  1. Diagnostic Problems !!!
  2. Astra cabby hydraulic fluid???
  3. crunching noise
  4. Astra mk4 2.0 Sri
  5. Mk4 Astra SXI problem - please help!!!
  6. v6 brakes
  7. ECU differences
  8. Manta B question
  9. enigne temp
  10. Vauxhall Service Price?
  11. mk4 astra 2.5 V6 what engines fit???
  12. What springs to replace the Ventura's with
  13. another strange noise
  14. T34 kits from matheus updates...
  15. My car rattles like a tumble dryer
  16. Indigo lights/Dashboard light
  17. Vectra MFD Question
  18. Erratic idle
  19. Cruise cable/actuator
  20. Temp never rises above 90.
  21. Hissing Air Recirc
  22. Cavalier - Wet Carpets
  23. vauxhall silver alloys-but what silver? as they don't give a paint code!! please help
  24. how to remove ignition barrel
  25. ignoring lamdna on 20ne
  26. Revs
  27. ECU Question (Ford Related - sorry)
  28. help!!! what offset do i need
  29. What does the Hall Effect Switch do?
  30. digi dash into corsa sport
  31. thumping noise from nearside wheel.cav mk3 v6
  32. Timing
  33. Judders
  34. idle speed problem
  35. abs lamp on cav gsi
  36. ECU dfifferences on Cav SRi 2.0 8v
  37. Help please
  38. What does a hump hose do?
  39. vx220 clocks
  40. ECU help
  41. K+n?
  42. Heater blower not working, what can I check?
  43. suspension
  44. Reesetting a vacuum gauge??
  45. Will Cav GSi suspension fit a Calibra
  46. Where's my BOOOOOST?
  47. HELP PLEASE!!! Nova keeps dying at lights etc!
  48. Help needed please
  49. what to do about my front end.
  50. Astra Mk3/F Slam Panel
  51. electronic speedo systems??
  52. VVT Technology
  53. Bump Stops
  54. Astra Mk3/F Facelift Version
  55. have a part no. wats it for??
  56. Vectra door handles on Calibra: help needed please!
  57. inside of tyre rubs anti roll bar and wheel arch on full lock
  58. Code 35 - Idle Stepper Motor
  59. Compression test on Lotus Carlton
  60. Does anyone know what I/C this is? Found it at scrappy!
  61. tryin not 2 get angry with my corsa
  62. Astra Mk3 & Calibra - Common Components
  63. Help on Astra Mk3 Heater + Fan Probs!
  64. Corsa Cracked B Pillars
  65. can anyone tell us what 303 fault code is please?
  66. Nova rear springs
  67. looking for switches
  68. calibra rethink!!
  69. After a bit of help - thanks.
  70. Tech 2 Fault showing Low Voltage?
  71. ticky rebuild
  72. Boost gauge problem
  73. Vauxhall Calibra Washers
  74. replacing steering wheel with an airbag
  75. where should this pipe go?
  76. Where is the ECU?
  77. astra/cav/cally struts all the same??
  78. ? about fog light on dash
  79. vectra v6 and cav v6
  80. Jacked car up, now squeaks like a mutha!
  81. Ford people, need some advice quickly
  82. help
  83. help please.digi dash into a mk2 astra 20l 8v
  84. HID fitting help please...
  85. loan of leak down tester needed !
  86. more possible trouble
  87. Number plate lights - Astra Coupe
  88. Argh! Damn Car!
  89. Please I.D. this fuse...
  90. Urgent!!! Please I.D. water pipe?
  91. v6 calibra central locking
  92. ok can we have a definitive on this please. emission check question
  93. Central Locking issues
  94. Fault Codes V6 - Whats wrong
  95. No Heat
  96. E30 rear wheel bearing replacement - that wasnt a nice job!
  97. Newbie Advice!
  98. How to reset an ecu?
  99. Corsa PAS Rack Mod to fit Nova
  100. Help, auto box problems!!
  101. Spi / Mpi
  102. astra MK3
  103. Brand New V6 Engines!
  104. Mk4 Astra Modding
  105. Reverse light oddity
  106. steering wheel wobbling
  107. electric window wont open (astra mk3)
  108. Astravan Sportive 2005, Wiring Diagram.
  109. Broke drivers door lock on Astra, Any1 know which lock I need?
  110. Help with a escort gti!
  111. DIS pack
  112. Astra GSI beeping.
  113. CV Boot Kit....which one
  114. one for the engineers to plough over
  115. Astra mk3 rod ends
  116. vaux tigra front tyre rubs inner anti roll bar on full lock - why?!
