- No Warm Air From Heater, only Cold
- Led Sidelights
- espautomotive code reading software
- (!) Light comes on when cornering hard ... why ?
- fiat disc caliper spacing
- acid dipping? what do they use?
- Coughing Astra
- judders
- couple of wee probs
- removing heatshield
- Not to sure where to shop
- astra wing
- ECU Readings
- Astra Breakers
- total astra issues,, i hate my car!
- vectra v6 brakes onto a nova
- V6 Wiring In To A Caviler Gsi 1990
- nova shaft length?
- Corsa seat support - PICS INSIDE
- Bad chassis on Astra mk2
- compression ratio
- Speedo
- another corsa B conversion!!!!!
- To test for battery drain do you..
- Wiring diagram wanted
- Astra H CDTi - Air Con Prob
- car hesitating and popping
- nova sri fan not kicking in
- Corsa C Dash Wiring Help
- Astra MK4 rear Windows
- My corsa ECU
- Gsi V6 Problems
- Laws: Changing Clocks
- brake upgrade question
- upgrading vauxhall astra MK3 alternator
- Cav GSI Rear heated window Wires ( what Colours)
- cav/calibra irs on to cav 3 with rear beam?
- Transponder problem.
- corsa c speed sensor
- Its about to begin...
- Pic Request - Astra GSi rear beam
- help with suspension leg
- Mk3 astra, cav rear beam
- my horns stopped working
- astra gsi knocking
- corsa convertion
- Management Light Zafira GSI
- cav rad
- nova
- Piston size
- my data log of when it blew up
- what would cause......
- door locks (locked)
- astra g mk4 clocks
- digi dash
- Brake pads...
- nova 16v conversion help
- electrical problem :/
- Alarm fob battery
- Corsa B Steering Problem / Juddering at 60mph
- quick mot questions
- just got bum raped by vauxhall again
- brakes! mk2 astra rear discs on corsa???
- ICV cleaning help
- mantzel box
- Confirmation of fault code descriptions please!
- v6 2.6 management light flashing(whilst running)
- overheating v6
- Anybody know where I will find
- Fault Code 18 ?
- help nova rear disc biasing solution
- astra gte calipers
- Which pads?
- Help Car Dies At 4rpm
- Corsa Club 1.2L 1999 - Reversing Switch
- HOW2 Guide - Cav Delayed Light Into Astra
- 2L 16v shafts for nova
- direct-port nos on 40mm trumpets
- Jockey wheel (Astra GSI)
- Steps positions on Astra F GSi Braking
- Removing sound deadening from your car
- car pulling left
- Speedo Type
- Are these compression figures ok?
- e marking
- ECU lite
- time, date, temp ???
- what strut brace for a cav gsi v6
- Electric Power Steering Pump
- six speed inf needed
- super touring 16 v
- who knows about audi quattro's?
- How do u take the front bumper off a Tigra????
- Dta lead connection problem *wrong port*
- Help needed not vaux but a ford
- Bannana Help
- Remote Central Locking
- Fitting a steering wheel.......
- Dash/Dial Swapping
- Would These be a good upgrade....
- Fault Code 14.
- Before i start.....
- Suspension upgrades Mk3 1.4i hi torq
- ECU Replacement?
- Low compression ratio
- how do you adjust a cav bonnet?
- Overhauling brake servo's ???
- nova quick rack
- no speedo help pls!
- Central door locking problem?
- which shafts? v6 into astra mk3
- Vauxhall Carlton diplomat heater matrix removal
- any pics of astra gte trip computer
- ABS Speed Sensor
- got a fair idea but just to find out for sure astra mk3 heater
- kk compressor housing
- refusing to start
- Opel Kadett pulling to the left badly.... advice?
- Best brakes for a Cav GSI
- vectra v6 advice needed please
- What Are The Best Lowering Springs??
- Perm Live Corsa
- easy to change auto box to manual?
- Tips on buying a Cally
- Adjustable regulator .
