  1. Nova twin 40's question
  2. Volume model
  3. ECU protocols
  4. Horn Type
  5. are there any ways to test a coolant temperature sensor?
  6. c, z ,x
  7. scuttle/battery covers in a nova
  8. Nova/Corsa Weights
  9. urgent emmissions help needed!!
  10. faint battery light? cavalier
  11. Alternator or battery problem (non vaux)
  12. Vauxhall Corsa start up problem
  13. Replacing Cig Lighter
  14. 16sv compatibility
  15. Caliper bracket mounting spaces
  16. corsa sri on 40s
  17. brakes binding!
  18. Rattle, vibrating, metalic sound in door...
  19. body repairs
  20. Hi Heres 1n For U
  21. quick PAS pipe question
  22. dip stick
  23. Superchargers
  24. eml fault code 41
  25. possible piston rings gone...
  26. lads please help
  27. what width/profile tyres ona mk2 astra, 15inch rims
  28. God Damn Car
  29. need to change brake fluid - what's the best way?
  30. 4-pot calipers on V6 288mm discs?
  31. temp sensor gauge
  32. airbag sensor?
  33. Electric Sunroof - More Gen Req?
  34. Is this worth trying out?.............
  35. Lost keys, please help !
  36. spluttering problems
  37. Nk4 Astra SRi rear brake rattle,
  38. reading fault codes?
  39. sunroof closer
  40. help lost boost!!!
  41. VX220 seats in a Cavalier - who was it?
  42. Astra van conversion 2.0 16v
  43. Help! vectra b digital display
  44. nova gsi help
  45. just wondering if ...
  46. name this part please!!!
  47. lowering suspention
  48. Vectra front fog light wiring solution
  49. Lucas calipers
  50. manzel style airbox
  51. zafira airbag
  52. could I use unmodified rear vectra V6 brakes on the back of an astra? or r they same?
  53. v6 caliper rebuild - what do I need
  54. whats the biggest discs I can use with vectra 298mm (standard brakes)?
  55. strange revvin prob
  56. Paperclip test help
  57. help !! Astra gte pulse generator
  58. cylinder leakage test - how and why?
  59. Strange electrical fault, any ideas?
  60. ecu
  61. ABS & TC lights and power sounder problem?
  62. How to clean a K&N Filter!!
  63. Whats the highest ampage vaux battery available?
  64. whats the final drive???
  65. are the steering knuckles on a vectra 2.5 the right size for astra GTE hubs?
  66. will veccy 300mm calipers fit standard corsa b steering knuckles
  67. Burnt Plastic Smell
  68. What is overboost?
  69. no compression on cylinder no 2
  70. Cav LCD Clock Wiring
  71. supership problem
  72. CORSA GSI ALLOY WHEELS OVER CAV 16V Calipers
  73. Inside tyre wear on rear?
  74. Custom I/C?
  75. slight hissing from No1 cylinder
  76. Clock dial lamps
  77. whats this
  78. Astra Coupe handbrake cable on mk3??
  79. Legacy LS 6945RD - Hmm...Strange HELP!
  80. mixing 2 pack paint
  81. cav seats onto corsa b subframes?
  82. Anyone Seen this kind of ECU?? PIC
  83. TIS Wiring Diagrams
  84. converting nm into ft/lbs
  85. lowered tie bars on pas corsa q,s
  86. Central looking trouble
  87. Gte Bottom End To A Sr?
  88. Vectra rear roll bar bushes
  89. Problems With Fog Lights
  90. Is it ok to remove the rubber under the gas pedal on astra mk3?
  91. No brake pedal unless pumped up
  92. Vauxhall rear brake pads
  93. mitsubushi fto gpx 2.0 v6 timing info
  94. tigra that cuts out can ne 1 help
  95. Problems With My Cav Gsi Electric Windows!!
  96. Please confirm-which clocks?
  97. Suspension
  98. No Reverse?
  99. Cav clock into Nova
  100. mk3 Astra radio help
  101. Respray Prices
  102. big end bearing clearance
  103. Scary Noise from wheels!!!!
  104. mk3 gsi idling
  105. How to remove rear washer jet (astra mk3 estate)
  106. torq settings
  107. Astra g Calipers
  108. Left side knocking on Cally T
  109. cos cast
  110. Haynes for 1.7TD Isuzu?
  111. back washer pipe snapped on corsa b?
  112. K1 ignition leads any good ?
  113. fast idle
  114. goin to nurburgring in the summer
  115. Ron Plug
  116. Astra MK4 Poor Idle, Hesitation & Cutting Out Help Thread
  117. Knocking noise from front offside
  118. Astra G Heater Lights
  119. crazy question -advice please
  120. Cig lighter in a mk3 astra?
  121. Corsa B Cage
  122. where is the coolant sensor
  123. what's likely to need replaced on a car that's sat for 4-5 years
  124. horrible squeek.
