  1. Brakes
  2. here i go again wiring
  3. Nova Brake Fluid
  4. Heating!!
  5. Brakes!!
  6. Cav Rear Brakes "discs"
  7. can anyone help me with my mk1 astra
  8. Nova SRi.....
  9. Ignition Feed Live
  10. v6 into astra
  11. digit dash form kadet gsi
  12. Omega brake pad warning light.
  13. how big can the lip be on worn/wearing discs?
  14. astra mk3 suspension question
  15. Personl Project (nova) all plz read and help
  16. Nova GTE alternator options??
  17. max reving??
  18. drilled grooved discs on ebay !
  19. Coolant
  20. corsa passenger door help please!!!
  21. 2l 16v in nova van
  22. Audi parts
  23. hellp pleaseee
  24. air sesnsor problem
  25. Someone cross reference EPC for me
  26. digidash sender problems
  27. Speedo calibration
  28. Help!!!
  29. Which colour wire is the rev counter?
  30. T28 question
  31. Tim Gauges wired to the dash light dimmer?
  32. Astra Mk4 Speed Sensitive Relay
  33. Meta Car Alarm HeLp PlEaSe :(
  34. How important is a Heat Sheild?
  35. how hard
  36. Steering wheel boss hub adapter! corsa b with airbag
  37. autogauge volt reader fitting help needed
  38. How many splines on a hub for Cav 1.6 8v?
  39. boost fault code
  40. anybody know much about or tried this???
  41. spec
  42. lumpy
  43. Corsa C Clocks question (techies)
  44. Meriva upgrades
  45. Mk3 Astra V6/20SEH wiring HELP
  46. wiring instructions needed
  47. Contaminated brake pads?
  48. (!) Dash Light????
  49. Timing Chain
  50. ABS problem, won't pass an MOT
  51. noises on my nova
  52. SEH into an NE car.......
  53. MOT question urgent help needed here
  54. ecu wiring
  55. Changing Nova to 5 stud?
  56. help!V6 astra
  57. What to paint my suspension legs with?
  58. Clocking mileage forward? (pm me)
  59. any1 using poly bushes on a cav cally? are they any good?
  60. Help, Strange Noises
  61. lumpy on startup
  62. Nexia questions.
  63. Car died whilst driving
  64. digi dash
  65. mot help with corsa
  66. How much capacity increase can standard management cope with?
  67. Mk3 Speedometer cable...go bye bye!
  68. Astra gsi...confused!!!
  69. where is the lights on buzzer in new corsa??
  70. shakes
  71. Hose pipe clamps..
  72. How to get Momo Steering wheel Boss off???
  73. ECU reset ? ? ?
  74. Wiring up switches on heater control panel...
  75. Pic Request - Astra GTE 16v
  76. nova sri dials incorrect??
  77. 2.0 8v twin webber setup, help needed
  78. Digidash mileage colour
  79. 2.0lt 8v nova questions!!!
  80. calibra radio
  81. V6 question/suggestions please!
  82. Corsa B Washer Jets not working :(
  83. digi dash in a corsa B
  84. Bleeding brakes
  85. w reg vectra gsi discs n calipers onto astra mk3
  86. few quick corsa questions
  87. ecu diagnostics light (with pic)
  88. cavi 2.0 sri conversion to nova
  89. Where to get ARP rod Bolts?
  90. vectra calipers?? all same??
  91. what is this? (with pics)
  92. Uregent Help Needed (speedo And Dash Not Working)
  93. No compression
  94. Corsa Problem - heating
  95. Mk5 IC to Intake Pipe
  96. 2002 Astra: Compatible CD players
  97. My electric mirrors don't work.
  98. what car uses the same front strut as a gte 16v?
  99. Bootlid and Instrument pack question..mk3 Astra
  100. Closer Ratio Question!
  101. ATT: All super machs
  102. corsa clocks
  103. side repeaters won't work
  104. lowering a coupe
  105. 95 Mondeo
  106. Torque settings 2l 8v
  107. Cossie smoking from cold
  108. brake disc and bell sources
  109. Can anyone help me with a corsa gsi question?
  110. please help me
  111. help it will not start
  112. Road noise.
  113. Vauxhall Arena 2.5
  114. Replacing A Nova front window??
  115. Traction control ecu on a mk3 astra
  116. Urgent help-Disconnected wire
  117. wheel size with digi dash in mk3 gsi
  118. bias pedal box, no servo. suitable for road use??
  119. Astra G front wipers
  120. rust along top of windscreen - MOT
  121. omega mv6
  122. Nova Brake Question
  123. HUB adapters for VXL with 5 stud
  124. Air flow meter error code 74 (high voltage)
  125. astra gte calipers
  126. Help!!
  127. corsa time/date display in nova anybody?
