- HID kits for astra mk3
- abs issues!
- Corsa b Front Lights
- c20xe ecu query
- c20let into corsa c
- Brake Fluid explained
- Vectra dash display - Dead pixels?
- suspension
- cavalier rear shock question
- Stereo Problem
- C20xe type ,
- corsa rear beam swap?
- From which car are these brakes?
- vectra b heater probs not rheostat
- calibra rear bearings, will they fit astra f gsi? (mk3)
- help coilover problem :(
- Strut Brace
- Apexi AFC Select
- 07 plate astra boot wont open ???
- nova pedal boxes
- MK2 Astra Digidash / Digital Dash red switch investigation results
- Corsa brakes, intermittent!!
- bmw e36 springs, will they fit e46?
- hid kit... will this fit my corsa b ?
- testing xenons on the bench
- c20let corsa battery draining over night...
- Corsa B 1.4, Battery/Alternator problems :/
- astra problems (mk3)
- Xe/let wiring loom the same? What's the difference?
- plastic fuel tank repairing?
- corsa power steering question???
- Help With Vectra C SRi Deadlock....
- Anyone know what this is off???
- Brake lights come on with side lights
- lowered corsa
- Vectra X20XEV Problems. Will not idle when cold.
- Astra mk4 C20LET question
- Is it possible for a transponder and chip to "lose" its memory?
- Astra H 1.9CDTi 150 Sri Glow Plugs
- Reprograming a Omega TID for the Vectra
- mising on a c20let im pulling my hair out with it help please
- What to do with the aircon on a corsa b 1.6 when converting to a c20xe
- astra g heater blower
- anyone turretted mk3 astra for coilovers?
- Faulty brakes on Corsa??? Help please
- Fuse number 1
- Temp Gauge
- Best place to buy HIDs from?
- Can somebody take a look at this for me?
- Vectra B Tailgate Boot Struts
- wiring a 2.0 8v into daewoo HELP!!!
- Vectra B Question
- Transponder Wiring
- Changing four stud to 5..what is needed..
- ??What's the best held held diagnostic code reader to buy??
- Any EDS Phase 1 experts?
- golf hubs
- can i use vectra front hubs on astra gte struts?
- Vectra B Traction Control
- hi all need help please
- Retro fitting Cruise Control
- funked up bolt
- speedo astra g ! not working please read!!!
- Coolant frozen
- Any Electrical Gurus on here?
- 2001 vectra sri estate Heating problems
- do astra mk3 288mm brakes fit my corsa c
- removing abs system and battery relocation to boot
- astra g fk coilovers, strut top bearing??
- where can i get gear linkage for my corsa b c20xe????
- Tyre Sizing ???? :-/ Help
- corsa b combo van not charging
- astra coupe alarm going off
- positive camber on a Calibra Turbo, need to get rid of but HOW?
- corsa b let strut brace
- should i weld diff ?
- HID Issues
- low profile 14" track tyres.
- Drilling discs
- mk3 astra problem
- Ecu Error code
- 5 stud brakes and calipers .
- problem with 5 stud conversion/springs too low on the front of the car?
- roof spoiler led brake light unit only required?Where can I get one from?
- calibra heated seat electrics
- newbie guide to fitting cruise control
- x16xe chips
- heater trouble
- c20ne coil connections
- corsa pulling to left
- Strut brace
- car alarms??
- corsa 8valve conversion help
- Astra sxi door poppers
- Air bag light
- fuses table for cali/cavalier c20xe?
- car heater that uses an all in one heater??
- What is this? On my exhaust.
- chips!!!!!!!!!!!!!!!!!
- vectra c20let
- do corsa b springs fit corsa c?
- Genuine Vauxhall Parts
- Springs crisis
- mechanical clocks to electric
- c20let corsa dash lights????
- fitting a digi dash into a ford
- vectra hubs 2 a cav
- Anyone ever put electric windows in cavalier rear doors??
- willwoods
- Battery STILL dying
- Welding a nut onto a locking wheel nut
- Corsa mechanical box with electronic speedo...
- Corsa tyre advice...
- red light on dash????
- Vivaro door switch / interior light
- Calibra V6 brake servo
- astra mk3 van, which wheel arch liners
- fitting front coaxial speakers
- Corsa B - installing gte digi dash! help!
- Cav/Cally Equal Length Shaft Inner CV
- Heater problom on a 1997 Astra Diesil non aircon
- Zafira Alarm Problem - maybe the alarm sounder??
- Electric power steering pumps
- Inertia Switch?
- Can you stop coilover threads rusting?
- c20xe in Corsa B: No temp or speedo and no ICV!
- Common problem or not
- Engine failure
- Testing electricals
- c20xe corsa b strut brace
- XE Rebuild
- heaters blowing warm air?
