone know a good place to get anew Nova wing??
- torox rotors
- New suspension setup for my nova.
- Corsa B Rear Disc conversion?
- part number
- wheel bearing?
- Problem with 1998 BMW 728
- Cost of a new icv?
- Adjusting the psi ??
- astra 3 v6 which clocks?
- ##**Part number request**##
- Quick Question About digital / Normal Dash!!
- Omega V6... coolant presurising.
- speedo sender advise
- thottle cable sticking
- need a hub/susp leg 4 big brake developement
- astra gators
- Astra Handling
- Brake initial pedal feel and action
- Nova Tie Bar torque setting
- cav v6 cutting out
- are air bag and non airbag aftermarket wheel boss the same
- astramax
- Uprated Brakes
- 53reg 1.2 corsa airbag
- Astra Mk3 Front Shock Changing
- Megasquirt
- Anyone know how to fit a digidash?
- whats the difference between these pics?
- V6 Astra mk3
- Car stalling
- Nova Door Mirror
- mk4 astra 5 stud conversion
- Carlton Cruise Control
- wire colours for ICV on v6 cav
- Strtbrace HELP!!!
- Car revs funny ?
- Fault diagnostic plug
- Cavalier rear wheel bearings...
- multimeter
- locked out of my omega
- Fault Codes V6 - Whats wrong
- Clio Question
- xxxk me guys
- rounded or square tooth
- Roll cage question.
- loud bang tempory loss of drive!!!
- 20SE running on three cilinders
- compresion
- crack in disc is it dangerous
- Installing Nova GSi Clocks/Speedo
- mk3 astra sport suspension
- astra GTE dashboard wiring
- vectra
- Pics of tophats
- mk2 astra springs on mk3?
- 0-60
- Stalling cavalier 8v
- Noise on Cavalier .
- Trip Computer + Cav Sri
- Nova front track width ?
- cav v6 auto shafts sames as manual?
- what do i need for electric mirrors?
- Stereo fault
- Aftermarket Tachometer Corsa Problem
- corsa gsi over heating
- Thoughts about alloy wheels
- Breaking problem
- Key fob
- Corsa SRi
- front fogs
- help with v6 wiring/plugs
- Urgent answer needed please
- Con Rod Failure Modes
- Can you make veccy windows close with the standard alarm?
- where to find angel eye fog spots for astra coupe
- Bilstein Sprintline suss Kit for astra coupe, where??
- Retrofit central locking (Corsa)
- Flashing EM light on MK4 Astravan.
- lowering a Zafira Gsi
- vectra's poor performance
- Ignition system on the R5 GTT
- ABs ECU
- Quick shock absorber question!
- Astra mk3 multi-function display thing
- Startup in the mornings
- 3.0 Omega questions
- g-max suspension?
- what do u think caused this?
- anyone got a link to Comp-r brakes
- HELP!! Please!
- anyone fitted a full set of braided brake lines to a gsi mk3?
- Its just one thing after another
- help with suspension on a cav.......
- How Low Shud I Go?!
- revved up
- Omp Strut Braces
- quickie..brake fluid change...
- grinding
- Corsa Reverse Lights
- anti roll bar paint
- Mk2 Astra GTE Spring Identity
- Airbag light is on. Also is the a trip system?
- digi dash
- Astra cruise control switch
- Funny Tachometer
- vectra computer - ideas
- Pics of my bottom end - diagnosis please!
- TC & ABS lights
- Astra C 17Td
- Ecu Fault on Astra 2.2 Sri ?
- cheapest way of getting 308mm brakes
- GB boost controller .
- astra f cutting and spluttering?
- arrgh now the electric windows aren't working
- difference between nova and corsa front bush sets
- omega sunroof into vectra sri
- Best Place to Buy
- Power Steering
- will nova sri clocks work in my 1.3 astra mk2?
- lowring... are shocks essential?
- Dash brake lights on
- Vectra Intermitent Light
- Frontera Brakes Still
- Fitting Top Mounts??? (HELP)
- Fitting ESP to a V6 Calibra
- Do ECU's have to be earthed??
- Does my Corsa already have MPi?
- Rocker cover material
- corsa management diagnosis
- 5 pin relay
- Cosworth bits
- corsa power steering
- ecu error code 19 help please
- Help needed, Senator Digi dash into a Mk3 Astra
- door pin fitting?
- car/track eligibility
- speedometer needle
- Brake Problems - ABS??
