- digi dash
- mk3 centre console
- v6 cav lowering springs
- speedo help in mk3 astra gsi(QUICKIE)
- Nova quick rack kits
- Ball joint problem .
- Ram Air Foam Filter....cleaning??
- mfa clck in astra not showing any info?
- Turbulence in Airflow
- Airbox
- Rev Counter
- ignition live
- Dash Symbols
- 2.0 16v corsa flat spot
- is it as easy as it seems? to take off rocker cover
- Alcon brakes
- Aargh - wheel bearings !
- 2 wheel drive
- can the gte digi dash be reprogramed
- what can i do
- Alarm fault codes
- Max front axle load on a Tigra?
- 93 Gsi questions
- v6 idle emissions probs
- cheapest place to buy
- Performance leads+plugs, why?
- No ecu light on corsa 2.016v conversion...
- Servicing my own car!
- car not running right
- EM light linked to heated seats?
- Synthetic Myths
- Vectra B Rear bumper removal
- cav electric windows
- Steering went byeeeeeeeeeeeeeee
- scary
- Dremel type tool
- sqealing
- Im new and need so advise
- mk4 astra lights/transponder Q
- chassis number query
- tensioner pulley
- revving up by itself
- Strut brace question
- Seat harness fitment
- just changed my leads
- decelaration probs 16v
- stupid boost question
- Vectra traction control Help!!
- tuning parts for corsa
- astra g/ coupe temp
- Is this water channel wall acceptable in width?
- Rocker Cover
- smokey astra
- heated seat problem
- Brake Fluid Pressure
- Decided on what I'm driving next. Advice Please.
- size of wheel bolts??
- under pressure? tyres!
- Electrical Prob's, Lights flickering
- Nova MK2 SRI Major electrical probs
- 3ltr v6 into astra mk3??
- v6 coolstat part number
- lights flickering inside
- Wheel bearing .
- heater matrix
- window probs
- Vauxhall
- astra suspension kits
- Rough cold idling??
- Controlling Boost with External wastegate? How?
- OK need tyres again, any suggestions?!
- Vectra Suspension
- temperature
- After a little advice/opinion please?
- 1.7 TD cav alt charge light.....
- lost boost
- V6 Spacer Kit.
- Astra MKIII Revving High when Idle
- Cleaning Of Icv?
- i think i may have a problem.........
- cav 2.0 and v6 disc centre bore
- Cavalier/Calibra Steering racks..
- hhmmmm k&n but no noise
- do you have to match dash to tranducer ?
- Just Crashed My Ride.
- external temp sensor
- nova spi high idle problem
- astravan rear disc convertion
- This could be GR8 Info for corsa c owners with faults
- Multi Function Display MFD
- Changing pads on a Zafira
- v6 cally electric problem (may be simple)
- Iridium Plugs
- 4-stud 284mm front discs
- compression test
- Astravan Axle
- 2.0 8v Starting Problems, Help
- Changing bulb on a Nova....
- Saab discs ....to fit 5 stud cavs?
- Plug
- sticky thermostat
- ecu light flashing on start up
- corsa rear disc beam with abs?
- which wire for bulbs on corsa clock/computer
- bit of a strange question
- mk3 astra drivers: heater problems
- how do i get flash codes?
- corsa e16se problems!!!
- New Key for MK4 Astra - matching to car
- GTE suspension
- 2.0 dti tuning
- lower
- FAO wiring boffins
- corsa b tailgate window removal
- what does a baraomic(sp?) sensor sense?
- high beam staying on
- rear brake conversion for a corsa b
- Specific V6 into Mk3 Astra qu's???
- Its arrived!
- reverse lights problem
- vectra shockers
- How Can I Tell
- Dodgy steering on cav mk3
- Coolant problem
- max 90Nm to rear wheels ?
- ABS light
- upload images
- Electrical problem
- Subframe Bolt, No thread in hole....
- airlock
- Are my plug gaps OK?
- blowers come on then go off??????
- Where to connect an I/C on a Corsa TD
- NGKs BCPR7EIX
- Still Sturgling Please any ideas
- what is an ICV ? whats it look like?
- 2ltr 16v corsa mounts?
- Nova GTE
- where can i get a release bearing from? new
- for those with Banana
- help with fault code 117 after a little mishap with a kerb
- Cavalier V6 Auto Box Problem???
- Drivers door dead lock
- PM box full for a while - dont pm me
- Backfire question
- Astra G centre console illumination
- Corsa steering wheel
- how do you change centre console bulbs in a l reg corsa
- heres my car for anyone who wants a look
- astra gsi rebuild
- Vectra B Central Locking i think
- how do i get my ignition barrel out of my mk3 astra?
- display problem
- Missfire/Hesitation under load...
- FSE at 4 bar
- Speed sensor
- heating not very hot?
- 20ne 20seh differences
- Power steering
- nova thermostat
- 2 stage fan wiring
- V6 Conversion
- ABS - turning on and off....
- High Pitch Whine
- Calibra Computer
- Nova dash prob
- corsa b power streering
- problem start my cavalier GSI
- actuaters and boost
- help with antifreeze loss
- computer in calibra
- v6 intake
- Just a question in general ...
- Astra GSi ticking
- v6 fse pressure thingy
- Astra GTE Track car HELP
- Cavalier Rear discs onto Nova?
- help work van dangersly slow<55deisel>>ford depresing
- zafira traction control
- How do you replace the sidelight on drivers side
- spring climp
- True or False???
- Getting behind the Cig lighter?
- Can you get...
- Rough when cold
- Abs
- corsa rear disc conversion
- 2.0 8v Nova Pulling all over the road
- 97 Tigra Suspension...
- 20SEH 8V engines
- Coolant pipes 2.0 eco, should they be hard or squeezable when hot?
- just how much boost can you run????
- ECU control below 3k rpm
- ABS warning light * Urgent *
- combo van
- bang from steering, now wont turn left?
- Vectra Alarm Keyfob Problems
- canister in nova wing, can i bypass it?
- Alternator Not Charging Battery???????
- vectra 120 and 130
- Cav front suspension top mounts
- Led Question
- 3.0 or 3.2 - which is better conversion
- 57i For 2.2 Vectra
- F18
- Electric roof on astra cab
- HT Lead resistance?
- corsa exaust fitment
- car just cut out...
- Help Me... the cold has killed my car
- Any 1 know any thing about PUG electrics?
- lowering Q for a nova...
- Faulty jubilee clip causing problems?
- HELP PLEASE - Running Lumpy
- Nova suspension question
- which box?
- Heater blower problem
- Vectra 2.5 V6 running on 5 cylinders? (maybe)
- need urgent answer please (diff on veccy)
- Damn bolts
- Cavalier wiring plug question?
- brake light goes off when brakes pressed
- front wheel bearing prob
- Wastegate chatter?
- passenger window (calibra)
- Changing an alturnater can you help?
- push to make 2 pin plunger switch, where to get one?
- corsa lowering springs on astra
- petorl spill
- Nova Steering Racks??
- i need to no what this is called lol
- V6 perfomance
- Air temp gauge,, strange readings :s
- Whats Involved
- How can i get round my tyres keep balding up on the inside.
- corsa C rear fog lamp
- v6 alternator
- Rattling
- fan not cutting out
- Wiper arms Mk2 Astra
- Screwed Cav ?
- Vectra hubs on Mk3 Astra
- Tigra (old Style) broken high beam
- v6 Astra project (pics)
- Mf2's
- Fixing leak
- will these fit??
- Mk3 astra clunking over bumps(front)
- corsa sri
- Corsa SRI ECU Code 24 question.
