- Vectra 2.0 DTi
- Cream under filler cap!!
- PLEASE HELP - How do You change an ignition barrel?
- fitting guide to put twin 40s on my nova gsi
- A Few Quick Cav Gsi Questions Please!!
- First MOT and Failed :-(
- ICV issue ?
- Deadlocks
- misfiring problem
- fao.People running 2.0 converted Corsas
- installing rev clocks in corsa
- Quad Driver Module Error
- Hole in Hose
- any pics...
- rattly corsa
- cav 1.7 td izuzu
- mbc and fitment
- mk2 astra v6 mounting
- any1 got picks?
- starting problem!!
- Questions bout my £175 vectra.. bargain?
- le jetronic on mk1 gte
- vectra C knocking
- HELPearth wire on astra gsi
- New Reg Plate HELP
- Astra Mk3 electric window problem.
- 4 x 4 unit and wheel sizes
- on screen boost display
- Fan overide...
- Triple info display fault code reading
- 3.0 Omega Autobox???
- Pioneer KEH-2030R and CDX-P670
- hydraulic tappet noise
- rear wheel bearings on R reg vectra
- HELP! removing ignition barrel
- airbag light please help
- Corsa conversion
- dis to dizzy please help
- V6 into Manta A
- Vectra Remote problem
- Frontera Cruise Control - Help!
- Fiberglass/polyester parts
- Nova Suspension?? & NOS Query.
- awd nova
- can you test a iscv?
- Braking problem on my calibra
- How Much ??
- installing universal central locking (diy gti)
- 5 stud onto mk3 astra
- Anyone tell what/where these connect to?
- air leaks......is there a way to spot them?
- rev counter goin crazy,
- ecu OBD-II
- Posible to do?
- slight hiccup!!
- Steerering wheel / Air bag removal, Clio 16v
- Cant get ECU apart!!
- Using Smt 6 software
- Calling senator owners.....
- where do i connect adjustable boost
- Could anyone tell me what these are??
- ecu question..
- External Temperature Sensor (pictures?)
- Whats the difference???
- anyone selling corsa conversion engines?
- Replacement Disks for Wilwood 4 pots
- mk4 astra springs
- what does this warning light mean
- Giant blade fuses - whats their point?
- advancing and retarding????
- Back Box compatibility question
- traction control in astra mk3
- Corsa died in rush hour traffic...
- Digi dash bulb Question
- RWD/FWD front suspension differences
- astra gsi
- will vauxhall 5 stud alloy fit a volvo 5 stud pcd 112 and 114
- Will Cav gsi lowering springs fit on a Vectra?
- Corsa Speedo cable
- Mantzel for corsa
- Brake bias a problem??
- top mounts
- Which pins to short OBDII
- help please tigra thay cuts out
- NOS on a Cav TD?
- Senny heater fans....
- What Parts Are Needed to make a Nova 5 Stud?
- substitutes for coolant hoses?
- shiney v6 pics?
- early mk2 coscast onto 92 calibra???
- New shocks - need to settle?
- Any1 know how to fit aftermarket alarm to std central locking?
- Any1 know how to fit aftermarket alarm tostd central locking?
- Vectra 3.0 conversion (56k beware)
- ecu codes 31 &71
- astra cd layer... help.
- Speedo sensor help please
- Removing rotor arm .
- battery light omega
- zafira diagram
- wiring angel eyes on mk3 astra ???
- 2.0 16v
- power steering conversion
- Which Wold Be Quickest???
- 16V nova conversion?!
- astra 2001 estate shock absorbers
- Piston damage..how bad??
- bonkers leccy windows !?!
- what alternator ampage is fitted to calibra 2.5 v6 1995
- The speedo 'W' number?
- Astra 1.7TD advice/help
- Fiat Brembos
- Battery Charging Rates - on a multimeter
- *help* Vauxhall Corsa displaying "Panel"
- ERB III boost controller
- cav v6, won't always start?!
- Big brakes.
- Has anyone played with vtecs?
- Bmc Cda On Corsa Sri Problem
- advice needed - new LED's for corsa dash
- New to Car Mod
- Poorly Calibra 16v
- What bolts need replacing ??
