- Corsa SRI ECU Code 24 question.
- wheeel cylinder.................
- screamer pipe?
- How's your German?
- Boost question
- Cavalier wont rev past 3000rpm
- ?spacer question?
- alternator
- cav towbar,hatch same as saloon?
- corsa seat frames
- Are all Astra MK3 front struts the same?
- 2.L16v Wiring
- v6 voltmeter problem
- Just bought an earthing kit, where would you recommend to earth?
- Help Problem
- HELP!!! --> Mis-Firing Cav SRI
- which is the better
- Hello all.... part numbers
- calibra box noise
- tigra mis firing
- intermitent dodgy idle
- Traction Control problem
- Car running cold info...
- who can..
- coolant awrning light?
- how much for a 2nd hand one
- Airbag light / ECU light / e/w up doesnt work / radio goes off??
- rev counter problem on corsa 1.5 TD
- fault code 0500 HELP!!!
- Urgent: Wiring Diagram for MK3 Astra Stereo
- plz help get my car back home
- Omega V6 running problems
- 1.8 zafira owners
- Dodgy Heaters on Corsa 1.5D
- How do change f/foglight bulbs on a mk3 astra gsi??
- Should I put an airbox back in?
- Internal control module
- Does this really work?
- Setting MBC with Ph 2, what pressure?
- bubbly sound from one water pipe?
- Clearing Flash codes?
- how much antifreeze?
- non starting nova
- my 14se died out on me
- Someone with EPC
- central locking wire colours???
- Nova ignition playing up AGAIN!
- heating blowers not working
- Coscast or not?
- Wiper Electrical Problems
- rev gauge
- Switch problems
- light bulbs
- TID upgrade found!
- Power steering fluid, could i use....
- Can anyone help with this code?
- 2.0 corsa problem
- Vectra Rear Hubs
- nova GTE vacuum pipes, any pics?
- I have lost a wire for the started motor??
- can di be converted to dti
- Zafira heater matrix replacement.
- my veccy has lost all drive?????
- Cav suspension on astra??
- Wiring front fogs into full beam
- What can I use an oscilloscope for?
- Corsa SRi Brake Travel?
- Upgrading a master cylinder?
- cavy clocks into nova?
- Goodbye piston number 4 (pics)
- 3 wires left from corsa to nova conversion
- F18 level plug?
- nova gte
- does it need bleeding
- Funny one - F18 box change
- Astra bump stops
- Stupid question about sqealing pads...
- Glow plug change on 2.2DTi
- Suspension Balljoint
- nova clocks
- Anyone got acsess to TIS or any mech's on here goot with Vectra's
- traction control on a corsa? could it be done
- nova 2.0 wiring
- Piston rings
- Brakes for track
- NGK BCP7EVX or BKR4EVX
- Starting
- Where to get Lotus Carlton parts?
- D'oh Cav broken down :(
- cav 2.0i d.shafts into astra 2.0gte8v?
- Downloadable workshop manuals?
- Advice needed on lowering V6 Calibra with 19s
- smoking veccy di
- Accumulater bulb and guvner
- will this tank fit 1.8 spi cav??
- Fuse box corsa c HELP
- knocking noise
- Bump stops for Mk4 Astra Coupe
- Still can't get boost right .
- Alternator on the way out?
- Astra "Hall Effect" problem
- v6 2.5 firing order ??
- adjustable steering column on gte broke!"!
- Nova Clocks Query
- Electrical Gremlins - Vectra B
- Climate Controll (Retro Fitting)
- 5 stud brakes question!
- Strange Noise when pulling away Astra H 3dr sport.
- Corsas Poorly.... ?
- only 1 plug in the kickwell? v6 mk3 astra with pics!
- squealing noise
- Tapping 2.5 V6 in omega
- 1995 astra 1.7td - Doest it have a transponder immobiliser or even an ecu?
- Brake's problem, mk3 astra with 2.0 8v
- Interesting Read...
- speedo queries/ dial change
- corsa brake question, please help its getting dangerous
- Astra eccecntric mounts - fitting help
- 2.0 nova strenghening
- OMEGA 2.5V6 running problem!
- slow when cold
- 5 stud onto nova?
- Sfi Box Differences
- Twin 45s, question....
