  1. Cavalier Wiring
  2. Astra TDS Boost lag
  3. It's arrived... My ebay bargain (hopefully...)
  4. Electric Power steering Columb
  5. MK3 Astra undertray
  6. Urgent wanted/borrow: Tool ‘KM 517’
  7. Differences between f13cr and f13...
  8. How to tell an Isuzu 1.7TD from GM Low Blow?
  9. drive sharfts
  10. just to cheer u lot up!
  11. alternator
  12. Central Locking Problem on Vectra
  13. mk 4 astra v6
  14. Speedo not working :(
  15. Name and Shame Time
  16. Tuning Advice PLEASE!!
  17. air bag column in non air bag cav?
  18. Part Number for a Calibra 16v rack?
  19. Toyo's on an astra....
  20. Tuning Advice
  21. astra reverse lights help?
  22. Tb question
  23. Mongoose fitment onto cav gsi 2wd ?
  24. Unbalanced braking
  25. Rear brakes squealing noise
  26. Whine under the bonnett...power steering?
  27. fitted pipercross ind kit. have a question to ask
  28. slight flat spot
  29. Rounded rocker cover bolt
  30. Landrover Electric Window
  31. bye bye PAS?
  32. Vectra DTi
  33. Power steering leak HELP PLEASE
  34. what will i need?
  35. Vectra B Rear Brakes / Handbrake - Help!
  36. whats the biggest...
  37. Squeeking from rear brakes...
  38. Lowering springs
  39. cables
  40. quickshift
  41. urgent suspension help needed!!!
  42. a funny one
  43. aircon relay
  44. part no for ignition control unit
  45. 2L 8V conversion with F13 box?
  46. CD standard Player cd 500 I think, random play
  47. replacing brake pads...
  48. improving mk3 astra estate isuzu ride "handling"
  49. corsa 1996 sport help !!!
  50. 1996 corsa sport keeps revving
  51. stupid crap brakes
  52. Front wheel barings info needed
  53. Brake heat dissapation, how to make it better?
  54. Any idea what this is? ANYONE
  55. blue smoke whats normally the problem?
  56. Rebuilding a CV joint?
  57. flip key
  58. Any idea how much a garage should charge for all of this...
  59. car revving by itself
  60. Engine's got the flu again?
  61. Help Me, Please
  62. Boost problem....
  63. Corsa brakes
  64. NE/SEH differences...
  65. nova steering column removal
  66. no power to A/C compressor
  67. ARP con-rod bolts for v6 3ltr were from
  68. fault codes 39/44 on a v6
  69. What is this... (piccie)
  70. leak down test: normal values?
  71. ABS possibly not working...
  72. aircon question
  73. help!! need to know what this pipe is!!!
  74. immobiliser keeps cutting in, help CAVALIER SRI
  75. Permanent battery drain .
  76. cv joint on 2.0 corsa please help!
  77. Question......
  78. "Ignition Offset" option on MBE967i
  79. Digi dash
  80. Cavalier Strut Brace
  81. Mk 2 Astra Pannels ???
  82. nova track rod change - how?
  83. quickshift??
  84. Front disc change, easy?
  85. what is this cable for??
  86. my corsa sport wont idle plz help
  87. f13 box on a 2.0 8v ???
  88. URGENT HELP PLEASE = Omega Earths ???
  89. Corsa springs in Mk3 Astra
  90. quick help needed! astra gsi super charger!
  91. Changing dials
  92. V6 brakes on a nova?
  93. v6 conversion
  94. Corsa sxi Rear Wheel Bearings
  95. please help
  96. mk4 astra speedo help
  97. MK2 GTE Steering Rack - urgent
  98. Help! Don't know what to do!
  99. stereo probs and wiring
  100. compression test
  101. help please... damsel in distress
  102. slight hessitation
  103. Someone technically minded
  104. mk4 astra van lowering
  105. Which Tyres?
  106. Sqeaking whilst turning steering wheel..
  107. boost problems light on
  108. Wiring diagrams / Service manuals - MK4 Astra
  109. dash lights
  110. power steering fluid
  111. Willwood midilite 285mm Kit
  112. Corsa irmscher twin oval !
  113. Hidden/Test menus
  114. Steering Rack
  115. Fitting Illuminated Grab handles
  116. urgent undoing a screw lol
  117. Speedo needle problem HELP!!!
  118. ABS not working, fail mot or not?
  119. astra sport suspension
  120. QUICK:Can someone tell me which of these Regulators is Drivers/Passengers! (Pictures)
  121. astra 1.7 dti really slow
  122. Vauxhall Corsa Date/temp Display
  123. 1.5td isuzu 1.7td isuzu differences
  124. corsa gsi vin number
  125. Help, before I buy new tyres!!
  126. mk3 sport what mods to do????
