  1. Astra gsi idle problem
  2. reyland calipers on nova or corsa
  3. Astra F13 g box housing
  4. **Vectra Door Handles in a Astra??**
  5. how do rear wheel drives work?
  6. what steering racks fit off what car on the mk3 astra ?
  7. mk3 astra gsi axle what disks and calipers off what cars would fit and be useable?
  8. Mk3 Astra Rear Brakes
  9. 5 seater van?
  10. central locking on corsa with alarm
  11. Removing instrument panel on Mk4 astra
  12. Heater Matrix
  13. Corsa B - Annoying Squeek
  14. new guy
  15. The definitive suspension brand poll
  16. How 2 fit UnderCar L.E.D's ??
  17. Battery Light in Instrument Cluster
  18. New Vectra XVR Brakes for all 5 stud?
  19. v6 playing up!
  20. How do you fit the M-Tech PAS Bracket?
  21. coolant staem bath
  22. Cavailer V6 Gsi Problems
  23. need help!!!
  24. Warning light
  25. strut brace set (cav)
  26. Problem with GT28 fitting
  27. Window washer fluid warmer
  28. Cally T quick question
  29. Heating problems
  30. 3 way coolant hose
  31. Distributer Cap on wrongway
  32. off topic suspension
  33. Corsa sxi 1.4 05 Brake problems
  34. rust
  35. 2.oltr wont run help please
  36. vauxhall diesal
  37. should my rev counter needle flick up on start up?
  38. Noisy rad fan
  39. PCB connections help...
  40. astra gsi electrics gone mad!
  41. any difference in cav rear shoes and pads?
  42. calibra floor plan
  43. Big probs...
  44. Central door locking motors?
  45. cav seats in in mk3 astra?
  46. astra mk3 rear wiper???
  47. suspension strut?
  48. Corsa B tuning
  49. steering wheel shaking
  50. Newbie questions .
  51. lowering my calibra
  52. Strange window problem
  53. Mini wheel baring - damage to hub - pics inside...
  54. Breathing problems!
  55. Mark 4 suspension on a mark 3? (Astra)
  56. measuring lift and duration
  57. Outside Air Temp Sensor
  58. Quick question - Cav/Calibra/Astra 3 strut tops the same?
  59. Quick tyre question...
  60. altenator not charging properly i think
  61. Calibra Brake Lights - Not Working
  62. corsa drivers
  63. anyone used a heater fan for blowing cold air around cone filter?
  64. do you park your car up for the winter??
  65. Heater problems
  66. 54 Corsa - What does the InSp mean on the display
  67. few corsa b questions
  68. mk4 astravan big discs
  69. electric problem, astra, fuse keeps blowing
  70. would a worn shock cause loud knocking?
  71. f18 size
  72. Feels like wheels un-balanced
  73. CR's
  74. thermostat
  75. astra overheating
  76. Astra Coupe 2.2, Traction Controll
  77. Should my car have an anti roll bar? Corsa B 1.4 Flair (1993 L reg)
  78. Cav trip computer bulb
  79. Mk3 Astra GSI – what faults to look for?
  80. att. southend peeps
  81. Vectra Gsi Seats In A Calibra
  82. Corsa B PAS ?????
  83. omega faults
  84. 2.2 or 2.0 - which one would be better ...
  85. Crashed My Car
  86. Corsa pedal box into nova
  87. high emmisions
  88. Any1 know a cheap place for porting/polishing in west yorkshire?
  89. could someone banana a part for me?
  90. Cav Suspension
  91. corsa power steering whats the big nut at the bottom
  92. Calibra door rub strips
  93. rev limit
  94. mini 'a' series unleaded conversion
  95. Rear ATE Calippers
  96. Interactive Driving System (IDS) - How does it work?
  97. mystic bump noise???
  98. i am thinkg of putting 16v or 8v digi dash into mk3 cav
  99. rotor arm
  100. which rear brake pads?
  101. central locking
  102. Retro fit - Fogs into nova gsi bumper
  103. Will These Disks Fit?
  104. Wheelbearing Noise
  105. Astra Mk3 Steering Column
  106. vectraV6
  107. omeha intermitent wiper relay can i use 90069864
  108. traction control
  109. help please frontera
  110. What is this in the photo?
  111. Astra mk3 central locking.
  112. swaping a nova 3 door shell with a 4 door shell???
  113. corsa b digi dash
  114. Strut brace/Harness mounting question
  115. urgent please - corsa and nova rear wheel brake cylinder question
  116. cavy locks
  117. HELP!! GTE 16v wiring
  118. tyre choice? whats best
  119. Weakest part of the corsa's suspension
  120. quote me happy!
  121. Compression ratio
  122. Avon CR500 Tyres
  123. Speedo cable question
  124. CAL/CAV suspension control arm question
  125. i am having probs with cavy not charging and going through alternators regularily
  126. paperclip
  127. Fault codes when paper clip won't work 2000MY
  128. could any one tell me what this guage measures?