- HELP mega vibration
- Sports mode light on or off?!
- Can Someone Reprogram my Key Fob
- do you need clifford wiring diagram
- v6 clocks mk3 astra?
- wheres the speed sensor? corsa
- Vectra SRi 140 front brake discs
- GTE 16v (Earlier Bottom End) Braking Layout
- Post Your Average 2.0 8v Running Water Temp Here
- kadett?
- Corsa brakes
- rocker cover cleaning out
- Cav SRi HELP NEEDED!
- swaping cav pass lock to driver door?
- Weird charging problem, confused...
- Ex M.S.D tech
- Diagnosis please
- alarm astra g
- nova shell strenghening
- Best Nove GSi Disks And Pads.
- Abs Cuts In To Soon When Braking Heavy
- Zafira GSI Stalling?
- 2.0 8v nova conversion
- Senator SPORTS MODE prob...
- 16v nova
- 16v conversion
- would these fit, or could you bore them out?
- cav v6 suspension setup
- Strut brace to fit 2.0l16v nova
- Alarm Help!
- Astra MK3 problems - help!
- cv joints
- MK3 Astra GSI 5 Stud Conversion!!
- corsa 2.0 16v conversion
- abs light plse help :-)
- Corsa speedo
- cavalier disc's and brake pads.
- F18 long or short
- instrument lights out.
- Brake Pad Warning Light and After Market Pads
- What to do next?
- Gte K&N
- getting a suspension kit fitted. couple of Q's
- astra coupe (2001) wheel measurements?
- Air Bag Light
- Nova GSI 16v conversion???
- Nova 16v advice
- corsa brake disc conversion
- Vectra V6 Stering column Recal
- dash clocks
- Cav V6 calipers/discs fit inside 15" 'Fan' alloys ??
- converting rear axle from drums to discs! mk3 astra
- Alternator in a Corsa C
- Astra MK3 steering rack fit MK2?
- Barke pads/disks for astra mk3
- Bet: Bottom-end or Rings (listen inside)
- Alloy fitment URGENT!
- Stalling when warm
- Corsa B weird sound of water behind the dash.
- Electric windows not working.... please help
- will lower front strut brace from cally fit my mk3 astra>?
- Omega Diagnostics
- Astra SRi MPG ????
- Little to no heat
- juicy tigra
- Manual steering into a calibra
- Part numbers for spill pipes and T's
- corsa fault code 85
- can ungapped plugs cause poor economy?
- Central locking closes, then opens again ??
- Uprated ARBs for Mk3 Cav - where?
- Help With Cav SRi Water Temp Gauge
- wiring
- Rear disc question
- Oxygen sensor signal
- Astra F running probs...
- Help for 97 Vectra 2.5V6 Auto please
- White smoke and water problems.
- is this normal on my mark 3
- please please help with my suzuki jeep
- Steering Wheel Wobble!
- Bad handling Astra Mk2
- Subframe help
- How to make speedo work??? Plz help !
- nova electrics fuses!!
- Astra harsh ride and pulls to left
- Brake pedal travel increased
- Worn bolt removal help
- brakes
- weird noise when auto choke is on
- Rear light problem on vectra
- results lol
- electric power steering into a nova
- mega steering wheel wobble (nova)
- how big brake kit????
- ECU Pin 20
- brake size
- Astra Mk3 handbrake?
- after a part number astra mk2
- 2.0 brakes on a corsa
- Heater matrix maybe?
- help with rear electrics windows in mk3 five door astra
- trip computer
- omega V6 PP Performance
- Best place to get new 5 stud astra hubs?
- help!!!
- calling all miggers
- Corsa Sport Problem
- Brakes seized on a Corsa
- Rear windows .
- airbag light
- compression test results
- MK3 Astra hubnut torque?
- Track rod end, CV Joint, Ball joint Replacement
- tigra paperclip test Q....
- Power Steering Probs...What can I do??
- My Corsa Kangaroo
- a quick what dose this mean? (fault code)
- Passenger Door and boot lid removal help
- Free Website If Someone Sorts My Vectra V6
- high rev idle stil persisting. ???
- Where's the knock sensor on a 2l 16v eco?
- corsa/nova help
- Fitting A New Bonnet Pull Cable?
- Hub removal ?
- Can anyone do me a favour
