- do you think its dead?
- another prob with cav
- Astra Coupe Cruise Control Question.
- urgent question, Astra mk3 TD
- GTE running but poor acceleration
- digi dash
- help re- assembling ashtray in vx astra mk4 sxi
- pooh corsa
- can i get fiat brembo calipers to fit a cav
- Still smokey while cold
- leccy sunroof?
- Calibra 2.8 V6?
- Dizzy Cap Problems
- Calibra Fault code reading
- White Smoke...
- Air control solenoid on Corsa Sport
- code 31
- main jet needed
- disconnecting aircon
- ast 2.0 eco shafts same as gsi?
- Astra Mk3 track rod ends
- false rev limit at 5k??
- Central locking
- Air-conditioning Maintance
- Battery not charging straight away.... new alternator
- Crows Foot Wrenches
- Clearing fault codes
- Rover Metro Auto problem
- Which brake pads?
- Which brake pads?
- Can someone check this part on EPC.
- wideband + more. i want one
- front end creek
- air box drilling
- Astra D 94: Locked Out!
- Mk4 Astra 1.7td running problem
- hellmans mayonaise variety
- omega td FAULT CODES?
- corsa seh - look at the pretty fountain and river of black gold. long one :D
- auto box prob
- Anyone with Eezibleed kit?
- " Vectra DTI manual boost controller fitting".
- Willwood 4pot brakes
- No lights on Dash or info panel!
- ECU Health Check
- Alternator
- Part Number for a Water Hose
- Brake disc screw
- calibra computer clock
- Owen Developements Geniuses
- faulty led's?
- Rear Trailing Arm bushes (knocking)
- Connection Diagrams
- just a quick question
- N-reg Astra Sport 2.0 16v MPG?
- Five-stud conversion questions...
- Quickshift problems
- ecu with out transponder v6
- Fittin a Ny-Trex system
- how to change a yurbo
- Front discs are shafted, i wana uprate them
- MOT Failure too Rich. What can cause this.
- cutting out
- Cav V6 Rev Counter
- Volvo transplant into Vauxhall
- Astra MK4 service/inspection light?
- Need Answers, Car broken!
- does lowering you car make everything else take the stress?
- Nova - Windscreen fitment
- 'Smoke' resulting from lack of use
- How much brake fluid does the brake system hold?
- removing fuse from tc
- Corsa C inspection light
- door strips
- Astra Brake Upgrades.
- Help! front caliper choice (4pot)
- Caliper fluid hose washers
- ICV troubleshooting for erratic idle
- URGENT!!!! vectra suspension help needed.
- Polyurethane Bushes
- Cav diff/g.box seal leak ? How to fix ?
- Changing Springs
- cav td dash lights
- can ARP rod bolts be used again??
- astra g suspension 2 bolt fixing????????
- 5 stud Conversion On Mk3 Astra Gsi!! Please Help!!!
- transponders of a diffrence
- fault codes
- astra mk3 automatic choke.....i think????
- Corsa C electrical/starting gremlins
- Biggest discs fitted behind Speedline Alessio 2's ?
- Beyond 7000
- Astra-4 Front Bumper Removal
- tc on astra sri
- icv questions.
- Emissions test?
- service logo!!! help (2)
- Temperature Switch V6 Cavy
- service logo urgent help!!!!!!!!!!
- help whats wrong with my car!!!!
- I'm in trouble - not got my locking wheel nut keys
- Best wheel alignment ever!
- nova sfi box replacement, anybody help
- how do you remove the ignitation barrel on a mk3 astra
- Garage recommendation in Uxbridge area
- what could make emissions too high???
- service logo!!!
- non vaux question.
- Nova Wiring
- Help please
- 8v
- fiat coupe discs (can anyone confirm)
- Blink test on a Corsa C, is it possible?
- Corsa Fault Codes
- Gen me up on brakes please......
- Need the 308mm fitting guide...
- imobiliser problem
- mbe 912 managment any good
- rear drums
- does anybody now?
- Rubber Mounts!!!