- Corsa Strut Top Plates
- 2.5 ecu running a 3.0
- airbag light on how do i turn the light off
- shocks from germany?
- blower problem!!!
- speedo not working
- C20LET Alternator (Vaux N00b)
- Corsa B power steering
- v6 coil pack help!!!!!!
- hi ppl i need help with a astra mk3 horn not working
- Astra Mk4 308mm brakes onto Vectra C???
- brake pad warning is showing on my display
- Corsa PAS, rack ratio and hose routing/manufacture?
- x16szr on bike carbs
- corsa c steering fault
- Crash Damage: Help my discover what I need to fix!
- Alternator gurus - help required with a non charging alternator.
- 12v in car heaters
- Corsa B electric windows install problem
- vectra fuel gauge
- Corsa xe earths
- Corsa c20xe ecu code choice.
- what boost controller
- Weird electrics
- Vectra B rear shock assembly diagram?
- MK3 ASTRA GSI WATER LEAK iIN D/FOOTWELL-POLLEN FILTER& PIPES BLOCKED UP?
- astra mk 4 trip computer
- where can i get braided brake hoses for my corsa at a good price?
- mk3 astra front coilover spring lbs rate
- cant get the cv joint off my mates driveshaft?
- mk2 nova hazzard switch?
- People help please
- Cavalier interior wiring harness help
- astra 2.0 dti temp gauge not working and fans on all the time
- astra 1.6 8v engine blown whats best to do
- mk3 cav heater problem!
- Vectra B N/S Rear brake not working.
- urgent help needed, cav xev code 24 vss??
- Possible coilover problem maybe something else?
- Total Vauxhall tech question: Corsa B power steering
- mk2 astra gte digi clocks fitment to mk3 astra gsi
- Corsa/combo wiper stalks
- C20LET fault code reading.
- Steel braided brake lines
- wiring help please
- my corsa b redtop and the speedo isnt workin?
- testing starter motor
- Vectra 2004 drifts!!!
- Corsa B Chassis
- Wiring up after market oil pressure gauge.
- astra vxr exhaust bore???
- smallest wheel size for cav 16v front brakes?
- Speedo help!!!!!
- zafira z16xe problems
- speedo not working & power steering question
- Software for Opel Corsa GSI
- Speedo not working and ABS light is on.
- F28 Gearbox and corsa clocks?
- corsa b 1.4 ecu pinouts/wire colours
- vectra rear rose bushes are they available as poly bushes
- hotwire coil on chevette
- help with plugs and a pipe on my conversion
- Amplified Interior Ariels, Anyone used one?
- Vectra B steering rack .
- power cap problem
- Jump lead cables to move battery?
- Problem
- corsa gsi 3.0 v6 cooling
- Really need help with this
- Silly question about hubs
- Coilovers on nova??
- cavalier gsi trip computer in to a a cavalier cdx
- Which starter motors fit a 2004 vectra c dti
- mk4 astra speedo lights please help me
- corsa b C20LET
- corsa b relay, what is it for?
- 4 pot calipers
- Astra v6 alternator problem?
- vauxhall isuzu 4pin alternator problem
- brake calipers
- C20LET ecu light continuously flashing
- Boot solenoid/popper help
- what brake fluid for vectra 2.2 dti
- Battery relocation
- Cavalier Gsi brake servo's
- PAS fluid on gearbox
- hid's
- Wilwood fitting 15's?
- corsa b c20xe wheel bearing?
- corsa digi dash
- What's the best suspension for an Astra G?
- can i use mobil 1 gearbox fluid in my 2.2 dti f35 gearbox
- Corsa B Interior Head unit, interior light, hazard switch - Power issue
- corsa hubs ?
- Corsa springs
- Cavalier v6 wiring
- corsa b combo van speedo sensor
- Wheel wobble tried obvious .
- Side to side movement in front wheel when jacked up! Could it be this??
- 60k slave cylinder would you reuse it
- do wishbone polybushes make the ride harder
- dispack wiring diagram wanted please
- vectra bonnet hinges will they fit
- C20XEV Water pump positioning?
- steering!!!! HELP!!
- Astra H CID & BID question
- Where can you get plug+play adaptors for towing electrics?
- Vectra C 2.2 SRi - what front brakes...?
- closed
- corsa heater panel bulbs
- Headache problem with HID lights/ cant source the problem??
- Help with EDS chips for C20LET
- heater and blowers stopped working
- mk3 astra shock adsorbers choice??
- Mk3 astra gsi rev counter/speedo problem!!
- astra mk2 gte intrument panel gone out?
- Vecta B Handling Question
- Mk1 astra with mk2 rear discs handbrake cable?
