- power steering fluid
- Limp Home Mode? whats the reason??
- cav eco 2l 16v probs(not heating up+)
- port and polish
- Whats the best g/box to use on my astra gsi?
- shock spring problem(rubbing)
- Ignition Barrel Removal????
- 2.2 astra misfiring
- am new to dta, ignition timing
- rear wheel bearing on corsa b
- Corsa Leccy Window Troubles...
- Astra Mk2 GTE 16v Central locking???
- aerial connector..
- 2000MY Vectra - leaking PAS fluid!
- brake queries
- 2L nova wheel bearing problem !!!
- Tappy Tap Tap
- Corsa C Steering Poblems
- Elecy Windows - Astra MK3
- wierd electrical problem with windows?
- failed MOT, advise needed please.
- solid/alloy top mount users (conncetric eccentric, dont matter)
- very odd sensor problem (not the usual)
- please help diognostics please help
- sensor question.
- Reading ECU codes from a MK4 Astra...
- Corsa B rear disc question
- clunking noise
- ECU Light - Sensor Changed
- Delocking the boot, mk4, possibly moving lock
- Push button door entry HELP
- Calibra leather seat subframe Q
- Anyone know how that charcoal thingy works?
- digi dash in a corsa
- Car tries to cut out when raining
- Tuning
- somebody please explain this....
- Calibra dash light
- Unsolved Mysteries - One for the clever fellas - my car is running like poop!
- Should i be worried?
- drums 2 discs
- Leccy windows
- ref veccy heater
- cally struts on mk3 astra??
- Black Smoke Vauxhall Zafira
- goddam corsa emissions!!
- damn arches
- help needed please guys
- where to get tuning parts 2.0 8v??
- Sealing a k+n
- Vec gsi firing on 5 cylinders
- Alternator Overcharging
- fitting track rod ends
- hi idle in a nova
- Brake pedal adjustment on astra G
- 2.5 V6 into MK3 Astra
- C12NZ Earth Points
- heater controls
- traction control in a coupe
- Can anyone offer any help with doing timing?
- Removing bushes from Cav/Cally lower arms?
- Advice please people!
- Understanding uprated brakes
- does anyone no where i can get this suspension kit
- identify these fixings.
- 45 webers
- is there a special paint for brake drums??
- im not sure what to get? please help
- strange noise (squeak) from new suspension kit
- EM Light Problem - Corsa B (99)
- did it backfire or detonate
- astra g power steering on a conversion help
- Is it OK to do this? (Suspension)
- veccy cdx
- Vectra flashing EMLight
- airbag???
- help needed with my heater?
- Rear wiper advice needed
- Nova fuse box wiring
- Help with V6 Calibra problem
- koni adjustables on there mk3 astra!
- vectra steering squeek
- quick alternator and battery voltage question
- speedo not working
- Car trying to cut out
- MAF Sensor Reading
- Vacuum Hose
- Helix 6 paddle query ??
- Battery problem - corsa b
- nova rear disc quick question
- lowered vastra handling funny
- will these brake sensors fit an astra gsi
- help needed
- lowering- brake compensator
- Making Brake lines
- Strange electriacl fault, ignition
- Electrical And Mechanical 160mph Speedo which can I use?
- Confused!! Bout Dci Unit......
- Poor brakes (Corsa)
- fan motor problem (astra gte)
- Vectra B GSi problem.....
- corsa hot start problem
- sooty plugs
- question-display electrics? help needed
- Cabby Hood Pics If Anyone Has Some ....
- V6 ECU quicky
- One touch windows
- disapointing rolling road results
- need some parts
- corsa steering wheel
- MFD goes off when lights go on? (corsa)
- clicking noise when door is moved
- Digi dash in Corsa
- temp sensor
- Corsa tie rod bushes
- How to Tune 2002 Astra 2.0DTI?
- Fan still not working at No.2 with new resistor. Electric window gheyness
- nova abs
- code 16
- Cav GSI wheels over V6 brakes?
- yeah got my electric s/r goin but
- Problems starting Nova GSi
- hydralic fluid
- Wireing Digram for a TOAD Ai606 Alarm any one ?
- Steering arm bolt
- Tigra heater fan not working
- Common Corsa C Faults?