  127. Fault Code 13 Oxygen Sensor
  128. is there a vx 300m disc 5 stud ?
  129. Mk3 astra v6 speedo wiring?
  130. What have i found?
  131. do SPAX do refurbs??
  132. vectra 6 speed conversion
  133. Nova GSi fault codes 46&47
  134. cv joint?
  135. Vectra GSI Problems
  136. abs light
  137. 1400 to 1600 tigra conversion problems
  138. car ideling rough
  139. i need advice asap...
  140. cav gsi cv joint
  141. heated seats
  142. cv joint price
  143. are these two mounts the same?
  144. Torq settings
  145. corsa v6 conversion kits, where from
  146. Alarm Help
  147. Fault code 16 - knock sensor??
  148. vectra ls mirror problem
  149. help with suspension
  150. Wich intake is better?
  151. Propshaft joint for later type Tbox
  152. Pleeeeeeeease Help!!!
  153. Remus perfomance centre pipe for Astra G
  154. Noisy Calibra 2.0 8v
  155. heater resistor
  156. bit of a silly question
  157. V6 CDTI Judder
  158. heater switch
  159. quick MOT question
  160. Z22SE Bad MPG
  161. Corsa sxi Rear Wheel Bearings
  162. need help regarding alternator/battery light on dash
  163. connecting EM light and diagnostic plug
  164. Astra MKIV Inertia Switch?
  165. Wiring Diagnostic Plug???
  166. wilwood Brakes
  167. speedo cable on corsa gsi
  168. Pas pump pulley
  169. Cav Gsi - Pulls left - Brakes right - General Instability
  170. heres a question?
  171. dodgy strut top??
  172. anyone in kent
  173. digi dash into mk3
  174. whining power steering arrghh!
  175. 4 pot brakes to fit vectra C/signum
  176. corsa tries to die!!!!!!!!
  177. Calibra Brakes
  178. ASTRA diagnostic
  179. astra hid,s
  180. Corsa pump and Astra pump
  181. slow electrics gte
  182. Corsa B central locking boot solenoid help!
  183. Corsa C Mirror
  184. SPAX PSX suspension question for calibra
  185. Swooshing type noise coming from.....
  186. "ECM/TCM IGN" 15 amp fuse blowing.
  187. Corsa B "What's This?" quickie...
  188. ECU PROB
  189. Help!!!!!
  190. TB help!
  191. Mahle : Piston - Bore Clearance ??
  192. mk4 lowblow swap to isuzu
  193. Astra Mk2 Cabby Elec Hood Mechanism
  194. help
  195. Poor Electrics Help
  196. 5 stud astra van que
  197. Electronic Rev counter
  198. Temperature guage playing up?
  199. Help! poor electrics
  200. Astra 1.8sxi 2001 cig lighter not working
  201. Vectra rear calipers?
  202. mk3 astra lazy revs
  203. Help looking for a company
  204. Suspension Bushes
  205. Towing an Omega automatic
  206. Would you use a leak stopper???
  207. Where to connect +wire on voltguage?
  208. Fuse Box
  209. Nova battery!!
  210. bonnet stuck
  211. vauxhall wheels on a rover ???
  212. Vectra Electronics shot!
  213. Front spring rates on Convertion NOVA
  214. electric mirrors
  215. HELP!!! what mount do i need?
  216. Astra Coupe Tubo traction controll
  217. Dimensions of Car 200 radio/cassette
  218. Vectra steering wheel controls
  219. Quick question!
  220. Tis 2000
  221. Urgent help needed
  222. Glow plug light?! colour wire?!?
  223. Large rear disc upgrade for Calibra?
  224. Tyre size on a nova
  225. Got these are they worth anything?
  226. Brake problem
  227. strange window problem??
  228. Speedo
  229. What Could It Be.
  230. Noise when boot is full or people in back
  231. digi dash wiring
  232. ecotac woes, high and erratic idle
  233. ref cd
  234. dodgy locking
  235. cav gsi maf
  236. Conversion Question,
  237. steering probs
  238. digital dash problem
  239. Shifter dimensions
  240. Electrical question
  241. v reg corsa envoy
  242. deadlocks on coupe
  243. 1.5td help please
  244. 1.5td alternator gone!
  245. digi dash transducer!!!
  246. Tigra Coliovers
  247. Air bag steerering wheel (might be a stupid question!)
  248. Changing the Alternator
  249. Astra MK3 Display scrambled
  250. Calibra Brakes