- help or my wife will divorce me!!!
- ICV Washer
- what do you call the little rubber thing at t botom f the steering colum?
- noise coming from front wheel area
- GTE digi dash
- em light still flashes v6 cavalier
- Rear cyl bank blew up today.......
- Rattling
- Anyone ever opened the central lock ECU?
- dashboard gauges quit working
- Astra-3 wipers
- Girdle
- Omex 710 series
- Will this OBD device work with Vectra + others?
- Wheel Bearings?
- Corsa C dials into Corsa B
- wiring a transponder v6 cavj
- Reconecting a battery
- transponder imobiliser v6 cavy
- how do i do a solinoided boot?
- Really stupid question but....
- Had tracking done now wheel shakes at 70
- Nova mounts question
- difference in standard k16 and hybrid k16?
- fan noise
- astra cab to be a 16v
- v6 cavy starts then stops
- Saxo question???
- Knocking noise on Cav
- Corsa B conversion couple of questions
- corsa clocks
- Vectra remote locking onto Cavalier
- astra v6 conversion!
- few corsa q's
- Box of tricks?
- breaking problem
- Cavalier Toe in/out settings
- Removing Dashboard
- tech 2 on ebay
- Fault code 38??
- burning smell
- were do i get gas struts for cali hatch?
- rear engin'd corsa?????
- cv joints
- Lightweight Fly Wheel?????????
- another mk3 gsi tcs question
- Sender unit
- getting the job done
- fitting bigger discs to mk3 astra
- What amp rating? alternator has a nametag?
- Different springs front and back....MOT Fail?
- Air Box Mods, Astra 2.2 Coupe
- 3.0 v6 into a mk3 cav ?
- Cav auto box/shudder
- Hub Carriers ?
- VAG TDi Cruise Control
- quick shift
- Slam Panel
- Which tyres and brakes?
- shudder???
- vectra ecu fault code 1690 help please
- Corsa Sxi 1.2 2002 Service
- HELP with EML on tigra and FAULT codes
- how low can i go?
- 90459461 90460834?
- Rolling rd Suggestions
- Advice - Cally aircon not working
- Nova GSI Clocks
- Help!!!!!!
- any miggers who can't sleep
- Battery suddenly flat as a pancake
- Outer CV joiint interferance!
- slow wipers
- 2.2 chain
- Heater Matrix removal
- 288mm discs with 4 pot calipers
- Alternator light question....
- running on 2 cylinders intermittently....
- Central Locking Faulty
- Astra mk4 temperature gauge
- biggest brakes under 15s
- Steering/tracking query
- Fitted lowering springs and its no different
- Astra GTE Digi clocks
- C02 Purge kits
- help with part number
- help! Finding Sri
- Suspension changed. Yay!!
- erratic idle won't go...............
- Nova drawing files
- Fitting strut and hub has fell out!
- nova 2l 16v 0-60?
- mk3 astra ne burning smell inside car???? should i worry?
- what cause for smoke on deaccelaration?
- Handbrake cable Snapped!!!!
- mot fail on emissions
- Astra MK3 passenger doors wont unlock
- Using bike TB's
- Changing suspension on a mk 4 astra
- lowering springs
- cav 1.7td izuzu
- Gmax Adjustables for Cav GSI 1990
- vectra v6 downpipes
- cavvy oxygen sensor ????
- k reg astra brake servo removal
- led's and parking lights?
- Jolting astra
- Forged piston supplier / manufacturers
- Vectra gauge Wiring, help needed please
- Tyre Pressure Problem...
- nos, how much damage does it really do?
- dodgy dash
- not a vaux, but need help
- removing door
- locking nut broke
- yey, more corsa SEH problems. electrical.....agaaain
- e.m fault codes
- astra 1.7d k reg brake servo
- how many teeth on abs ring
- alternator on its way out?
- Astra G Wiring Tachometer Help needed
- astra cutting out on start up......
- cv joint
- transponder v6 caviler
- tappin
- Corsa c 1.2 sxi 02' Service
- Drums to discs - Nova