- Corsa LS front end repair help!
- Auto to maual
- Rattling brake
- could you miggers help me?
- vectra diagnostics
- Corsa Gsi trouble
- V6 brakes upgrade where and what to buy
- Removing glass from mirror!!
- Astra GTE Springs, what will they fit???
- Cav making rumble noise - bearings?
- mk2 cav heater matrix pipes
- EPC users.....
- conversion kit
- piston rings on fessy
- how heavy are the astra gsi and corsa gsi standard ?
- electricks 2.5v6
- virginal dizzyless need advice
- speedo just stopped working (corsa)
- calibra
- 97 vectra remote centrol locking not working
- piston ring land gen needed ?
- couple of questions about a v6 cav
- Corsa GSI Trouble
- Splitfire or Revotek (Boost Gauges)
- Cut break hose??
- need advice on my nova
- Rear Brake Regulators Or L.a.v???
- EM light again on the cav
- quick answer needed on suspension on a cally!!
- poolem filter, where is it?
- Koni Adjustables
- sfi box
- Removing track rod end from struts!
- Nova suspension
- Where will....
- cav sri 8v ABS question
- Help with grundig rad/cass
- Removing fooked Mcgaurd wheel nut!!
- fitting dual controls
- Any Suspension Specialists Out There????
- non vaux motoronic 2.7
- auto to manual
- Trackrod end for a corsa 1.2 sxi - HOW MUCH?!
- alternators!!!!!!
- symptons, need your help
- knocking suspension
- how do you remove parts?
- Fault code 19
- 00MY Astra Coupè - Upgrading my air-condition to automatic
- MBC and overboost???
- mot failed!!! hand brake ratchet + emmissions!!
- Vernier Pulleys
- Ny-Trex Nos adjustment
- Poly Bushes
- Removing thermostat
- Corsa 03, Running Jerky And Poor Acceleration
- Corsa conversion (not the usual questions)
- What suspension?
- Oxygen Sensor Question
- brakes
- Work in progress-non vaux rebuild
- Speedo drive sensor
- battery light
- central locking
- Dodgy thermostat?
- Corsa handbrake dividier
- lock problems
- Corsa cut out problems
- Boost Control?
- zafira!!
- horn wiring?
- cruise control
- seh air flow meter voltage reading at 4.5v
- cool running stats
- big brakes
- rear shock absorbers too long
- Installing a speedo cable - nova
- identify this seat subframe, mini ? pics inside
- transmision problem
- Vauxhall Corsa Time/date/temp Display
- Astra g ,speedo ,traction control , abs not working
- Xsara hand brake help
- marco
- Mod/reworked plenum on V6
- torque tube
- Spluttering GSi
- caly ABS cutting in under normal braking
- Astra Mk3 Central Locking Problems!
- nova querie
- tool kit
- Gsi problems
- Mk3 Astra Brake Union
- problem with cav auto box
- Magnex questions
- Koni Adjustables
- Abs Light
- Astra sport steering?
- Advice please!
- Omega 3.0 MV6 cutting out after 5 mins?
- 55Amp Alternator
- Cavalier GSI 4wd Warning Lamp Trouble ???
- nova handbrake cables for disk conversion
- Mystery stalling problem on a Nova....HELP!
- vectra central lock remote & radio problems
- c12nz tuning - no laughter!
- astra gte
- changein the style of my astra digi dash
- dont shout at me vw problem lol
- Best place to get ally sheet or something?
- Calibra Electric Window Leaks
- LPG Vectra tuning
- Decent plugs for my motor
- removing brakes
- jerkey on acceleration
- astra - Battery DEAD :(
- vacumme locks on gauges
- how many v6 novas are out there?
- MK3 astra, fault 85
- omega owners manual
- Tuning VW Passat SE TDi 110
- need a pic of re-drilled discs. 5 ot 4stud???
- Has enyone fitted a Frontera IC to coupe
- How to check fault codes z22se
- Transferbox what options????
- How can i improve Braking a Corsa with aC20xe