  125. Astra G Idle Problem
  126. Grape ape intake theory
  127. what was you like when you first started?
  128. Castle Nut Removal
  129. Corsa GSi master cylinedr upgrade
  130. ARP Main Stud kit
  131. Correct way to jump a car
  132. Vectra v6 questions
  133. Corsa B Wiper Motor Problems
  134. Intermittent coolant loss.
  135. How much boost to run .
  136. 'CLUNK' from brakes.
  137. 20seh in a nova
  138. Help!! Emissions Fail On A Sri Corsa Help
  139. Vectra Sport V6
  140. some advice with v6
  141. Tyre psi?
  142. corsa conversion owners - where do you put your ecu?
  143. vectra error code 0335
  144. Vectra b 2.0 sri diagnostic plug??
  145. Fookin Calibra again
  146. Frontera A Rear Wiper control / relay
  147. Brake pipe to drum
  148. ICV Question: wiring it manually so it opens?
  149. engines died again....
  150. Corsa B - 2L 8v query...
  151. rev counter on merit.
  152. seats that fit?
  153. Nova IRS rear beam?
  154. 1.9 8v tuneability?
  155. Wheel bearing on a vauxhall nova
  156. CorsaB: Shell strengthening kit
  157. shaky car
  158. my novas driving like an auto
  159. Jst Dies Out
  160. problems with a corsa boss kit
  161. Dodgy tickover
  162. Vibrating brake noise when reversing??
  163. Astra Mk4 2.0l?????
  164. saxo, lowering the rear??
  165. My new toy.
  166. Anyone with EPC?
  167. ball joint/bottom arm
  168. Quick jacking question
  169. I've been fitting a T34 today... pics
  170. Electric sunroof wiring
  171. water in wires, now theyre hissing (corsa b)
  172. Car battery slowly dies as driving then it cuts out, why ????
  173. is anyone clued up on the laguna 2.2td?
  174. V0090383817 what is this?
  175. battery
  176. what options do i have on bigger brakes?
  177. Do I need reverse lights for an MOT?
  178. How is boost controlled
  179. what ign system...
  180. Omega 2.0 16v 2000 reg Alternator
  181. can anyone explain overrun?
  182. jacking point covers
  183. reboring 18e to 20ne
  184. My lumpy idle - Ideas ?
  185. 2.0 astra clunk
  186. How to test a heater panel
  187. can someone please help me with a clifford alarm question?
  188. differences in y32se and z32se?
  189. horn not working
  190. Astra Van MK3 Conversion
  191. Little plastic bits on Wipers
  192. Dry compression test (Results)
  193. whers the best......
  194. please help !!
  195. rear seats for mot
  196. Advertising
  197. 20SEH starting problems AGAIN!!
  198. Moving battery power cable
  199. Astra GSI Spongy brakes with 308's
  200. How much are these worth?
  201. Astra GTE Digital Dash Probs-
  202. single wiper conversion
  203. Making your own brake lines?
  204. ECU Testing Question
  205. vaux tigra rear bumper support / mount
  206. Corsa hub bent!!!
  207. How low can a Tie Bar go? Pics inside
  208. Binning the Nova brake servo
  209. Help Buying brake shoes for corsa b sri 16v?
  210. V6 wirring diagram
  211. Lighter
  212. Need Help Asap!!!!
  213. 1997 MK3 leaking sun roof
  214. 20seh into corsa wiring/general
  215. v6 compression test figures
  216. my mate has a vectra R reg 2.0tdi...
  217. Ignition amplifiers, are they all the same?...
  218. Is this any good?
  219. HELP! ive crossthreaded hole where rear shock bolts to hub
  220. Air pipe question
  221. Mk2 Astra Wishbone pivot mount
  222. help needed please
  223. Astra GTE powersteering prob
  224. corsa and nova hubs the same?
  225. Is my rebuild going to end up on it's arse?
  226. 1995 astra 1.7td speedo
  227. What regulator with TB'S
  228. Cheap suspension kit...
  229. ECU / TECH1 question
  230. Throtle Body Question!
  231. Can anyone help
  232. Vectra 2.0 16v DI warning light
  233. Vectra Airbag light wont go out!!
  234. 1.0 corsa wipers wont sit at the bottom
  235. Astra G 2.0DTI Immobilizer Fault
  236. microscan an0012 - interface
  237. tech info wanted please
  238. Nova Brake Problem
  239. full beams keep coming on.....
  240. 3 pipe
  241. snapped bolt...please help lol
  242. fitment of these part numbers??
  243. supercharger - does it matter which way round the pulley spins? mark.
  244. whats the right price?
  245. T.V mk2 astra's actuator cover..
  246. corsa speedo problems
  247. Temp Problem running high underload...
  248. help with a corsa boss kit
  249. nova dizzy probs
  250. Braided Brake Lines