  129. Lost.car.keys!.No.spare,...options?
  130. led replacement lights
  131. Cav mk3 central locking stopped working.....
  132. help with cavalier
  133. how such can be?
  134. 8v Alternator wiring help
  135. reading fault codes
  136. Factory fitted alarm refitting to new cavy
  137. Trip Computer
  138. Solenoid
  139. info on fitting boost gauge.
  140. Need big brakes for Corsa C
  141. Dials on Astra G Sri
  142. electric windows
  143. JohnA?
  144. electric windows gsi corsa
  145. Strut Brace Help Please!! Which one??
  146. iffy idle with video
  147. banana help
  148. cavalier mk3 rear shocks on mk3 astra
  149. Electronic speedo conversion
  150. corsa b 60mm springs not low enough, anyone do custom ones?
  151. A few probs with my cally v6. need help people.
  152. ABS Light on Boost?
  153. omega fault codes
  154. How hard is it to build rwd nova??
  155. 308mil brakes under speedlines?
  156. Changing A Track Rod On Corsa
  157. V Max
  158. Lack of rev counter in M reg cavy
  159. Leaking Heater Matrix (GTE)
  160. Fitting Elec windows..
  161. idol controll unit
  162. Calibra Knocking / Pulling problem
  163. Brake wiring help please!...
  164. 79K Service?
  165. what dose a knock sensor do ???
  166. what are the connection #'s on these knobs?
  167. F18c, where to find one?
  168. cavalier td starting problems
  169. Cruise control and steering wheel for new Astra
  170. seh corsa not starting- please help!!!???!!??
  171. will trip comp stalk work on a cav mk2 comp
  172. rumbling and wheel stuck fast
  173. Speedo Cable in a corsa
  174. Compressor advice
  175. Lowering a cavalier 1.8i 60mm help
  176. timing set up
  177. Vauxhalls as tunable as fords?
  178. sorry a bit OTT, Metro suspension
  179. cut or polish gsi rims
  180. Astra Mk3 Front Suspension
  181. on the scrounge
  182. Nova rear disc conversion
  183. speedo help!!
  184. Anyone know where I can get these?
  185. nova droning noise
  186. Calibra - Standard Alarm/Immobiliser
  187. Any bright ideas? (knocking/clicking noise)
  188. Mk2 astra GTE, equal length shafts??
  189. Electric sunroof into a nova wiring?
  190. Air conditioning/Heating
  191. Vauxhall Corsa startup problem
  192. non start help please
  193. Hesitation, K&N and MAF?
  194. Ignition leads
  195. Vibration through steering wheel after balancing 3 times?
  196. Astra Gsi Traction Control
  197. astra gte v6 wiring
  198. Tuning for 2.0l Dti astravan?
  199. HELP!!!....Nova GSI Leccy Probs.
  200. My alternator light is dim?
  201. DIY Porting, can it be done easily??
  202. Quick icv question
  203. What could be draining my battery?
  204. Honda-Rover engines (not vx!)
  205. Vectra Di - will not start.
  206. Door adjustment
  207. Commercial Tyres
  208. my cali runs hot without heaters blowing
  209. converting to 4wd info needed! pics?
  210. anyone got a passanger side suspension leg for a astra gsi???
  211. online workshop manuals
  212. corsa running prob 8v inj
  213. air wrench help.......
  214. Vehicle speed sensor (VSS)???
  215. GSi fogs wiring
  216. v6 wont turn over
  217. dash top rev counters
  218. Astra Airbag Steering Wheel Removal
  219. 10w-60 a technical explanation
  220. rattle
  221. Calibra wishbone bolt thread screwed!
  222. Installing central locking
  223. handbrake light turns on while driving
  224. Setting suspension up (FK Konigsport)
  225. quick reply needed, mk3 heater problems
  226. Mk3 Astra rad mounts question
  227. Servo push rod length?
  228. Building an astra gsi???
  229. Mk2 Astra Steering
  230. Nova weight
  231. what colour are the different speedo rings
  232. k&n cleaning and intake pipe.
  233. em light!
  234. speedo
  235. corsa gsi aldl plug
  236. propshaft mounting
  237. car pulls to the left......
  238. 2.2 (z22se) Timing Chain Fault!!!!!!!!!!
  239. Solved boost problems .
  240. pulling to the left...knackered CV joint??
  241. Corsa B Rear disk Conversion
  242. Fag lighter problem (Posting on behalf of someone else)
  243. Rear Brake Disks ?
  244. Need brakes for Corsa C
  245. knocking sound from wheel
  246. Corsa brakes pants.
  247. charging-charged-C.P.
  248. Is it the same
  249. Heated Seats
  250. all the 8v buffs - water hoses