- Cruise control on a mk4 astra 1.7 Eco4
- Re-fitting bonnet..corsa..
- Suspension Exploded Diagram
- Vectra ABS Unit changed, now the TC wont work?
- 60mm rim keeps making contact with the road
- Before I buy a Mantzel, anyhave a link to a good step by step guide to Fitting?
- mot emissions figures
- Tuning the V6 ??
- corsa electric speedo sender q
- mk3 springs onto mk4 astra?
- 308mm disc width
- removeal of a astra mr3 stearing wheel with airbag
- Best place to buy vernier pulleys
- wiring trouble!
- izuzu glow plugs
- Will a cavalier GSI ECU Work on my Calibra 16v?
- problematic brights
- Airbox
- Need to no so questions regarding corsa gsi engines and wanted!
- 2.0 DTi Vectra Tuning
- Where to source Nova top mounts
- What do I need to convert my GSi to 5-stud?
- single point to multi point
- does a digi dash have an ecu light?
- wipers self park
- corsa
- fan (heaters) only working on position 3
- 1503 Fault Code
- Vectra LS 16V Auto - the bloody fan
- KONI shock problem
- Auto to manual?
- Another funny idle problem
- Splutter Bearings
- 52 astra club goin crazy!!
- dodgy idlingon astra gte
- Dont feckin believe it!!
- astra gte 8v ABS
- Another smoke question! 1.7td Isuzu Astra
- nova expertise needed
- What ride will i get using standard dampers and lowering springs
- 2.0 8v 1 wire please help!!??
- converting calibra to 5 stud problem
- corsa calipers
- stronger body
- nova speedo
- anyone dealt with APEXi RSM Rev Speed Meters?
- Tyre drift?
- What size is the Gugeon Pin ??
- Can someone fit my suspension for cash
- Mutli info display on astra '00
- Quick check Alternator or Battery
- Alternator mount question...
- what is this part?
- my temperature gauge wont work properly!!
- What "rings" for heat protection
- Suspension Fitting Help !!
- Where did you get your .....
- Help as No Brakes on MKIV Astra
- Cav shocks on Corsa B?
- Help needed, with Vernier Pulleys ??
- diag:1???????????????
- Loud Noise please help on vectra???
- where is the cd changer cable
- mtech rear disc
- Corsa TCA onto Nova
- Battery booster pack question..
- Sidelights
- Supercharged 8v anyone?
- astra wiring problem
- Where is the ABS unit part number on 02 Cabrio?
- ARP 2000 torque settings needed
- Fan fitting prob
- novagte clocks into my 1.2 nova
- rear wiper going when anything is turned on
- very quick arp conrod bolt question
- Urgent - Pics Required!
- Will the reyland 300mm brakes fit under 15's? LOL
- My CDR500 - Backlight Problems
- Braided brake hose Corsa rear disc
- Late Style Digi Dash Bulbs
- Lowering an Astravan
- astra 2.0 dti starting problems
- inner CV - vauxhall part no wanted.
- need some help
- Corsa chewing rear wheel bearings
- Racetech Voltmeter Gauge
- help needed with a tensioner
- new switches
- Suspension
- what's this light on my cally wurbo dash?
- NE intermittent running problems
- astra v6.em light flashing.
- Where can I get a 6 paddle from??
- Bling Pipe Fittings?
- What One Would Go?
- vaux tigra - vibration when braking - any ideas?
- Fault Code 16
- vectra v6 smoking on startup
- Where Are the F No. On A Gaerbox
- radio interference
- Temperature Guage Probs
- starting problems
- Dash Lights
- abs sensor
- Road angel classic with laser alert
- ABS
- Calibra Leahter Into a Corsa B,
- bilstein streetline or KYB shocks
- Battery light stays on. WHY?????
- help on 2.0 8v with 11.1c/r approx
- Advice on brake upgrade for cav gsi keeping 4 stud fitment
- Astra mk3/F Cruise control
- Fuses
- fog lights
- astra v6 wiring.
- scary brakes!!!
- Corsa, Help Needed
- 140mph clocks question
- vernier Cut Outs
- problems with nova gsi wiring
- Honing bores for new rings