  128. removing digidash from astra
  129. V6 into a mk3 2.0 16v sport
  130. Astra Gte 16v Starting Problem
  131. Kent vernier torque guide?
  132. MBE 967 and LM-1
  133. cruise control
  134. Oh dear, Ebay fool
  135. traction control
  136. Calibra V6 rear suspension diagram
  137. Rear seats won't fold forward
  138. Trip Computer
  139. Astra g intermittent wiper fault
  140. Im not making required overboost levels... Whats wrong?
  141. Cig lighter and Heated Seats not working
  142. Anybody know the guy who. . .
  143. 2nd Cig lighter
  144. MK3 Astra Illuminated Sun Visors
  145. cruise control help asap??
  146. please help, im getting frustrated!
  147. Coolent system light - astra mk4
  148. Struts on Cavaliers - which one?
  149. Calibra Wiring Question
  150. juddering when accelerating hard
  151. wat is it called
  152. Astra GSi Alternator Bracket
  153. Getting a bit annoying - boost .
  154. FAO anyone following my 2.0 corsa woes
  155. Heat shrink
  156. Wire
  157. shock absorbers question
  158. 8v astra gte wiring help
  159. Wheel Bearing (Nova)
  160. Bigger brakes
  161. astra clock and digi display thingy
  162. heater control unit
  163. Dancing rev needle
  164. Tyre Pressure
  165. Refitting brake lines to new calipers
  166. Calbra V6 rear subframe
  167. Front to rear brake-pipes
  168. anti roll bars
  169. CV joint help!!!!!
  170. Dashless MOT gotchas?
  171. Calibra running poor after a couple of minor repairs
  172. ABS and Traction Control removal
  173. stupid lights on my dash
  174. corsa gsi battery blew, now not starting?
  175. 14" wheel, brake upgrade
  176. zafira! a few questions
  177. putting rev counter clocks in corsa b
  178. Windscreen washers
  179. mk3 suspention kit advise!
  180. Snapped spring!...
  181. need help with speedo asap!
  182. raising the rev limit on stock ecu?
  183. wanting to install nos
  184. Fitting 2wd conversion
  185. ATT: ALL TOP MACK"S
  186. ride height
  187. ?????????
  188. Girlfriend's Corsa - Crazy lighting problems
  189. Corsa Brake Conversion to 2.0 16v Front
  190. How to change manual windows to electrical!!
  191. Battery Problem...
  192. Emgime Overrunning when switched off
  193. Corsa b wiring/charging problems
  194. v6 astra help!
  195. clunking noise coming from drivers wheel area..
  196. Help Idling problems again
  197. corsa rear disc conversion? (abs)
  198. part number check
  199. Split water hose + Gaffer tape
  200. convert power steering
  201. Will this ECU work in my car ?
  202. retarding dta ignition
  203. Help
  204. Removing ABS From Mk2 Astra
  205. Corsa Brakes
  206. Astra Heated Seats?
  207. ID car and also alarm
  208. Random Calibra Damper q......
  209. Whats the correct procedure to bleed brakes on a Calibra
  210. Radio or aerial problem?
  211. S/S pipework suppliers
  212. high idle. climing. also, alternator light
  213. Cav Gsi problems
  214. Mk2 Astra Quick Rack??
  215. Placing of diagnostic plug in Astra G 2000 ?
  216. Squeaking noise..
  217. jerky gsi2000
  218. Brake pressure testers
  219. screeching noise from brakes
  220. Tigra Sunroof
  221. Digi Dash Info Needed Please
  222. sensible drop
  223. sri transplant to astra
  224. ****ing Car
  225. Strange one, getting worried
  226. Corsa Sri elec windows
  227. Any1 Know Of A Good......
  228. Cars Running! :D...
  229. Omega c L.E.D Dash Conversion?
  230. Brake Upgrade
  231. climate control 4 s.t veccy
  232. 8v timing marks.
  233. A few q's about wideband gauge fitting
  234. Front Stabiliser
  235. conrod deseem
  236. Result! just a thanks to everyone that helped
  237. brake shoes
  238. Brake (or rear light) warning check bulb?
  239. Rear brake light bulb..
  240. performance ideas
  241. astra gsi cooling fan resistor??
  242. water hose gen wanted
  243. Quick MK3 astra help please...
  244. CAV/CALLY without PAS ?
  245. When i turn left Em comes on/ it cuts out
  246. astra gsi computer thing
  247. GUESS WOT VAUXHALL CAR THIS HAZARD SWITCH IS FROM?!?! please
  248. Gabi05
  249. coolant sensor.(guage)
  250. can i swap door locks over
