PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Lamba sensor for Vectra
  2. Fuse 22 - blows when I turn the wheel
  3. Corsa C
  4. Astra G ECU pinouts
  5. removing alternator
  6. Cav SRi 16v -Elecrics All Gone???
  7. Weber Help?
  8. v6 brake upgrade
  9. Help! wiring adld plug on calibra
  10. Can anyone tell me what sort of weber this is???
  11. speedo
  12. EBD gets confused by different tyre sizes
  13. Axle ratio?
  14. Top Speed Calculations : How do you do it?
  15. tigra compression test
  16. Where is the coolent sensor on a V6?
  17. quick question: brakes?
  18. steering problem on mk3 astra
  19. Corsa starts to knock
  20. New Suspension Kit
  21. Fault Codes 93/94
  22. MK3 Astra inserts
  23. can someone tell me this part form a part number?
  24. Whats next?? The story so far!
  25. Pulling to the left!!!
  26. dis/ignition
  27. fault code 94 hall effect sensor high voltage.
  28. Filler Cap wont Open
  29. where can i get a new air intake and rubber helmet for my viper piperx ?
  30. Astra 2.2 non-runner
  31. Getting conned big time!!
  32. Astra MK3 vs MK2 front suspension struts.
  33. part no. check
  34. Air con...
  35. getting ready for EVO5...
  36. how to wire up foglights
  37. Performance effort of this......?
  38. mk3 astra front shocks ££ quick please
  39. lowering springs question
  40. Autobox fault codes?
  41. Wilwood on corsa (problems)
  42. How do i fit traction control switch?
  43. what size brake disc is best for corsa gsi ?
  44. Clicking Noise!
  45. the strange box thing under the air box
  46. Can anyone give advice on this standard corsa alarm?
  47. Does my car have an Alarm?
  48. dis/ignition?
  49. timing chain
  50. astra digi dash to nova
  51. vauxhall models: belmont
  52. Astra mk4 Electric Mirrors
  53. Replacing Astra GSi fog lights......??????
  54. Remote brake fluid reservoirs on a pedal box?
  55. Parts needed for Corsa V6 conversion
  56. ecu warning light diagram.
  57. Help identifying a part on my mates W reg Astra
  58. Wilwood Breaks
  59. no hot air
  60. W number on clocks
  61. whining behind the clocks
  62. any megasquirt experts about
  63. cutting out and rough running. and ideas?
  64. Vectra V6 2.6 Emissions light
  65. fitting electric windows to my car...
  66. FAO MODS Ecu Light
  67. Can anyone post a pick of a mk2 astra estate or belmont rear quarter.
  68. Rev counter
  69. bigger drop needed on astra 3
  70. digi dash
  71. 1997 Astra van td trouble...
  72. mk4 astra timing woes
  73. help getting major flat spots.why!
  74. Window stuck down .
  75. How much differnce do performance leads/plugs truley make.
  76. Feed For Rev Counter Help Needed!!! Ahhhhh
  77. Picture of my top end... is it fooked or fine?
  78. follow up to my problem,compression test results?
  79. Upgrading to what suspension on Nova 1.6 (8v)?
  80. Basic light question
  81. Ignition barrel
  82. Looking for a Strutbrace
  83. quicker 1/4s
  84. Starting issues, no glow plug light.
  85. 6 speed in a Vectra.
  86. What mods should i be saving for? V6 Sri 1997
  87. mileometer not workin!
  88. wiring diagram
  89. calibra anti-roll bar bushes
  90. cav
  91. What is this?
  92. iv bought some wilwood four pots, just wondering if?????
  93. What boost do you run ?
  94. Vectra gsi rear box .
  95. Air Compressor Parts
  96. what is this in this picture?
  97. 2.0 in a nova
  98. shakes
  99. rev limiter
  100. Where can i get one of these?
  101. Nova 2.0 16v shafts?
  102. can anyone help me do some wiring for a conversion
  103. Is it possible to fit cruise control...
  104. power steering
  105. I must be really dull to you lot
  106. Startup Noise on Astra 1600 sport.
  107. sounds like a lolly stick in a bike spoke
  108. My Astra does not like going into 1st & 2nd
  109. Manually cut through inner wings, easy or not?
  110. power steering
  111. mk4 Astra SRI tick over problem
  112. Banana number check
  113. V-max EVO 3 just fitted
  114. wiring for air con recirc switch
  115. accumulator bulb
  116. reusing old 'new' tyres
  117. changed my coolant temp sensor... *problem*
  118. V6 Help or anyone who knows about Compression.....
  119. v6 into astra mk2
  120. Brembo 4 pots
  121. help
  122. digi dash help
  123. handbrake
  124. Cav SRi
  125. PAS leak
  126. Urgent help needed !!!!! Break Disks
  127. question about cav/cally clock
  128. mk2 veccy key fob probs
  129. 01 Corsa PAS quest ron.