- Astra sport performance tuning
- Unwanted Traction Control
- ECU fitment
- Convertible Roof Electrical Maintenance Help!!
- Mk3 Astra 16v Heating Problem
- wiring puzzle
- Vectra GSI - Questions
- What actuator will do the job
- mantzel box info
- will the............
- nova gsi rewiring
- Transducer help needed
- vx220 dash display
- afr gauge info
- ok have odd problem with vectra.
- Is there a Haynes Manual which covers the V6
- Guess the accelleration...
- Bilstein Adjustables?
- Turning the Caliper Piston?
- Suspension question
- Differences in standard ECU's
- white dials
- Black ECU Wire (Pic)
- i lost my keys (silly boy)
- how to sort emmisions?
- vectra estate cdx 2.5 v6 help
- chronic starting problem
- digital dash___how2?
- abs light is on
- fault codes
- Gte V6 Wiring
- MBE help needed
- cavvy side light
- what temp is normal
- Running lean in high revs?? Flow rate?? Fse??
- Redundant digidash lights?
- vauxhall help
- 8v air flow meter
- Just 2 small questions....
- hey a little help needed
- Vauxhall Corsa Breeze Hi Torq Questions
- is a apexi boost controller the way forward
- mk3 astra gsi battery light
- help with mk3 astra tuning
- battery light turning on.
- Engineering question- strech bolts
- Boost Gauge
- V6 into astra mk3 (properly)
- Corsa C Wiring
- nova wiring problem
- Rear brake adjuster strut query...
- Corsa C Dials In Corsa B Question
- Astra GSI G/box
- MK4 Astra brake upgrade info needed...
- Mantzel Fitting?
- car popping and juddering
- corsa c fuse help!!!!!!!
- cold weather, starting car
- do L.E.Ts take much looking after ?
- isuzu 1.7 TDi cold start problems
- Bizarre dashboard phenomena...
- How to change CV joint??
- new key
- corsa dilemma
- 1256 Vauxhall Chevette Challenge...
- vectra!!
- not a vauxhall but can any one help?
- water temp?
- how much does it cost to put a car on a jig?
- Suspension Creeks! Corsa SXI 02'
- big end bolts
- centre box removal
- Uprated shocks on a budget
- Calibra V6 Diagnostics port
- corsa gsi handling upgrades?
- Cav 3 litre ECU
- can an adjustable steering column be put in a corsa
- what is this???
- DIS Pack to Dizzy
- Replacing Rear Brake Pads
- AGGGHHH! My Car's going NO-WHERE!!!
- oxygen sensor fault code 13
- Astra gsi mk3 MFD
- clifford concept 300 going off...
- running problem
- washer fluid
- wierd starting SEH
- corsa mfd
- corsa e16se
- corsa juddering/holding back
- weird noise coming from wheel...
- alternator pulleys
- Steering wheel judder!!??
- How do horses escape?
- abs or not
- temperature drop. below 90'c
- K7N 57i on the coupe now
- Plasma dial wiring
- vauxhall nova light faliure help needed
- how easy/hard
- cally v6 wishbones!!!
- cav ajustable steering colum into astra mk3??
- Mk 4 ASTRA FRONT SHOCKS REQUIRED !!!
- gsi starting problem
- Idle problems
- v6 timing marks
- Power steering started to leak what next?
- Astra gsi electrics help
- Mk 4 Astra Sri Rearbrakes
- Anyone using GAZ suspension?
- reving on its own
- mk3 cavalier ignition barrel
- Vectra Heater Blower Resistor?
- Sender unit?
- Can anyone help ?
- cav 1.7 td
- astra mk4 coupe air suspension kit
- V6 Vectra Front Suspension Noise
- v6 brakes on a corsa
- Strange problem
- The definitive tyre brand poll
- Renault experts? Clio 172 problems
- rev limiter
- Vectra/Cav/Cally Suspension
- Speedo problem
