- Arghh cav GSI MPG won't go over 30!!!
- battery keeps going dead???
- Dribbiling Coolant
- service kit
- Vectra 5stud to 4 stud
- Calibra v6 cooling problem!!! Help
- astra van speedo prob
- Irmscher Body Kitz
- corsa price
- quick rev counter advice
- F***king TC!!!!!!
- basic and cheap mods for '89 gsi cav
- does this look ok for a nova gte?
- F13 from a astra in a cav
- Wet Rear Footwells
- locks oops help
- Rear wiper
- Sticking deadlock, cav'
- stuck with wiring my 2 litre nova
- 2.5 v6 rads
- amp thread
- ford transit question whine
- ECU Fault Codes
- need zorst fitting
- can some one point me in the right direction on these last few wires?
- Starting problems
- Windscreen Washer Motor
- Corsa GSI probs
- electric windows playing up
- Cavalier online haynes?
- what is the best anty roll bar
- Question about remote central locking
- Please help
- what happened to this cv joint?
- Corsa ECU question.
- 4wd rolling roads in cumbria?
- vectra fault codes help!
- knock sensor?????
- New car spec sheets for old cav
- genral problems with my new car.
- how to wire up my gsi computer right?
- Diagnostic plug on vectra
- Cally Rad
- corsa window wiring
- How do I get the date back on my display?
- Corsa Immobiliser
- cavvy lekky ariel wiring?
- central locking
- corsa speedo
- astra td knocking when cold (isuzu)
- online parts store?
- problem with door locks ie wont lock
- project astra v6 mk4
- Omega Fog Lights
- Please Help Quick
- Tigra workshop manual wanted
- vectra A - spring height
- vx220 dials into nova?
- how many miles to wear in rear brakes??
- Clifford Alarm help
- Caliper mounting brackets
- Cav SRi into astra F
- Non vaux but appreciate help
- Coolant Leak
- Squealing from front n/s stops under braking
- dodgy electrics
- will a f18 mate to a v6?
- Digidash In My Aquired Cabby Reads Fubar
- ****ron zx td electrical prob linked?
- immobiliser
- fitting a exhuast system to a corsa b
- Help!
- Astra Brakes....ebay link advice
- omega gen
- New Auto Box
- 5 stud question...
- Time to replace bulb ???
- idling and stalling - ICV question
- Nova Total Closure
- Serious Suspension Problems, Help needed
- help electrical problem with cally...
- nova conversion!!!!
- Tyres
- Astra 8V Thermostat
- 5 stud conversion on Nova
- idle probs
- Cally Hub Conversion Advice Reqd
- Someone explain a couple of terms...
- recirc air vacuum reservoir
- clong on bumbs Corsa B
- Help! Advice needed about novas
- just bought a ****ron zx td....
- REMUS/K&N
- replacing bulbs
- Topmounts
- traction control on cav
- all corsa B outer cv's the same?
- Front brakes hot
- lowering my calibra
- wiring
- Pollen filter
- someone please help me :(
- dodgey Ignition switch astra mk 3
- will mk4 astra dials fit into a mk3?
- Cally Advice Sought
- cavalier v6
- Idling problem
- Bleeding New Main Cylinder Advice ?
- Need diagram v6
- Need Clifford alarm help Urgently
- PCD's Pitch Circle Diameter for wheels
- Under my scuttle panel...
- Battery Light
- rear wheel drive conversion q?
- Tigra conversions.
- Corsa Ignition switch 1998
- sloshing noise
- mk2 cavalier inner cv's
- astra mk3 gsi just broke down!! urgent help neeeded!!!
- MK3 Astra GSi cutting out?
- corsa rubber mount
- my handbrake shoe's
- Nova gsi clocks plz help
- Short Shift for F13
- Drifting illustrated lmao
- alloy key
- FK Suspension kit: any good?
- coupe cruise control
- v6 into an astra gsi problem.......
- Digital Dash !!!!!!!!!!