  130. Please Help Anyone
  131. Diagnostic paralell port WHERE ?? please !! Vec 2.5 V6
  132. Vectra GSi towbar?
  133. 2l 8v stalling problem????
  134. 2.5 V6 Electrical Problem (own doing)
  135. mk3 electic window queiry
  136. Getting 12v from the fusebox
  137. Koni set-up
  138. F.A.O Cav V6 Owners
  139. Mechanical to electrical spedo. CallyT.
  140. sigma alarm help please!!
  141. if i remove abs sensors from calibra
  142. Rear Window Removal
  143. suspension help calibra
  144. corsa gsi abs prob
  145. Just been to garage to get wheels aligned but, they can't adjust toe
  146. What do you reckon are the chances of getting these signum brakes to fit a mk3 astra?
  147. LMF 308mm brake upgrade: total diameter
  148. dropping 5.7 v8 in an omega b
  149. Cavalier 2.0 GLS 1993 Lost Interior Fan & Rad Fan
  150. help with mark3 astra fuses
  151. It still won't idle right!! Tried everything now, grrrrrrr
  152. jolting
  153. 1/4 mile
  154. Been reading about the 2.0i 8V...quick question
  155. Manual boost controllers .
  156. Omega Sunroof in Astra MK3
  157. Corsa SRI 8V
  158. Mk4 Golf "EPC" fault code! Any gen?
  159. 3rd brake light
  160. setting speedo
  161. Please tell your experience with Maxtorq disks
  162. Aerial cable problem
  163. Ruff Running???
  164. pollen filter
  165. battery time
  166. Brake caliper bolts
  167. draining battery......
  168. Gte 16v Ecu
  169. urgent-temperature gauge and tachometer
  170. Can you get chrome intake pipes for a V6?
  171. 94 gsi astra engine's ????? HELP
  172. Parts Online
  173. brake upgrades
  174. calibra suspension
  175. NOS filling
  176. Cant get drums back on over rear shoes im stuck :(
  177. electric windows have died suddenly
  178. cant engage 5th!!!
  179. ECU fault code 94?
  180. is this an abs control module for a cav/cali?
  181. can anybody tell me this
  182. not vauxhall but ?
  183. Still got a prob, maybe electrical
  184. Is this a Nova front brake calliper?
  185. ARP rod bolt torque setting
  186. hall sensor
  187. anybody got a "how to" for a 94 cav w/bearing change?
  188. interior lights problem
  189. nova leccy sunroof...cutting rooflining?
  190. Astra merit speedo upgrade
  191. Sintra flat battery
  192. Installing studs instead of bolts
  193. need help
  194. what cars
  195. Omega CDX cruise control failure
  196. veccy help required !!!!!!!
  197. what would make a rad split twice
  198. FAO Those with Powerful cars; Re: Brake Pads
  199. ecu codes ie PJ
  200. Urgent Help!
  201. rev gauge
  202. help drivin me mad.
  203. Astra GSI Strut Tops Gone??
  204. Heat blower fan never stops...
  205. Wishbones - Cavalier Mk3 & Astra Mk3
  206. resonator box
  207. nova gte anti roll bars
  208. Testing an A.F.M.
  209. Tigra1600
  210. braided stainless steel brake hose for my 200tS
  211. Overheating advice please
  212. Airbag light?
  213. astra j reg wireing
  214. So tempted by a GT28
  215. cavvy
  216. resonator box
  217. rev limiter??
  218. Is te mk2 3dr astra sill the same as the cabrio?
  219. Can I borrow a steering wheel puller please?
  220. gudgeon pin removal
  221. corsa coolant hose question
  222. dta wizards plz help
  223. Problems with wiring
  224. Are new bottom arms easy to do on a nova?
  225. Zafira GSI Suspension\Discs Suggestions?
  226. suspention help
  227. auto box drain plug ??
  228. cav suspension/cali sus? are they te same
  229. Brake disks?
  230. works style Uniballs
  231. Omega Police V6's
  232. Anyone know Fords?
  233. centre console
  234. fitted 4 pots but spongy brake peddle?
  235. v6 Auto box problem
  236. smallest wheel size for 330mm discs?
  237. pinout for Corsa C
  238. URGENT help Astra Diesle THERMO FAN Samantha
  239. Tis 2000
  240. front brake discs
  241. Suspension
  242. clunk wen returning wheel to strait from left but not right??
  243. help with tyres guys
  244. Why a Simtec 56.5 on 94 Cav SRi? (picture)
  245. Speedo prob mk4 astra ????
  246. waste gate sound ???
  247. Wheel bearings & rear hubs on Cav V6
  248. Disconnecting traction control on Cav V6
  249. rwd 16v corsa
  250. coolent temp problem with my mk3 astra.