  117. vernier pulley 20SEH 8v
  118. ecu immobiliser problem
  119. mechanical
  120. poor performance after rebuild
  121. Help. No water, damage?
  122. tap HELP tap PLEASEtap! tap! tap
  123. redjoseph1946
  124. Sunroof Fuse
  125. sunroof has stopped working
  126. Astra air box? Which one fits the GSi?
  127. 2.0 into Corsa B
  128. wher to start
  129. v6 pic
  130. Omega instrument panel removal ??
  131. Cav GSi Tracking? Or something else?
  132. query about AUTOVAUX.
  133. ECO 2.0,sport man light
  134. Whats the difference?
  135. Sensors in front of rad
  136. Help needed asap pls!(wiring)
  137. cav anti roll bar bushes
  138. Paper clip test
  139. Knocking under car
  140. afr gauge installation...........help
  141. taking out air con
  142. tyres and there pressures
  143. push button start wiring
  144. Car suddenly won't turn over at all
  145. astra traction control urgent help needed
  146. V6 ignition leads
  147. knackered f18 how unusual!!!
  148. DIFF Bearings
  149. Bore wear @ 5000 miles
  150. what to mod on Vectra SRI V6..???
  151. corsa v6 brakes
  152. Lowering advice
  153. Electric Sunroof - Which wires :S
  154. Wheelspin Problem
  155. Help with alternater needed
  156. Calibra strange air conditioning problem!
  157. Nova noisy heater vents
  158. Coolant Capacity
  159. Viper kit for Cav GSi
  160. ABs ECU pin out?!!!
  161. corsa speedo
  162. what is this out off
  163. hydraulic handbrake info and sumfin else
  164. cav central locking - going up and down
  165. Astra GSI
  166. power steering
  167. Wiring relays?............
  168. Facelift Omega Multi Timer
  169. intake vacuum question.
  170. Ceramic coated or not?
  171. Calibra 2wd/4wd shell differences?
  172. any one heard of autosprint???
  173. What are the symptoms of knackered ABS?
  174. ecu v6 problem
  175. vectra hunting and no tickover
  176. vectra jacking points
  177. Astra Mods
  178. calibra heated leather in a tigra
  179. Corsa cutting out problem.
  180. Astra tapping! What could it be??
  181. my cars and "alcoholic"
  182. heated seat wiring? astra mk3
  183. Help Please
  184. parts
  185. Fitting Anti-Roll Bar to Car Without
  186. Converting 2.5V6 to 2.6
  187. s1 lamba vs s2 lamba
  188. alarm roof light (cavalier)
  189. 8v to 16v swap
  190. astra giving proplems...again
  191. Spring info needed, spax owners needed
  192. Need help transferbox problem
  193. Problems with my Calibra
  194. Astra mk3 Sport Brakes Weird one?
  195. auto to manual conversion.....
  196. Wishbone problems
  197. f18 diff replace in car ??????
  198. cav prob
  199. Tyre Blowouts!!!!
  200. Opel Kadett 2.0L 8v GSi
  201. Anyone tell me the quickest way to swap a cav box?
  202. front struts
  203. vauxhall service qoute
  204. astra g upper strutbrace
  205. distribitor help
  206. Pierburg help
  207. I Need Help !!!, my cars running plop!
  208. Play in drive flange
  209. piece of **** car - lumpy drive, waringing light on dash :(
  210. X reg Vectra 2.0 DTi lump into Mk4 1.7dti Van
  211. Has anyone got wiring diagaram....
  212. Are the Inner cv boots the same as the outer ones?
  213. Are Gauges Universal
  214. Alternator
  215. pollen filter
  216. K & N Filter
  217. Moving battery to boot
  218. HID Corsa B H4?
  219. m3 astra
  220. pollen filter
  221. Knock sensor Nova Gsi
  222. calibra v6 cooloing
  223. Stainless tube suppliers
  224. octane plug
  225. Corsa wiring diagrams ?
  226. 3.0 senator straight 6 into a frontera
  227. Which other v6 DIS packs fit the calibra?
  228. corsa air mass metre
  229. Cossvaux???
  230. management light
  231. Strange clifford prob. Possibly battery and charge?
  232. Astra 3 2.0 Sport running cold
  233. 19's on mk3 astra ?
  234. Astra MK4 paper clip test/fault finder???
  235. noisy top end
  236. Nova bonnet light/alarm sensor?
  237. Anyone got gauge fitted .
  238. Flickering ECU light after ignition turned off
  239. Handbrake cable bracket info
  240. Wiring help needed PLEASE
  241. Corsa sxi Starting
  242. Mk3 Astra Heating Playing Up
  243. Pic of 1,5 and 1,7 isuzu
  244. another daft cr q
  245. Alternator Amps
  246. dastek info please
  247. cavalier altenator
  248. Frontera 'cooler, how hard??
  249. COmponents for check control
  250. do you think its dead?