- Nova leaking in rain (drivers footwell)
- cav steering fault , need help
- urgent!!! pics wanted....
- ATE None ABS Brake Setup/Probs
- astra gte dash into a corsa
- cav astra shafts on corsa YES OR NO!
- Dippy Bast
- Servo vacuum leak.
- Carlton gsi 12v problems
- Tigra Rollcage
- Immobiliser Diagram?
- What a load of rubbish!!
- Nova brake setup
- Anyone help with new discs and pads?
- Dealership List?...
- Balljoint nut size ?
- New brakes don't work
- corsa flush boot opening problems
- Astra Mk3 ABS
- diagnostic plug
- mk3 astra heater problem...
- vectra suspension query
- shock differences
- Help me:Swap for corsa B
- no heat inside car
- Front Fog Light Wiring
- Paperclip test
- Lowering a calibre
- help on wiring
- boot lock
- astra gsi
- can you remove sunroof runners, but not the glass??
- cold air feed
- Vectra Deadlocking
- corsa b handling question / allignment
- Nova heater doen't work right an It's gettin cold :(
- Safe mode ?
- GTE ABS/Non ABS Servo/MS differences ?
- Vectra- Someone Please Help!!!
- Tigra- Please Someone Help Me!!!
- What can cause this????????
- when a rollcage isnt for a car with a sunroof.....
- mk4 astra TD
- FAO TFS:- Running x2 100i kits ??
- bloody car!!!!
- Dot 5 brake fluid: how often to renew?
- Astra Fuse Box
- heater blower/heated back window/elec side mirrors/and ciggie lighter help needed
- Help: my car is a serial battery killer
- alluminium tubing
- nova power steering
- V6 brakes to an Astra????
- nova tanks
- ecowreck vaccum
- E16SE is in but a few nigglys, can you help?
- de-locking and shaving handles
- new car
- air temp sensor
- Quick question on nova sri/gte engines
- Tranny box *dis-enage query*
- corsa runs with keys out, wheres the main ignition relay?
- Corsa 1.4 Brakes
- Sensatrac S3418 vs Bilstein 625720525 on a 16V mk2 GTE
- astra g rear disk brake conversion
- compression test results !!
- Resistor mod
- Cavy clock/temp display wiring
- leccy window problem.
- a quick heated seat q?
- Big Brakes
- 2002 Astra SXi Winter/summer Settings ?
- Nova front spring damper pad from Deflex
- central locking module astra mk3
- Corsa electrical problem
- astra rear disc conv parts list.......
- [Q] How many rear bushes on Vectra 1.8LS 1995?
- Distributor Wiring Problems PLz Help!!!
- corsa handling
- chugging td?
- Speedo not working??? hmmmm
- This ain't good! Pics included.
- Speedo problem on VW Polo
- Any brianiact’s about (ECU question)
- were do the hoses go help coolent help
- Astra Mk2 Rear shocks
- astra g question asap
- Part No. 900 19987 needed asap
- Relay problem help please
- Blue smoke
- vectra 2.2 dti bad starting
- Boost Controller -- HELP
- Help
- astra top strut mounts
- silicone hoses
- Traction Control 9issing Me Off
- compression tests
- Display unit
- Can any one help????
- corsa sport buying guide
- any1 attempted to fit golf mk4 speedo to older vauxhall?
- are beru leads good enough??
- plug leads
- Running REALLY rich
- quick answer guys wheres best place to buy wings?
- Vectra milometer bulb
- cavalier fault codes
- how many run evo5 / 310 on a standard bottom end?
- Carlton gsi 3000 problem
- Judders
- diagnostics machines?
- eps steering for corsa B
- Will I Benefit From fitting An Apexi
- 1600 8v hesitating
- possible air leak
- corsa wheel
- How do I know when rear brake pads are worn?
- corsa gsi, 5 stud conversion?
- what does it mean
- what is the difference
- 2wd or 4wd .
